查看: 1102|回复: 0
[分享] The Behavior of Structures Composed of Composite Materials
发表于 2008-2-22 23:29:28 | 显示全部楼层 |阅读模式 来自: 中国云南红河哈尼族彝族自治州
The Behavior of$ H# B, V$ D- ~/ |2 W: u
- {1 o9 }/ d! z* M' x6 w4 R7 NComposite Materials
; m& h* |+ s: a0 }  o; M; KSecond Edition& G  t" f- g2 v* P( M
by5 S+ B* h; w$ q# |0 G6 a( a3 a3 z+ ^
JACK R. VINSON& L6 O% r: M5 B. j  e. D
H. Fletcher Brown Porfessor of Mechanical & Aerospace Engineering,# w* L3 g. H  [
The Center for Composite Materials and The College of Marine Studies,) t; @4 }. Y  F& E: k' j. p$ a
Department of Mechanical Engineering,
6 ^% i; ?. ~& c! a- i5 p" h7 C- SUniversity of Delaware,
& o+ _& ]) [% u& r2 S) N) u. |Newark, Delaware, U.S.A." {0 L$ @$ ?) q) `0 M+ i
and& ]9 O0 p3 I6 T3 d4 G. c* e" T7 m% R5 p
ROBERT L. SIERAKOWSKI
2 R4 t* p2 ?* h! qChief Scientist,2 Q2 I0 C+ X* ~
AFRL/MN Eglin AFB,% b, X5 R- T' G/ ~  f
Florida, U.S.A.1 g3 F* |. y! i. g' ?' L! P
7 u) Q4 D- D8 G/ O. J
1 l9 I; Z6 y) ]4 E% r% W$ o1 l
2 Q9 W1 J) ?% H  A8 \* rContents- G3 Z- B$ q$ o* P9 s+ t' `
1 m- y; m8 Y9 c3 u+ W# c  h
1. Introduction to Composite Materials 1
# g3 h6 j7 }( P& H  H
) K2 T3 x  J0 E) H6 t, E$ {General History
# Q  A6 P3 o; `# nComposite Material Description
2 Y. a8 Q+ ~, ~( w/ GTypes of Composite Materials
) E' G, k( A6 C. O4 t# V7 p0 Y; [Constituent Properties
) p1 b3 E4 o* {# H5 mComposite Manufacturing, Fabrication and Processing) W4 V' U2 _2 ~: ]/ T: c# @/ k
Uses of Composite Materials. ~1 j4 E5 t) C) p, c- ?: k! r, l# f
Design and Analyses with Composite Materials/ E; n2 o0 ?2 U: ?; E. ?  t! }9 z2 x
References- E' a; i7 Q) q+ X2 A8 s
Journals
0 u- M( e9 k( x9 W" Q% rProblems& L; ~4 g- a; X- J! X3 x: i9 o
3 ^3 Z$ W! j- A# f1 r2. Anisotropic Elasticity and Composite Laminate Theory, c# y+ m* G5 q  _
" Q9 |! u8 p1 t. i
Introduction
" M/ n# T7 L, C) n# kDerivation of the Anisotropic Elastic Stiffness and Compliance Matrices
4 ]9 j2 E; V7 |6 w/ d8 _; |+ H# U7 PThe Physical Meaning of the Components of the Orthotropic Elasticity
, B8 A0 \% C/ o% @Tensor# z# k) c. p  p
Methods to Obtain Composite Elastic Properties from Fiber and Matrix
* ~5 x2 {, F0 |Properties
! B/ _2 J( C/ ^# H6 gThermal and Hygrothermal Considerations5 Q7 g: K' b, Z: c& ?/ o& i* U/ i# ?
