发表于 2008-2-15 16:18:32
来自: 中国安徽芜湖
化学成分和材料对照表A 576 1020 对应GB 20
' I: l; [7 [* ~0 Q5 S" h0 \
" B( X; ]0 ~- L" e6 N8 h9 `+ \3 Z
/ e( ] Z3 F: ~, c7 C' d
f% r( Q, O z, Q" j$ U7 w& U, C5 }" l4 x2 K0 k) G+ @
化学成分和材料对照表A 576 1020 对应GB 20 " D) | j1 B g! A, y. w' q' x
| | [table] | | 材料牌号: | A 576 1020 | | 标准: | ASTM | | 国家与地区: | USA | | 钢组: | 结构钢 | | 次级类别: | ASTM A 576 Hot-wrought special quality carbon steel bars | | 注释: | Bars shall be hot-wrought and shall normally be delivered as manufactured. |
+ H/ t m$ U9 ]3 z# [! l | | | http://www.key-to-steel.com/cn/img/nav/spacer.gif | http://www.key-to-steel.com/cn/img/nav/spacer.gif
$ T: w: u2 N" s) B. a, q2 w化学成分 (%)7 J0 P7 t/ n4 U1 i }
| http://www.key-to-steel.com/cn/img/nav/spacer.gif" F. ?) g7 n: g/ b4 H) W5 d
[table=98%] | | 元素 | 最小 | 最大 | 近似的 | | C | 0.1800 | 0.2300 |
' k! R; W- d+ S; O* \, | _ | | Si (*) | 1 T$ I3 O, t/ h. u
| $ A6 m& V. U* M# @& r% t
| * s+ C0 `4 D K
| | Mn | 0.3000 | 0.6000 |
! H% C" Z9 X& e( n4 n& O | | P | ) a2 Q( v ]2 V% v0 \
| 0.0400 |
/ B( D# w5 h o9 C | | S |
, V. H& p/ i5 @7 Z | 0.0500 | ' `9 S" _. H* y4 C2 V
| | B (*) |
; a) x o `" _# @* t& R; I( H | % e6 a5 g3 h) U! B& z/ f( w
| 0 n% G# U. E% ]" b4 @9 s; W: {
| | Cu (*) | 0.2000 | ; G' c! Z, p# C. n Z( Z) o( |9 K
| . Q( T6 |3 v! S% p
| | Pb (*) | " x2 n: |- C/ w- `
| 3 L4 \8 R- \9 y2 E7 B
& E, W- r2 p* D/ r; L6 P/ B/ e | | Other (*) |
# U8 i+ }7 p7 Y- B+ ~ |
' ~" y: y4 Q6 D' @* ?8 k; k | M$ R1 P2 N) w% H* K& A, P
| ; { `# n* w* m6 \' X7 @5 _
http://www.key-to-steel.com/cn/img/nav/spacer.gif0 F7 \- r- B* R1 Q- r
| 元素 | 注释 | | Si | Where silicon is required the following ranges and limits are commonly specified: Si=max 0.10%; Si=0.10-0.20%; Si=0.15-0.35%; Si=0.20-0.40%; | | B | When boron treatment is specified for killed steels than B=0.0005-0.003% | | Cu | When specified | | Pb | If required, the lead content can be specified Pb=0.15-0.35%. | | Other | The elements bismuth, calcium, and tellurium may be added as agreed upon between purchaser and supplier. |
' W8 R4 z% J* O! K; }% z% x |
! a) } G3 q1 O* L3 ~3 C' j) n2 D# D |
! R) C; N7 P% a1 i3 c y- Y' \
: s7 ?. Z8 J! l, l. P+ r! K1 B| 材料牌号: | 20 | | 标准: | GB | | 国家与地区: | China | | 钢组: | 结构钢 | | 次级类别: | GB 6479 Seamless steel tubes for high-pressure for chemical fertilizer equipments |
/ r }! @& e7 G* S& ? y" y/ B9 q# g: f1 s2 f% X. _; i+ B1 \ I
化学成分 (%)8 l% ?% L+ P! V/ r6 c
( ]2 P. D( [4 || 元素 | 最小 | 最大 | 近似的 | | C (*) | 0.1700 | 0.2400 | , a: X; Q7 D% D. U
| | Si | 0.1700 | 0.3700 | 1 W8 S3 k7 j3 q
| | Mn | 0.3500 | 0.6500 | " u; i& x. T3 y2 K, N' w* n
| | P |
1 ^7 D: v: U/ M7 @& j | 0.0300 | 3 `7 Y4 X- M( \* X6 N& Q1 m
| | S | ) N% v7 |1 ?. A
| 0.0300 | 3 B+ Y Q- Z# y8 Z, g8 r
| | Cr |
4 `. J+ V; E- Y8 x' c# b% T | 0.2500 | 1 b; j0 {. n) l1 Y. ?
| | Mo | : r [5 ` N, z3 }& F+ W
| 0.1500 |
! F- O5 o/ V8 a/ {* O4 p | | Ni | : H4 I# A! r; t2 z2 y
| 0.2500 |
3 b1 ^ D+ m' b. v4 r- j9 W/ _ | | V |
: U( |7 a, z) r z: ?( G8 M | 0.0800 |
$ H& R0 A* G, F. D6 R | | Cu | : T1 U4 v( X* o5 B- u# @( G: t% b
| 0.2000 | " ^! {( [3 ?: b1 p# M3 t$ A, r
| | N (*) |
6 L% k" v1 [- h) m$ b& x | 0.0080 |
/ H% X2 Y0 o# I/ I |
s; z! V; m9 W/ z( b) }- q4 D/ i9 `http://www.key-to-steel.com/cn/img/nav/spacer.gif' J* s+ T, ^" R# s+ E: D$ ^
| 元素 | 注释 | | C | When requested by the purchaser and specified in the contract, for steel used at low temperature, carbon content may be 0.17-0.22% | | N | For steels smelted in the basic oxygen furnace. |
7 |6 }- x _0 i. _. c. u6 e) T* i0 m3 x9 | q
[ 本帖最后由 hourpp 于 2008-2-16 08:14 编辑 ] |
