发表于 2008-1-10 08:40:01
来自: 中国浙江宁波
" S9 D; N: W, k8 b, k6 L" X5 o9 t
lisp代码:) v# t2 ?" p# ^# Z0 @# Q/ U4 z) c
(setq var (getvar "cmdecho"))
% _8 G& P1 m, @: ` (setvar "cmdecho" 0)
( m1 M& C, E* _+ ]5 p* A r$ [ (command "-style" "standard" "gbtxt.shx,hztxt.shx" "" "" "" "" "" "")4 Q" ~: v6 U% }" J4 ~. O( j( |
(command "-style" "单位名称" "gbtxt.shx,hztxt.shx" "" "" "" "" "" "")3 f1 S$ k! T/ H1 {3 R3 V
(command "-style" "工程字" "gbtxt.shx,hztxt.shx" "" "" "" "" "" "")
" X+ u9 {$ v" ^* K6 N6 h ;;(command "-style" "standard" "txt.shx,bigfont.shx" "" "" "" "" "" "")$ w7 {( J1 e* p& B
;;(command "-style" "单位名称" "txt.shx,bigfont.shx" "" "" "" "" "" "")6 ~+ X7 D `5 b9 d
;;(command "-style" "工程字" "txt.shx,bigfont.shx" "" "" "" "" "" "")
9 v. H; E w* H, x (setvar "cmdecho" var)6 E: H( b" g, B
(command "_qsave")/ s, I5 P, j q7 Z
(command "close")$ L# m- \5 Q0 s: x: z7 @; @
) y u8 q0 O# j代码放在acad.lsp文件中,将此文件放在CAD的support文件夹中,在“选项”中设置每个文件都加载acad.lsp;使用时只需打开要修改的文件即可;自己电脑上2008版调试通过;建议楼主先备份一个要修改的文件然后做试验,修改后删除acad.lsp再次打开修改后的文件,如果成功无问题后在做批量修改;
3 h; J/ c' _7 S' C- a# w6 \& z本程序只作方法指导用,建议楼主使用前仔细调试,因各人电脑及软件差异,制作者不承担由此带来的一切后果! |
