查看: 1316|回复: 0
[文献] 聚磷酸铵阻燃聚乙烯的研究
发表于 2008-1-14 20:58:20 | 显示全部楼层 |阅读模式 来自: 中国四川德阳
; m* J6 w& M3 M  F  v  s
【英文篇名】Ammonium Polyphosphate Flame-Retarded Polyethylene
【作者中文名】[url=]刘渊[/url]; [url=]贾润礼[/url]; [url=]柳学义[/url];
【作者英文名】[url=]LIU Yuan[/url]; [url=]JIA Run-li[/url]; [url=]LIU Xue-yi (Research Institute of Plastics[/url]; [url=]North University of China[/url]; [url=]Taiyuan[/url]; [url=]Shanxi 030051[/url]; [url=]China)[/url];
【作者单位】[url=]中北大学塑料研究所[/url]; [url=]中北大学塑料研究所 山西太原[/url]; [url=]山西太原[/url];
【文献出处】塑料, Plastics, 编辑部邮箱 2007年 03期
/ H/ @/ J: @! g) D期刊荣誉:中文核心期刊要目总览  ASPT来源刊  CJFD收录刊
【关键词】[url=]聚乙烯[/url]; [url=]聚磷酸铵[/url]; [url=]极限氧指数[/url]; [url=]力学性能[/url];
【英文关键词】[url=]polyethylene[/url]; [url=]ammonium polyphosphate[/url]; [url=]limited oxygen index[/url]; [url=]mechanical property[/url];
【摘要】通过极限氧指数测试、力学性能测试研究了聚磷酸铵(APP)对聚乙烯(PE)的燃烧性能和力学性能的影响。结果表明:Ⅱ型APP在添加量达到30%以后,PE的氧指数达到了22.4,可以实现离火后很快自熄;在添加了APP后,PE的拉伸强度在开始的时候提高,当添加量超过20%后,其拉伸强度开始缓慢降低;PE的缺口冲击强度在添加APP后,在添加量很低时就产生了大幅度下降。
【英文摘要】The influence of ammonium polyphosphate on combustion performance and mechanical property of polyethylene was investigated by limited oxygen index test and mechanical property test.The limited oxygen index of polyethylene reached 22.4 when the amount of ammonium polyphosphate reached 30%,and the polyethylene was self extinguished instantly when it was moved away from the fire.The tensile strength of polyethylene was increased at first,however,when the amount of ammonium polyphosphate exceeded 20%,the tensil...
聚磷酸铵阻燃聚乙烯的研究.pdf
212.25 KB, 下载次数: 3
