查看: 2598|回复: 5
[求助] procast计算不能继续
发表于 2007-12-25 11:28:54 | 显示全部楼层 |阅读模式 来自: 中国广东珠海
计算不能进行
2 Z9 A) o! I0 o) }, B; S! a. h. o. K) M& O) q' p0 E8 c9 p, i' d
一件我算到1160步后,第二天接着算,初始步长调到1150,算时出现如下提示:
2 R! e& b3 i4 @( p% c; \; I* S( `) S: N* y5 {5 y/ Z" j
--------------------------------------------------------------------------/ q; j/ L# o0 d, `  X8 Y
Petsc Release Version 2.3.0, Patch 32, April, 26, 2005
( U' |. M+ P! g0 ^) _9 v. BSee docs/changes/index.html for recent updates.
; L9 E6 s7 g: p0 X8 X) SSee docs/faq.html for hints about trouble shooting.% H: ^$ Y) @6 o% a5 Q
See docs/index.html for manual pages.
1 w0 B. H  o" J/ A2 |-----------------------------------------------------------------------
$ o0 U1 ]9 l9 o* E. O$ D( Ed:\PROGRA~1\ESISOF~1\ProCAST\2007.0\bin\pro_icc.exe on a cygwin named LONG by us
+ ~# E  p0 N) w2 x4 s: Y/ P/ mer Tue Dec 25 11:24:39 2007
3 ^& S) z: ?, `6 B$ c4 |" ILibraries linked from /cygdrive/d/users/ama/procast2006.1/petsc-2.3.0/lib/cygwin
+ P! s* e7 e9 L2 j! u, K; W  ~; \Configure run at Wed Oct  5 10:19:50 2005
- e1 c) s2 a4 \  C1 O& c0 E6 |Configure options --with-mpi=0 --CC="win32fe icl" --with-blas-lapack-lib="[/cygd
2 L6 e* r9 h; ]1 m% Nrive/c/MKL/8.0/ia32/lib/mkl_lapack.lib,/cygdrive/c/MKL/8.0/ia32/lib/mkl_c.lib,/c
9 C. o$ g3 z, _1 t8 @' V) S1 Y8 Jygdrive/c/MKL/8.0/ia32/lib/mkl_ia32.lib,/cygdrive/c/MKL/8.0/ia32/lib/libguide.li
  P: O1 b& h2 i, N% I7 P1 u7 W& hb]" -AR="win32fe lib" --with-fortran=0 --with-x=0 --with-debugging=no --useThrea. S& Z# i' y6 g1 Z3 u: C2 F" ]# L/ |4 r
ds=0 --with-shared=0 --useThreads=0
' t, S: x: k" \-----------------------------------------------------------------------. ^* H7 ]" J6 E5 Q
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably m
  t: M; l( e/ {0 O0 ]: [6 m* oemory access out of range0 y0 n. @: _' ~" u" R5 j
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger7 J8 u3 m6 m9 p, \) x
[0]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
0 }1 Y8 ~/ w2 v2 A[0]PETSC ERROR: to get more information on the crash.0 b" P% Q% [+ C. w  s; `
[0]PETSC ERROR: User provided function() line 0 in unknown directory unknown fil
! d5 |7 D4 \9 ge
3 M- P9 {/ L" Q% ?4 v5 K[0]PETSC ERROR: Signal received!
( b- k7 ]9 T# ~) H9 X8 `[0]PETSC ERROR:  !. h& @! q8 b1 T& J+ W# h& z
This application has requested the Runtime to terminate it in an unusual way.+ P% m- I: H. Z+ m
Please contact the application's support team for more information.* U, L3 v2 N9 b4 a( z* [
E:\procast\kh1350\kh1350balde-2007-12-24>PAUSE! L$ N+ Q$ l7 j6 _! v$ O
请按任意键继续. . .2 q- n$ y/ u7 r! s3 J- G, w; _$ M, b4 S
. ^' |; M: O; Y; C' l! S7 w4 L' s; [4 I( w8 }: y
不知道问题出在哪儿?计算不能进行$ g: ?9 t. E, z( f
) }% \8 e( H/ Z, s/ P+ G/ k4 B% x/ Q8 o7 F
[ 本帖最后由 zqlong 于 2007-12-25 11:31 编辑 ]
发表于 2007-12-25 19:26:27 | 显示全部楼层 来自: 中国黑龙江哈尔滨
很正常,procast现在基本放弃了
 楼主| 发表于 2007-12-25 20:07:48 | 显示全部楼层 来自: 中国广东珠海
原帖由 阿帕奇 于 2007-12-25 19:26 发表 http://www.3dportal.cn/discuz/images/common/back.gif5 s( b7 @( o& k; D$ x2 L; ^7 |1 U
很正常,procast现在基本放弃了
( V1 G% v- q/ I7 t
8 K5 M, _; p" j% _0 M7 b
/ `. E- c* E- }* Q2 w8 V2 y0 o) e
为什么,我用了不少软件还是觉得PROCAST好用!~
发表于 2008-2-5 21:42:42 | 显示全部楼层 来自: 中国山东淄博
是呀,其实PROCAST只是一种工具,在很多情况下不能得出结果,可能是用的盗版的原因吧,再者我们也没有经过ESI的培训,很多东西没有掌握,我学了一段时间了,还是没有真正掌握,真希望能有人能站出来教我们一下。
发表于 2008-2-6 15:57:46 | 显示全部楼层 来自: 中国黑龙江哈尔滨
原帖由 zqlong 于 2007-12-25 20:07 发表 http://www.3dportal.cn/discuz/images/common/back.gif
2 R5 r2 f* g, H1 ?) _
. ~; x( [! @2 m3 @  Z3 X" y( \3 W# |8 u
& T8 N% p% _2 |% q! ^
2 Q& v2 j* W: W/ k4 H+ E" Q/ h为什么,我用了不少软件还是觉得PROCAST好用!~
3 K7 Y+ v# D8 x! w现在觉得magma和anycasting才是很好的,操作方面anycasting是最好的
发表于 2008-2-6 17:08:11 | 显示全部楼层 来自: 中国辽宁大连
网格的原因吧,一般划网格容易出现问题,最少会网格重叠,所以会出现问题,
