问cimatron 后处理文件是用什么语言编写的,' q. }& W* A) i
LINEAR MOTION: FAST: ; l6 J7 j1 Q v" Q, U9 Q
FlagSpin = NO ; ; p9 Q6 ~) _+ r3 L
IF_SET (SPIN_SPEED) FlagSpin = YES ; END_IF ;
% c- ^1 m) j! G5 X9 ~ IF_SET (SPIN_DIR) FlagSpin = YES ; END_IF ; ) ]; ~$ }# w$ Y" G; F6 m, T) t
IF_SET (FlagSpin _EQ_ YES) - h B& d: @( [, O/ c
SET_ON SPIN_SPEED SPIN_DIR ;
( b6 h( n0 Q' O, p' o9 m
1 R7 L1 ]* V# d, e******************************************************** 2 K% w; l7 V6 k C0 k1 S Y
* define private variables: % m7 N! d. u8 p$ y
FORMAT (SEQUENCING) Seq SubSeq count first deg id K ; 2 l- E( v2 r6 K7 Q; Q( [7 z
FORMAT (COORDINATES) Xold Yold Zold DXcenter DYcenter DZcenter ;
- r: r- P4 S( E, j( _3 u7 RFORMAT (COORDINATES) Zinit Clear Depth CNTRL_X CNTRL_Y CNTRL_Z KNOT_ ; 8 D# f; A2 ~5 h
FORMAT (COORDINATES) Xhome Yhome Zhome Time maxz minz radout timeso ; ( s* }; E5 b, x' ~% ~
FORMAT (COORDINATES) XfirstOrigin YfirstOrigin ZfirstOrigin ;
5 }( z) B9 |1 IFORMAT (USER_1) CurrSubNum ; 8 b4 }# C1 a2 W: i' ~% t4 ?8 A
FORMAT (coordinates) ORIGOLDI ORIGOLDJ ORIGOLDK offset Tol ;+ _$ S: M& M2 z2 m
" r% |* V( r. [! ^9 x* _' @* define private flags: 4 P6 d" H2 x& W7 D! ?, }" u+ v
FORMAT (USER_2) FlagSub FlagSeq FlagSpin; ! ]' [' Z( g5 v* U5 x
FORMAT (USER_2) FirstOriginChange FlagError Flagrotmac ; $ Z2 _) v0 ^# D1 M/ v1 B' }8 b1 J
$ a0 ? [/ |2 k8 ^& Q2 C* define private constants: 8 I# {, T* w! H" a0 @1 A- G
FORMAT (USER_2) YES NO ; ( [9 \5 ]5 U" P# f# d) ~
% k7 i. `" V0 F$ n
FORMAT (TOOL) D R L ;' h5 A: l) c; r, U
*文件命名时使用的TP或刀具字符赋值变量(代码中仅用tl), [$ H. H+ J+ B6 D& o2 |1 A8 n
FORMAT (CHARACTER) tp tl pm ;! p+ i! a) L: m3 Y* c0 ^" H+ q& Z
$ ~) w( H% c& ]! A8 K1 d* z' V0 xINTERACTION (CHARACTER) "SEQUENCING<Y/N>" NumYN = "N" ; - ^5 I: O$ i- a
INTERACTION (SEQUENCING) "SEQUENC-START" SeqStart = 1 ; 2 p6 ^6 v6 t$ H' o- u, m
INTERACTION (SEQUENCING) "SEQUENC-INCR." SeqIncr = 1 ;
# h3 k1 [" h9 L% gINTERACTION (CHARACTER) "JT/A/Sim/B/Fanuc/C/" CONTTYPE = "C" ;
3 k9 i$ E) Q! F4 G& NINTERACTION (CHARACTER) "R-OUTPUT<Y/N>" RADOUTPUT = "N" ;4 g r% {7 p, X* i
: R/ }( \# O; o- }& lINTERACTION (CHARACTER) "X-Y/SN<A/B>" XOY = "A" ;
. W! T) [3 _. W* MINTERACTION (COORDINATES) "DW-X" XO = "0" ;
2 k8 {: w( Y# X) w) r) ] f! q7 J& x& lINTERACTION (COORDINATES) "DW-Y" YO = "0" ;
9 s0 k. f6 O, x! I4 B, e% O$ K, g# lINTERACTION (CHARACTER) "Tel" Tel = "135........" ;
7 n o% I3 L, i" y% uINTERACTION (CHARACTER) "Z/SN<A/B>" Zplain = "A" ;
+ |5 F+ E5 I8 l9 YINTERACTION (COORDINATES) "DW-Z" ZO = "0" ;1 U5 _6 Z2 k H$ @2 z) Z# r
. A) U. S. D M9 a5 p" ONON_MODAL ALL_VAR; t" ^4 N9 k. B$ ~4 |
MODAL X_CURPOS Y_CURPOS Z_CURPOS ;
2 [" I# `1 S! E: {+ x; Z6 ]) M! p2 nMODAL LIN_MOV CIRC_MOV MCH_FEED SPIN_SPEED SPIN_DIR MCH_COOL MCH_DWELL;
- o; _% M+ Y L/ T0 n6 n* R4 F' }5 WMODAL CUTCOM_ON CUTCOM_OFF ;
9 e4 f6 w) d; f1 e: X* Y9 U1 A6 zMODAL CYC_DEPTH CYC_PECK CYC_DWELL CYC_RETR CYC_CLEAR Depth Clear NURBS_MOV; + J+ Z7 c/ @! h1 U
$ B1 e/ U% H! f# WIDENTICAL X_CURPOS X_ENDPT ;
) W" c( O- L; m" J, g- `IDENTICAL Y_CURPOS Y_ENDPT ;
+ K2 y" h, z' i" N9 k+ h. _
2 _1 k. Q$ K* {$ G% v* v********************************************************
8 i9 w& x8 q: M5 D1 mNEW_LINE_IS $ ; - b# N* O: z6 y m3 c6 }, t. h' x
IF_SET (FlagSeq _EQ_ NO) 4 @0 A( i: v% s; ~/ P2 N9 {: O
OUTPUT \J ;
# P. E5 ?1 Q( v5 d( K ELSE 4 R! q' D5 G7 O/ M6 ] h: u
IF_SET (FlagSub _EQ_ NO) , M8 [0 e8 Q1 r5 T
OUTPUT \J "N" Seq ;
- {; K1 v9 I, ^( D Seq = Seq + SeqIncr ;
8 }) x; q4 F; H3 L. F" b6 p+ s1 L ELSE
8 |0 ? ~6 B+ O; r9 {. G# Q OUTPUT \J "N" SubSeq ;
& i# l$ f7 o( V# H0 j6 Q SubSeq = SubSeq + SeqIncr ;
3 V9 b6 C B! s# Z. b$ \0 K, E1 K: B END_IF ; 6 s& K2 u& C: K" c* y+ k( ~% f
END_IF ;
* P% r, d" h3 n. S% W6 x
9 X, J- f( f) H( j+ c7 f******************************************************** 7 k0 @! \) E, T8 T
8 k o, |% u0 }; H! C1 G; b
BEGINNING OF TAPE:
' ]% p+ I& \ Z7 p+ n6 z YES = 1 ;
4 O! a" B8 u* t4 [% { NO = 0 ;
! Q: u) d3 Y) ] O( q2 ^' b Seq = SeqStart ; |
