查看: 1266|回复: 2
[求助] 请教这个规格的具体内容
发表于 2008-2-15 11:27:15 | 显示全部楼层 |阅读模式 来自: 中国江苏无锡
Conforms to Federal Specification GGG-C-771d   这个是美国的规格标准   请问有谁知道呀    6 [5 [2 k+ H0 u- E* I
是拉码的  有谁做过拉码之类的东西么  ?知道这个规格的具体内容不?
发表于 2008-2-15 11:56:19 | 显示全部楼层 来自: 中国北京
切管器
http://www.newmantools.com/imperial/206-FB.gif
Product #: IMP.206-FB
Product Name: ADJUST-O-MATIC TUBE CUTTERS
Description: Adjust-O-Matic® satin nickel finish chrome plated tube cutter for tubing from 3/8" to 2-5/8" (10-66mm) O.D. tubing.8 Z! H* S9 }$ V  D" n8 g8 c; {
% @+ U1 e  P5 H; n) tRatchet feed mechanism speeds up cutting operation - opens quickly to insert tubing, slides to cutting position instantly, fine feed adjustment for cutting action. Extra wide rollers with flare cut-off groove stabilizes tubing. Spare cutting wheel included under handle cap. Enclosed screw - type feed mechanism; light weight aluminum alloy body.1 f" x3 a! Y1 i: l7 l& F
1 d$ y2 U: }! T! w5 D4 \
Conforms to Federal Specification GGG-C-771d, Type II, Class IConforms to Federal Specification GGG-C-771d, Type II, Class I
 楼主| 发表于 2008-2-15 12:00:45 | 显示全部楼层 来自: 中国江苏无锡
% c6 _0 m2 k6 J0 O0 d/ {我是想知道这个规格的具体标准    GGG-C-771d
