查看: 1308|回复: 0
[文献] 环氧多聚磷酸铵的合成及其对环氧树脂固化物性能的影响
发表于 2008-1-14 21:02:12 | 显示全部楼层 |阅读模式 来自: 中国四川德阳
【英文篇名】The synthesis of epoxy ammonium polyphosphate and its effects on comprehensive properties of cured epoxy resin
【作者中文名】[url=]郝惠军[/url]; [url=]曹诺[/url]; [url=]肖卫东[/url];
【作者英文名】[url=]Hao Huijun1 Cao nuo2 Xiao Weidong2(1.Drilling Technology Research Institute of CNPC Huabei Petroleum Hebei Renqiu 062552 2.Faculty of Material Science and Emgineering Hubei University Wuhan 430062)[/url];
【作者单位】[url=]华北石油管理局钻井工艺研究院[/url]; [url=]湖北大学材料科学与工程学院[/url]; [url=]湖北大学材料科学与工程学院 河北任丘[/url];
【文献出处】胶体与聚合物, Chinese Journal of Colloid & Polymer, 编辑部邮箱 2007年 02期  ' r+ P1 d) F, V% X1 }
期刊荣誉:ASPT来源刊  CJFD收录刊
【关键词】[url=]环氧树脂[/url]; [url=]多聚磷酸[/url]; [url=]阻燃[/url]; [url=]极限氧指数[/url]; [url=]耐热性[/url];
【英文关键词】[url=]Epoxy resin[/url]; [url=]polyphosphoric acid[/url]; [url=]Flame retardation[/url]; [url=]Limiting oxygen index(LOI)[/url]; [url=]Heat-resistant.[/url];
【摘要】将环氧树脂和多聚磷酸直接反应后用氨水中和,制得了含磷18.5%且与环氧树脂相容性较好的新型环氧多聚磷酸铵(EPPA)阻燃剂。用极限氧指数、冲击强度、硬度、热失重等测试方法研究了EPPA对环氧树脂二乙烯三胺固化物阻燃性以及其它各种性能的影响。实验结果表明该阻燃剂对环氧树脂固化物有较好的阻燃作用,适量添加EPPA可大幅提高固化物的韧性,并且对固化物的硬度以及热稳定性影响不大。
【英文摘要】The epoxy ammonium polyphosphate with good compatibility of epoxy resin was synthesized with polyphosphoric acid and epoxy resin.The flame retardancy,mechanical and thermal properties of cured epoxy resin were measured by Limiting oxygen index(LOI),Impact tests,Shore hardness tests,and TG,respectively.The results show good flame retardation and sharp improvement of residue char yields.When the EPPA reached to only 10phr,the cured resins could self-extinguish in air,and to 40phr,the highest LOI value could r...
环氧多聚磷酸铵的合成及其对环氧树脂固化物性能的影响.pdf
128.73 KB, 下载次数: 2