Time-Temperature Effects on Composite Materials
4 z5 [6 _5 C# b" A- B7 y6 oHigh Strain Rate Effects on Material Properties
2 }! g9 B. ~' J+ pLaminae of Composite Materials6 s* J/ i7 g/ f7 W% D* ]
Laminate Analyses! J1 [. ^  E, k; k8 q
Piezoelectric Effects
# H' C4 q7 K" O% U1 `3 _7 lReferences
, v& ~( E" `- ~. D% EProblems. w, p5 U; d0 I* }! {2 ^( B  J5 J8 A
1 o6 e. k$ u% @7 N
3. Plates and Panels of Composite Materials2 \  b/ q4 p' c# B( ^* n
7 K* x6 Y4 W' l! i" z) v0 R( v  K- AIntroduction% M, }; C) e3 u
Plate Equilibrium Equations
* R7 J, \  L! [' m  Q" d- G8 LThe Bending of Composite Material Laminated Plates: Classical Theory  {( F( n7 V1 q0 `
Classical Plate Theory Boundary Conditions+ ^" [! p" L# B% {8 e
Navier Solutions for Rectangular Composite Material Plates
, s. @- }. @' f. wNavier Solution for a Uniformly Loaded Simply Supported Plate – An
' U9 n/ ?( ^# B% n9 h7 a) vExample Problem
6 k, z( E' X7 A" mLevy Solution for Plates of Composite Materials( X$ P5 l6 q' B! }/ _( j' W
' f2 ?0 X& a7 a0 Z. ?, P2 k
Perturbation Solutions for the Bending of a Composite Material Plate With
) F- T3 K3 a. h+ s0 w* ^& V. w( \Mid-Plane Symmetry and No Bending-Twisting Coupling
; y, S* A2 _: Q$ f1 f3 fQuasi-Isotropic Composite Panels Subjected to a Uniform Lateral Load
% [1 r* ^0 q3 O# w2 K5 kA Static Analysis of Composite Material Panels Including Transverse
# b# ~# }+ ]* ?9 g3 ?- `' b; AShear Deformation Effects# e' e' O3 x6 e8 v0 E
Boundary Conditions for a Plate Using the Refined Plate Theory Which
- W4 ^2 r2 R% _7 `* Q! jIncludes Transverse Shear Deformation
) j0 W$ S. A1 ~! C2 HComposite Plates on an Elastic Foundation
1 E6 Y9 J4 Q4 sSolutions for Plates of Composite Materials Including Transverse-Shear
* X7 N7 E! X( ]% J3 j9 i- r4 HDeformation Effects, Simply Supported on All Four Edges
/ k5 ]" {5 u: E, k, r2 V  p' dDynamic Effects on Panels of Composite Materials* q3 `: U$ K' h. }1 s3 E' d
Natural Flexural Vibrations of Rectangular Plates: Classical Theory
/ s2 u2 k& r7 I9 y1 b# N& BNatural Flexural Vibrations of Composite Material Plate Including
9 i4 F5 E  j: x2 O$ R; D3 Z. PTransverse-Shear Deformation Effects
' \( m0 i9 F6 |9 Y1 n; ?Forced-Vibration Response of a Composite Material Plate Subjected to a/ p1 ^; L6 W" R$ G
Dynamic Lateral Load
$ [6 Q5 q, r" c% f6 o$ QBuckling of a Rectangular Composite Material Plate – Classical Theory
3 Q8 ?  j4 {% F& SBuckling of a Composite Material Plate Including Transverse-Shear
9 ]$ ~% {; ]2 NDeformation Effects* [" q# e( N/ H8 m
Some Remarks on Composite Structures
) g( A- Y0 J. D+ c  {' Q* M$ \Methods of Analysis for Sandwich Panels With Composite Material9 Q5 Y& q- y" F; }
Faces, and Their Structural Optimization' V+ B* ]2 y$ v3 `2 ]! E
Governing Equations for a Composite Material Plate With Mid-Plane4 F7 E% p. J4 |2 O5 p$ n  g& I
Asymmetry
3 C6 ~& j5 a" |' v$ uGoverning Equations for a Composite Material Plate With Bending-
) ~* D: u# |1 T+ x, y6 \2 KTwisting Coupling
( P. ~! M& v0 d/ ~% LConcluding Remarks& I6 r# Q1 Z3 h) j0 Z* c+ o; l8 H, k  s
References4 q4 P. W( C" K$ U  Z# e( W. A
