查看: 1336|回复: 2
[已解决] 有限元分析
发表于 2008-1-15 12:13:46 | 显示全部楼层 |阅读模式 来自: 中国山东淄博
我在做有限元分析是出现这种情况请大家给解决以下万分感谢!===========================================================
8 f0 ^4 @1 E1 I5 W列出信息创建者:     Administrator
$ V( q- q; f2 y7 O日期                           : 2008-1-15 12:15:069 X2 Y* j1 A% s3 `
当前工作部件              : F:\ug_huaxia2\001_sim1.sim
4 v8 [: j8 [) |3 _9 K1 [) G4 {5 V节点名                      : microsof-ce5e30, \& Z) c- V2 C
============================================================- U3 I8 Q% t3 }" z
+ p9 N( j. g9 L
" R: l% N3 @9 H% K" V# ?
, C7 }3 l, K+ M          Solution Model Setup Check Error Summary * P8 f2 S- T8 K: H( I
1 {( I4 v* K& H1 ]' V6 o------------------------------------------------------------' ]8 Z" T7 U* u$ g% \7 r
1 |! N% q8 D7 E& E2 }2 p 解算器是 NX NASTRAN DESIGN
6 P" l6 O8 Y( i3 E4 Q
/ N0 B8 Y( y0 @6 _+ o5 ` 环境: NX NASTRAN DESIGN - 结构! b) N- c; v  P
5 l1 q, H, {0 ~* S5 s
解法是 线性静态 - 单个约束" o3 V7 L3 K* E& ]9 ]
; d% F7 i& m7 |
------------------------------------------------------------  {  u: B; e* E5 A
0 V! i! a) M- `$ p0 e" l* k, k
Mesh-Based Errors Summary- v' m2 w+ E: E% \0 f! T
1 G$ z- G0 S9 B: d0 `" ^
/ ?) g3 U: n/ ?+ {Total: 0 error and 0 warning
" |* H; V: l' a7 Q) ]" k4 r
) N3 P% h  v4 H- ^" T' o9 S8 p
' k6 B9 C+ T2 g/ ~/ W: h$ q( LMaterial-Based Errors Summary
, a1 O5 C' }: _: I% r-----------------------------! d( e. d- t" Z. x/ R
/ @, u6 S" m/ K# t9 X7 h2 Q& m8 p7 T
6 P" U' M. O: k, y; y% n) ]
7 @! z5 I4 N' u9 r& o' T" Q; R+ h" b4 Q
Solution-Based Errors Summary
/ l( u6 \; S/ W5 u6 ]& w-----------------------------
  D% v. y4 d% `. v+ F* n
; v( L4 u5 |7 N; TTotal: 0 error and 0 warning
7 w) [) s9 P) ~2 ~1 E) h% F' f% l, ~: \9 I& M4 w+ g6 F
  V, n. g* N/ T2 R* kLoad/BC-Based Errors Summary3 u: j: Z. k) M3 c
! D" L# ~/ w  Y
3 n# n9 ~+ x) f$ U' MTotal: 0 error and 0 warning
1 K0 j+ X" s" Z3 ?) A
  A8 D* ?1 w5 A9 k
; {( V: p! C3 R* O' }" {NASTRAN Model Setup Check completed
 楼主| 发表于 2008-1-15 12:17:27 | 显示全部楼层 来自: 中国山东淄博
回复 1# 的帖子
还有写着:follow license could not be checked out : nx_nastran_export
发表于 2008-1-15 12:29:09 | 显示全部楼层 来自: 中国山东青岛
NX_NASTRAN结算器不能用。用的是UG4.0吧,它自身不带结算器。
