查看: 6604|回复: 7
[已解决] 国外齿轮参数表!
发表于 2008-1-26 04:46:12 | 显示全部楼层 |阅读模式 来自: 美国
国外齿轮详细参数表!寻求国内!!!专业翻译!!!0 U& i/ q  s( o. z& z: @3 v
0 W5 }- g: |# `( r
EXTERNAL SPUR GEAR DATA& |) K1 D6 F+ M& n3 k2 [
   manufacturing data
! q. u0 C# c3 l: O: h' _part number
& A3 C) F1 h" I8 Ttooth form
6 [4 I2 e5 X+ \- u& e4 R$ _gear type
. C$ Q% F- R- ~! [5 r3 anumber of teeth( `- y  ?+ F5 `0 a  n2 F
normal module
2 k. L( X% M. q; y( e) |normal pressure angle (at ref circle)3 ?0 I6 w1 o* t) s( j
helix angle (at ref circle)
/ C  I+ d  C# N3 ^2 ~helical lead
& e! K5 q6 F' J# r8 ohand of helix
6 }5 V7 {) o( \; U" Treference face width6 s" z( T+ n/ y; U; ]
outside diameter3 g+ A/ v% m$ \  J
chamfer diameter
) _6 a5 @& I( p. {7 Qreference(pitch)circle diameter; Q+ D. w5 P# F( t9 B
start of active profile diameter
+ D( ]# r2 [% I; M- hform diameter6 d: y4 i7 s: w
root diameter
  \- p9 l$ }6 g1 `base circle diameter$ |6 M2 L4 Z( M: j* j2 ~
whole depth+ O: v% {" k; S
normal circular tooth thickness (at reference circle)+ s, j* }& ^3 a0 p$ q
root type
( Q& A% N* {5 D+ w0 ?toot fillet radius# |8 @: z+ [1 ]  l2 B& A4 b
lead crown
6 I- l6 G% O2 H; kHOB DATA
7 c: o0 S& F, ^2 ~pressure angle
: M' w# ?% l+ m% Y& j% X2 O5 R; vtooth thickness at reference line
$ \& ~# h; H# yprotuberance
/ i, ~( M0 I9 z. p' u6 r2 `$ B% mtip radius
3 F0 B3 G7 S# J5 H. d8 S6 ^reference part number% O& l- T$ n. Z. J! Q: A% `) p
INSPECTION DATA
' F* ]' n1 C8 Z; x7 P4 u& r
2 h$ I, _/ d# ~" E; d  i& y$ Qprofile tolerance and modifications
7 L' c1 b0 d$ O( d) jprofile hollow6 M. o, H: Q2 h! k$ d
refernce pitch circle runout
/ X4 s* ?7 r5 n1 B) D. ^pitch variation0 o3 m6 y- v' R+ n* m, ?
lead variation
3 Z  f) y1 x0 U$ zlead hollow4 [) n0 G$ k  ^
profile surface finish
+ t7 @! r( q# @0 w( hball diameter
* ?8 d" r# Q- ^' R* mdimension over two balls in same plane; M. s8 G" W1 K! C
REFERENCE DATA-MATING GEAR
8 m0 S$ d/ w8 V3 b
7 [0 a/ i+ ~& Q0 knorminal center distance7 S9 e8 L$ y4 e3 K" ]  X$ n
mating gear part number" I" E/ O! d& Z5 p4 F( A
mumber of teeth on mating gear
. Z, G9 i; J0 ]" Q: y7 lbacklash (nominal CD ,ROOM TEMP)
: p% M1 p5 C+ E7 Y/ n" p& q4 l) i! E6 I4 J/ W
3 l5 c1 \2 D  R. t
$ f  I) }2 c$ Z# q# j# Z上面包含国外齿轮完整的参数,,所以比较简单的翻译内容(简单常用的可以不用翻译)
8 b. b$ K1 V: P' v9 D$ s
; E6 {  |% u" n" b" m+ l谢谢!!!!!