Problems and Exercises
" S% f, P) y+ ]9 w. s( X; _' y  _0 ~; e/ y" X7 l1 B0 c
% I9 D% O0 p; G8 T) C* e$ R, ?, x8 x4. Beams, Columns and Rods of Composite Materials
) k4 H* H' v8 k, m7 Y. r/ u9 ^* Q1 L& G: g/ `( d
Development of Classical Beam Theory
- ^: _/ V: P/ N+ qSome Composite Beam Solutions
4 O3 W7 }; |0 a1 J) M6 F! QComposite Beams With Abrupt Changes in Geometry or Load
% w$ ~& a0 x- e7 @$ ?- lSolutions by Green’s Functions
' \/ q# N$ C+ ]" w/ O) ?( jComposite Beams of Continuously Varying Cross-Section
' G" x/ `8 \/ N- e( d( D. p: p4 XRods
* P1 M/ L( `. UVibration of Composite Beams
" x7 `5 n/ ]9 a( [Beams With Mid-Plane Asymmetry$ h$ W/ d/ F; p. N4 L+ x
Advanced Beam Theory for Dynamic Loading Including Mid-Plane
6 K/ J% M# s. y, T0 ^" U% DAsymmetry% X2 }# R4 F, _( w; X
Advanced Beam Theory Including Transverse Shear Deformation Effects
9 {' x* c; g9 S, n; \2 {Buckling of Composite Columns
) {0 k( I- u8 G: pReferences
$ O' B8 {& h" S3 j+ {9 DProblems' i" }# O, ~  K. M9 f. G" g; x. S
, U6 b  Y% g" Q9 `, i* v4 J
$ ^) J- j% E* q8 m8 i) p. g5. Composite Material Shells. w; m  r$ r/ v* Z6 W
( c8 P/ L+ j. W! _Introduction* f4 F, F# n! U" }0 Q5 j
Analysis of Composite Material Circular Cylindrical Shells5 H- k  P" j2 W- J5 }6 @# _
Some Edge Load and Particular Solutions* x3 L$ E3 I! |1 J2 F6 S
A General Solution for Composite Cylindrical Shells Under Axially
# v% r# c/ v) n) aSymmetric Loads) m( k0 C! {, v  a5 Q; ?
Response of a Long Axi-Symmetric Laminated Composite Shell to an% i- ?0 Y' F" J8 E1 `& s7 u% Z: _, z: F" x
Edge Displacement
: u4 U. R" u9 g8 s% n$ o' Z4 f, X/ DSample Solutions; W: U) L" A( x1 m: E
Mid-Plane Asymmetric Circular Cylindrical Shells
% V0 m) g0 \  P. d5 L. R" N/ TBuckling of Circular Cylindrical Shells of Composite Materials Subjected  d& x" Y7 f( r: |8 o& o1 V2 L" T
to Various Loads
8 v8 [* |& w, ?' v% ?Vibrations of Composite Shells
, D4 L! H3 i4 _# U- ?% V! [Additional Reading On Composite Shells
6 j5 ]7 e/ H6 tReferences
/ P; w- M4 s" `! F$ J, gProblems$ s1 q# w6 c* f! w" x  u! ^
: N- P  H+ M$ W/ \6 m0 j* E
5 s; ^8 w- U: R6. Energy Methods For Composite Material Structures
! O+ |1 l: k* G6 x+ y' N8 B% U' n0 u# @( ^. c4 w5 y9 Q
Introduction8 h$ ]3 B; e2 w& x4 \
Theorem of Minimum Potential Energy% f* n7 m  V  L
Analysis of a Beam Using the Theorem of Minimum Potential Energy* M# I4 E& |4 [" W9 G- o" C
Use of Minimum Potential Energy for Designing a Composite Electrical9 \  {* M& }$ J1 a: e" t
Transmission Tower
8 M9 c) q+ U" }3 U  W1 P. NMinimum Potential Energy for Rectangular Plates- y3 @: U* }. ^5 n' h9 W5 ^/ K& J
A Rectangular Composite Material Plate Subjected to Lateral and* \2 I$ q* Q; ?& B
Hygrothermal Loads
; R) M" Q, ^4 X! F5 v  R: rIn-Plane Shear Strength Determination of Composite Materials in* B4 r8 F9 S9 `, u5 X" `
Laminated Composite Panels2 l3 T% j- w( p6 L4 D$ k
Use of the Theorem of Minimum Potential Energy to Determine Buckling
* c6 G7 [. E  A- Y, u; a  cLoads in Composite Plates
- ~4 y3 ~1 X1 H5 DTrial Functions for Various Boundary Conditions for Composite Material
