这个是我用NC辅助分析拔摸角以后的结果, P0 S" L( R1 \. _. p( G0 u
; R0 v3 {) K# g6 y& o8 I+ `; B- e
5 O) Z+ @4 g4 w- |% y/ j c NC Assistant - Analysis Results
1 n* `# D! A; \: r
9 T: H5 I) R# D0 @------------------------------------------------------------2 `& W0 u$ Y6 d( c" |
* ^8 F3 q' `: k$ D% a
信息单位 毫米2 |3 N _8 _3 K+ k- M; N
' t" r. M" ~' i6 ~7 {: K W分析类型 Draft Angles
9 ~7 \! M7 ?" g* O+ M7 H$ g0 _距离公差 = 0.010000000
$ F+ B% a) R" \! M- Z$ o角度公差 = 0.010000000 V1 S% N z+ m
最小值 = -100.0000000001 p$ _* R5 p& m2 D* Z( E% E( n
最大值 = 100.000000000+ V$ U- j1 _" p; ?8 x
) D# _: }# t5 b Color Number of faces Angle
5 \7 d0 @' G: P t* I; C4 X4 f8 U------------------------------------------------------------
5 l# U U; U) l4 p9 Q# RColor Set No. : 1
3 e) J6 P* W* Y( C- o: N------------------------------------------------------------- J) K! ^2 U9 _% \: A: L: Y6 S
1 (白) 727 x' M1 r& J1 a: i8 n4 F
= -90.000000000
4 _$ t% w( H4 x2 (Pale Weak Yellow) 20 G5 ?; u# A* Z3 [0 d, Z* }
= -85.030259272
. h4 s4 ]5 P8 f0 ]4 X4 p3 (Pale Dull Yellow) 2
# t- {) U8 u0 Q = -80.788973459
?! w5 ]' W& k4 (Light Faded Yellow) 4; j8 r" X- J- d8 d6 W
= -80.472716619
+ Q6 j# v4 v6 T3 \5 (Light Hard Yellow) 4
% g5 m% I3 f$ _: }! {) S = -72.972792665
3 Q0 \# i: ^: G$ d6 (黄) 10
9 g$ N0 s, Q+ Y* l- y = -59.000000000 D& m, Q+ l5 r( k
7 (Pale Weak Cyan) 4; R! q- X* s4 R' Y3 L* X& Y; A
= -54.000000000% E& W0 I$ D' Y' g( z4 @
8 (Pale Weak Green) 10
0 @& e' r8 d3 b& L" h9 K6 N, h = -45.000000000
& c- e! i k$ ?& [3 R! J H0 e* M9 (Pale Dull Spring) 69 |, h9 L% W- f+ G7 x9 [. T+ Q: N2 J
= -35.264389683' C7 A9 T# x$ ^4 w9 [7 t3 ?7 ~
10 (Light Spring Yellow) 4
- a5 a5 V m! g; w7 I' t4 K1 w) H( R* C = -30.999975142/ A( O; G5 p2 B" t$ ^5 O% E
11 (Light Yellow Spring) 2
. G( h) y& b- i = -30.023391258$ g# m4 w: S$ r+ }% Y6 H
12 (Yellow Yellow Spring) 2- J; c$ G4 [$ s% _' q
= -6.141110617% ?6 O1 R6 C- j( M# I
13 (Pale Dull Cyan) 4; }4 |" O6 `# u& W d J, e: B
= 0.035462196* P4 `2 Q2 d# _' V( ^
14 (Pale Dull Teal) 4
" I' m2 ~9 R9 S, Z = 5.000000000
% w6 p3 R M* O------------------------------------------------------------3 i: k% i* q. e7 G1 |1 S2 A: [; u
Color Set No. : 2: P8 p" b# m7 f4 j* [, E+ G
------------------------------------------------------------& Q! w8 p, i2 A; m
1 (白) 2/ I m) b1 a3 ]
= 29.6327383396 H+ B" N" s& e2 B2 }
2 (Pale Weak Yellow) 2- ~" V; I& e$ C% W
= 30.999496619 w B* N* J$ N! F
3 (Pale Dull Yellow) 6
* w2 o' Y. P s% I0 Y = 35.264389683% g' N# ?" v# ^
4 (Light Faded Yellow) 20
. R/ _2 D' Z7 e$ s' c- D = 44.999820951 B$ i J, z7 u% w( v$ b0 M( q
5 (Light Hard Yellow) 165 U9 E8 b. W. ]+ R! Y; ^! k* ^! S; e5 l
= 54.000000000! W, `# c2 ]8 N# k9 ^
6 (黄) 4
6 A2 E' ?* F$ A& p# X5 B6 T = 59.000000000
; {% y1 M, f$ v, v) F( Y5 f2 R$ Z+ @" `7 (Pale Weak Cyan) 49 ^" R5 q! o9 S3 n$ S) ~
= 73.909183651
5 o! b+ z% Q1 L- m3 Q* n0 l c8 (Pale Weak Green) 2
8 i( ?. c! h- k- h6 x = 77.719045595
2 z( `4 m# r8 S% u# v- M9 (Pale Dull Spring) 2
9 l+ v: c8 e; |; Y2 ^8 X) a% m = 82.874983651. O: Y# f% z; f
10 (Light Spring Yellow) 70/ s6 J# Q. h& v5 ^3 p
= 90.000000000; X! m% ^ n2 }& O- a2 C1 l
2 D4 \- i' x1 C, L, q6 x' C$ j/ ?! H+ b5 R/ N* ?
有的是中文。有的是英文。我的是3.0请问,怎么全部变成中文的。谢谢 以便更好的区分 |
