查看: 4467|回复: 18
[求助] AMESim仿真出现异常,有没有用得熟一些的高手指点一下?
发表于 2008-1-16 16:53:02 | 显示全部楼层 |阅读模式 来自: 中国上海
运行仿真时出现以下提示,不能出结果。9 A' i! l7 Q. L& L* G( e
不知道是模型建得有问题呢,还是软件本身有问题?
) E3 u9 L; h# D8 G
7 K) p1 Z6 t6 a# g6 Ulc_checkout failed with -5 - retrying after a short sleep try no:0
; X4 R6 D- n3 l; Slc_checkout failed with -5 - retrying after a short sleep try no:1 0 h3 R# W; x% c# n: \  H
lc_checkout failed with -5 - retrying after a short sleep try no:2   a+ H% f; t& X0 x# H
lc_checkout failed with -5 - retrying after a short sleep try no:3
; u7 R2 l! a! k9 Q( M8 elc_checkout failed with -5 - retrying after a short sleep try no:4 - j0 \* l! J' X* {: O9 @' T5 @1 d
lc_checkout failed with -5 - retrying after a short sleep try no:5 : S/ \- o  c* {0 o" T- }; G
lc_checkout failed with -5 - retrying after a short sleep try no:6
. j  Q$ T7 l% i+ @# b6 w7 \4 G: tlc_checkout failed with -5 - retrying after a short sleep try no:7
# `4 k- y4 M* b* i# ?' I& rlc_checkout failed with -5 - retrying after a short sleep try no:8
$ W: i. ?- M, S7 L/ C/ e- [) ~lc_checkout failed with -5 - retrying after a short sleep try no:9
1 a. @1 S" m' L) l8 C0 J% qlc_checkout failed with -5 - retrying after a short sleep try no:10
" [# ?8 P7 z6 W7 C6 n- R0 }: ~Checkout failed: No such feature exists. 0 W  L  t' g% X
Feature: hydraulic # r+ G# z( [2 ^. f3 s
License path: D:\AMESim\/licensing/license.dat - \" n! Z% K9 b2 ~5 ?, o) E+ M) g
FLEXnet Licensing error:-5,357 / z! T4 m. U" |$ L- ?6 M
For further information, refer to the FLEXnet Licensing End User Guide,
' w+ T) A, P9 Y3 {0 havailable at "www.macrovision.com".
% Q! ^/ \& ]* EAMESim model E:/cylinder_ did an abnormal exit!
+ P) ~+ O/ A( C# J' T5 x3 a
$ ^1 w: L5 o/ v  N" t/ O4 ~6 k非常感谢!!!
发表于 2008-1-17 09:21:30 | 显示全部楼层 来自: 中国四川成都
可能是license的问题,你弄个帮助文件里面的模型运行看有没有问题
发表于 2008-1-17 15:26:40 | 显示全部楼层 来自: 中国天津
请问楼上这种软件有中文版的吗
发表于 2008-1-17 15:48:50 | 显示全部楼层 来自: 中国四川成都
没有,而且基本上没有中文教材,不过可以看英文帮助文档
发表于 2008-11-25 22:22:28 | 显示全部楼层 来自: 中国内蒙古呼和浩特
的却是lisence的问题,你没有Crack对,可以查查amesim的安装方法,论坛里面就有,crack也有。
发表于 2008-12-13 15:18:48 | 显示全部楼层 来自: 中国湖南长沙
哪个好心人能给我一个amesim 7.0的license
249359104@qq.com
' X. [# S* u8 b. u9 L- {( C+ ~( d$ ~$ ~! g& q9 j
非常感谢!!!
发表于 2008-12-14 09:57:32 | 显示全部楼层 来自: 中国四川成都
你是amesim 哪个版本,我有8.0的crack
发表于 2008-12-14 14:19:04 | 显示全部楼层 来自: 中国陕西西安
应该是license的问题,我有7的crack,需要给我留言
发表于 2009-2-12 15:51:00 | 显示全部楼层 来自: 中国浙江宁波
chdiulong
; o/ b8 i9 L- L; X 请发我一个,谢谢!
& F: |# j- p  l& r, N9 }6 v295992877@qq.com
发表于 2009-3-4 09:26:34 | 显示全部楼层 来自: 中国吉林长春
我的也是只能建模不能仿真,上网查了一下是因为licesene缺少东西
7 m/ v/ t1 F# E# m/ m谁能帮忙解决一下,非常感激!
发表于 2009-4-9 12:41:14 | 显示全部楼层 来自: 中国四川成都
- r* }$ q" `: v5 `9 ^& \非常感谢wff198037@163.com
发表于 2009-5-5 10:23:29 | 显示全部楼层 来自: 中国江苏镇江
回复 7# 龙门起重机 的帖子
我要8.0的,谢谢了
1 c8 N6 d  O: M  ]: Jxunqunde1@163.com
发表于 2009-12-1 09:46:19 | 显示全部楼层 来自: 中国重庆
哪个好心人能给我一个amesim 8.0的license,非常感谢,0 J8 f1 ~$ B; o) t/ f
zzxjbs@163.com
发表于 2009-12-7 21:01:22 | 显示全部楼层 来自: 中国河北保定
发表于 2009-12-7 22:25:15 | 显示全部楼层 来自: 中国内蒙古呼和浩特
发表于 2009-12-8 11:01:38 | 显示全部楼层 来自: 中国辽宁鞍山
论坛里面有搜一下就行了
发表于 2010-1-8 21:29:36 | 显示全部楼层 来自: 中国河北保定
发表于 2010-3-26 09:09:40 | 显示全部楼层 来自: 中国陕西西安
我也出现了跟楼主同样的问题,请问楼主是怎么解决的?
发表于 2010-10-22 11:20:12 | 显示全部楼层 来自: 中国广东深圳
RE: AMESim仿真出现异常,仿真液压库中没有二位二通阀(常开)怎么办
18# joopl2007