4 R( a! _4 |; o2 D; fRectangular Plates& @% D0 y6 W$ Q: v; I. n
Reissner’s Variational Theorem and its Applications$ F7 |1 ^+ S  U3 a) k. P
Static Deformation of Moderately Thick Beams
* ]1 V8 i- i% U6 p9 u1 f2 e. P# kFlexural Vibrations of Moderately Thick Beams
  {  h6 n/ V: B( P& t( T% B1 iFlexural Natural Frequencies of a Simply Supported Beam Including3 V  s% B/ F  Q5 I
Transverse Shear Deformation and Rotatory Inertia Effects
" ~3 W  X9 Y& E. l: oReferences+ N$ r; ]3 S7 A# D+ Z) n. v
Problems
: W8 O! L" b, {/ i9 N
7 d0 D0 e4 z- U9 G7. Strength and Failure Theories
. f9 Y! _# _/ A  ~6 {$ C( {
8 y, x& r+ @" e0 yIntroduction' {  y, o+ y; E
Failure of Monolithic Isotropic Materials
( _" p3 I5 W" c2 X  `6 X5 S" [Anisotropic Strength and Failure Theories. Y1 C, I7 C# _3 R& a
Maximum Stress Theory3 X  C) x$ }0 G/ [  b% Q
Maximum Strain Theory
8 t/ d. ]) j7 a( g8 u) L9 gInteractive Failure Theories
# z: D& I* z* f1 M5 XLamina Strength Theories
! B  A2 B, r0 Z0 |$ {8 H- `Laminate Strength Analysis9 O. I" @4 V7 B* x  t# p
References
# q. c" E+ H2 B/ ZProblems" ~. I; A5 P8 g$ y) u+ O
) i2 _# E! u7 T$ v
& n8 N9 n5 c; b+ p4 N8. Joining of Composite Material Structures
# r- n& H# n3 G$ N
2 w2 X5 Y: G4 o! b( x' ?6 yGeneral Remarks- V' p* o' K0 g/ G5 I7 Z
Adhesive Bonding
0 S# e* l2 ?# x/ K2 mMechanical Fastening) g9 H/ C8 V. N$ Z$ q
Recommended Reading
7 j2 z( l" u& t! `! ?0 T! B) }References+ i6 [  L0 o- V, F8 l' U
Problems
6 S" @/ [/ N, g* ~4 B  |/ L( [/ ]7 H2 f9 Z* W% Z
3 k& O+ H4 |. G5 R0 j9. Introduction to Composite Design
6 s$ a; y" x$ K! A$ m7 m. K. A$ w7 j8 \( T
Introduction
/ m5 ]# y' F0 [4 z& Z" W  vStructural Composite Design Procedures6 F' ~' o6 [7 B/ S7 x6 Z
Engineering Analysis# s% q+ V) W: r0 ~0 w# M: q
Appendices) u# A# Q$ F6 O7 d! n6 Y7 e
6 E# D4 k4 w/ |; ?( ^
0 w# L5 f& t  _; V" H( C" }Micromechanics
3 y* n# V- i; q* YTest Standards for Polymer Matrix Composites2 C9 `2 f/ B# t5 Q# S: Q0 P
Properties of Various Polymer Composites" r2 y+ O- a6 Z* n( v& j
Author Index$ j) |# g' x% a, P
Subject Index. Z$ q* i0 V* j6 z" q
* v1 n# G* K4 k4 |
[ 本帖最后由 jove20020 于 2008-2-22 23:41 编辑 ]
The Behavior of Structures Composed of Composite Materials.part01.rar
1.91 MB, 下载次数: 8
The Behavior of Structures Composed of Composite Materials.part02.rar
1.91 MB, 下载次数: 8
The Behavior of Structures Composed of Composite Materials.part03.rar
1.91 MB, 下载次数: 6
The Behavior of Structures Composed of Composite Materials.part04.rar
1.91 MB, 下载次数: 7
The Behavior of Structures Composed of Composite Materials.part05.rar
1.91 MB, 下载次数: 7
The Behavior of Structures Composed of Composite Materials.part06.rar
1.91 MB, 下载次数: 7
The Behavior of Structures Composed of Composite Materials.part07.rar
1.91 MB, 下载次数: 7
The Behavior of Structures Composed of Composite Materials.part08.rar
1.91 MB, 下载次数: 7
The Behavior of Structures Composed of Composite Materials.part09.rar
1.91 MB, 下载次数: 7
The Behavior of Structures Composed of Composite Materials.part10.rar
1.02 MB, 下载次数: 7
参与人数 1三维币 +10 收起 理由
1135026 + 10 好资料,感谢对论坛的支持!