( B' F5 N6 O  ?9 e( M# {
4 y5 d, P, ^6 O2 \$ G/ A! J: h[ 本帖最后由 xcdlyhm 于 2008-1-26 04:47 编辑 ]
发表于 2008-1-26 13:10:41 | 显示全部楼层 来自: 中国江苏无锡
到这里看看. 齿轮参数
发表于 2008-1-26 20:23:43 | 显示全部楼层 来自: 中国江苏苏州
有几个不太能理解,如果有参数和图形可能更容易理解一些。
 楼主| 发表于 2008-1-27 01:09:31 | 显示全部楼层 来自: 美国
EXTERNAL SPUR GEAR DATA(外圆柱齿轮参数)- [! O% u$ l0 m( E
manufacturing data(制造参数)
7 @; d! S5 b7 b6 @( Q* Bpart number(零件号); d* y9 o4 m$ |& T4 b: [! P: V) o
tooth form(齿面)( ~4 z# J/ `5 X) G6 Y0 y6 Z% X* _: r
gear type(齿轮类型)
+ _" n, ^3 \  m+ bnumber of teeth(齿数)( c2 A0 A8 z3 G) x& _
normal module(法向模数). I, x3 m# @$ _+ x% s3 v4 ^+ M7 o
normal pressure angle (at ref circle)法向压力角(在分度圆上)
! s$ G% s! p8 |: P* |helix angle (at ref circle)螺旋角(在分度圆上)9 f9 V1 v. h9 Y! D& Z0 j- O* H
helical lead(螺旋导程)# J( H$ i1 s, W+ S- i  f7 @( H7 A
hand of helix(旋向)1 ~! T( L1 {- u$ f* ^/ b2 {& N0 r( x
reference face width(参考齿宽)
. i8 Y& n) |8 E" }- @outside diameter(齿顶圆直径)  P* a( t, K9 m( l
chamfer diameter(倒圆直径)
! f- \1 `0 u; x8 A1 F% f& Dreference(pitch)circle diameter(分度圆直径)或节圆: F. C  }# G( j/ g( j% @  p
start of active profile diameter有效渐开线起始圆直径
4 r% n$ G. N" L% |5 B% d: aform diameter 展成直径" T1 Y! i+ c" G! J8 t
root diameter齿根圆直径7 Q& D3 k5 D& t( c6 g# ^  ]. x
base circle diameter基圆直径* }& N% m" j& e, Q
whole depth全齿高" ^2 U( A3 ~6 I# \, R& \. q$ ^- y
normal circular tooth thickness (at reference circle)法向弧齿厚(在分度圆上)
$ f! S! @: I: k: R% Kroot type齿根形式
7 d: f, F, |& |9 yroot fillet radius 齿根圆角半径
% M, F/ M4 P) `0 K* w, Glead crown齿向鼓形
2 ~# |, N7 o7 y8 C' b" P4 O1 w! K: T" ZHOB DATA滚刀参数
9 P' }7 h( |7 h" Y. Upressure angle压力角
8 A* O; f1 k/ [0 Z4 {tooth thickness at reference line分圆齿厚
0 P. R' H  w7 ~: S# Z* l! Qprotuberance凸角5 F( i' ?* ~; Z% j% Y! V5 K( ?" j
tip radius齿顶圆半径  g' w  ~( z- T% f8 ?
reference part number 零件号
2 x$ z. \# o- a* f- H8 i7 \  YINSPECTION DATA检验数据# n; e( S3 m; m9 m. {
: Z( c2 C7 }" {5 E1 ]* c# N2 M/ N
profile tolerance and modifications齿形公差和修形& h5 \1 o) t; }2 J) X0 P
profile hollow齿形中凹
. y) M7 K# v0 L. @0 ]7 q3 ]refernce pitch circle runout节圆跳动
; m9 n( y0 r" e' }  ]% K* apitch variation齿距偏差1 S7 j0 b& p7 P: }3 P9 `
lead variation齿向偏差8 R5 m3 F6 _4 o
lead hollow齿向中凹
0 i) E7 ]% ^) i. J; f. Qprofile surface finish渐开线齿面精加工
+ c9 \0 O5 [: G0 ~ball diameter量球直径
+ X) i/ c7 b% T1 S7 }) ldimension over two balls in same plane跨棒距5 i1 @; a0 E# w# y
REFERENCE DATA-MATING GEAR对啮齿的参考参数
0 S0 I% F! p& K- B, b3 m5 ~, W; ?1 e
normal center distance 中心距& e+ @1 H& T+ @6 J2 P
mating gear part number对啮齿轮零件号
9 a- r/ M' I5 n: r1 L& W" S; \mumber of teeth on mating gear对啮轮齿数7 D; }1 U3 x0 B+ r5 _9 e
backlash (nominal CD ,ROOM TEMP)侧隙
0 R% M: Q8 w, \. y! X# [4 v7 [+ D) g
5 w: `- ?: c5 Q9 W2 A" U& b  g9 y3 J! D' W
本翻译转自zhengchangw   在这里向表示感谢!为了服务千万需求者  特此贴出来
' `( y- N' k  l2 q/ N$ [' J5 n" [3 H/ k1 j
希望浏览本翻译的 对zhengchangw 都有一份感激之心: i7 ]' N+ ?, I( {: B) l* t# Q: M
谢谢
发表于 2008-1-29 14:17:50 | 显示全部楼层 来自: 中国江苏常州
tooth form(齿面)?不是齿形?
发表于 2008-7-12 16:40:43 | 显示全部楼层 来自: 德国
Thanks
Thanks for your kind share.
发表于 2008-9-18 11:04:31 | 显示全部楼层 来自: 中国江苏常州
学习是光荣的
发表于 2009-11-1 05:44:50 | 显示全部楼层 来自: 中国
谢了!!!!!!!!!!!!!!!!11
