2021-06-25
查看: 1278|回复: 1
[讨论] 关于特征操作
发表于 2008-2-20 10:14:58 | 显示全部楼层 |阅读模式 来自: 中国黑龙江佳木斯
3 ^; f8 _; m+ k9 G5 }3 Z# LResolve Feature Overview! X: I1 f" \" k) L
**************************************2 d- W. X8 V' O' |. o& s  c7 i
3 c  N% i+ M5 j! O. c  W( f& H
* Undo Changes undoes all changes made since the last successful
- b1 T; _6 L) [5 y5 w( z, y  regeneration.
5 C+ Y: O0 y/ L! E. r! b6 y- O- A- J8 F: h  G+ K/ O
* Investigate provides tools for failure diagnosis and model information.
- }% H+ Q' m7 d) b, L/ i3 G' \- q: v8 |8 {9 |- c% C9 G. M9 R5 x
* Fix Model provides part or assembly functionality for model resolution.
& G: R, {; |* U9 T* S1 [  Included are the Feature/Component, Modify, Restore (to return dimensions,
& C( s% A5 A/ a  b& b  relations, and parameters to previous values), Relations, and Set Up menus.
% N& d% I/ f& l  x0 |  l# a+ _, P  P6 O, c; r+ ]; i
* Quick Fix provides short cuts for performing standard operations on the  t: W8 H% ^- i3 g2 N& G
  failed object.  Available actions are Redefine, Reroute, Suppress (for
; Q1 W  ]3 D: A* [  parts), Freeze (for assemblies).# j; d# ^0 z! E- @  r* E: y
2 z% L" K* P) M8 q3 |: P; x
( C' Q, b: B  E. f5 ^4 m' F6 h; V! XUsing the Current and Backup Models
' w2 Y5 k0 I! `- j+ p' H**************************************
7 p7 ^! b% J1 G1 E6 W# L* P1 |1 W, Z& k3 _
When model regeneration fails, all features after the failure remain
- k2 E7 n  ?5 u- qunregenerated. The current model shows only the regenerated features (the) g, m) h1 ?. ?- V2 W. i, d$ r( W
failed feature and all subsequent features are not displayed).
) {6 c6 H; e7 k: [9 Z7 t8 ^& j# t# g8 {( M* J/ B  S# N: ^
The backup model shows all features in their pre_regenerated state. It can/ Q, b; X: t# t8 E$ N2 ^: j
be used to modify or restore dimensions of features that are not displayed7 J# c" l* l: D$ g
in the current model.
  Q2 w, D- ~/ A5 _) e/ R$ a4 ?. s1 I. w. {
A backup model can be regenerated in two ways.
: J* z$ K! T2 l! o" D# ^$ M
2 L: K! u* p- m9 S; \% m 1) If Regen Backup is selected in the Environment menu, a copy of the model
6 p( z7 `: |, D% u3 Q/ x(regen_backup_model####.prt) will be saved to disk prior to each 3 s- B  B# w- e; u) P) B9 D
regeneration and removed upon exiting Resolve Feature mode.
, r+ Y& y! u9 M9 U/ ^( C 2) If Regen Backup is not set the most recent saved version of the model6 G, S: X+ @  p  @
(if it exists) will be used.
发表于 2008-2-20 10:24:55 | 显示全部楼层 来自: 中国江苏扬州
是楼主改变了某个特征的参数,导致模型从新生成时出错。可以重新设置参数,或者恢复之前的模型
