楼主 |
发表于 2008-3-4 21:59:19
来自: 中国四川成都
下面是 www.tcfonts.com 主页的内容:
0 j% M9 r7 d' |% e" s
: p1 |( ]: N8 N& rQuestions or Comments? Contact TC Fonts.
+ e7 n1 z7 W0 VConverts TrueType (TTF) to: Filled/Outline AutoCAD SHX Fonts
! L/ Y6 U! E8 `) {; [9 xArc-based DXF Files (not a series of lines)
2 R; Y1 y& x, Y) }9 ^/ ~3 @ {Generic CADD FNT Fonts
* }% p3 r3 Z% U0 m+ j CVisualCADD VCF Fonts : Z& K6 R2 w, |( e5 y* \
Fonts don't have to be installed - convert fonts even from a CD.
3 y3 f. r" X' ^4 @0 P, ^+ ^* pRuns in a batch mode - convert one or hundreds at a time.
$ r0 L8 z* e) kSpecify which characters to output to DXF or the entire character set.
1 G/ ^* {$ R- E) a3 a v1 `/ c# ](FONTasm will not convert SHX fonts to Truetype - see Font Services below.)
, K% |! ~4 `) c9 B8 z) X% n, HOnly $95
! r# m+ b/ P* G5 XClick to Request Feature Restricted Demo 1 X* w0 a) e! q# U/ y; s E$ h
(program/demo are delivered via email by the developer, G. Gibson & Assoc.)
3 F* `4 ?/ i, K. V! j3 k- y" _Demo Output Files:Filled SHX Font Outline SHX Font DXF File) B1 t5 B8 j: T( x; \' a
8 c; c5 S d1 o( p
FONTasm! Ordering R5 ^7 w) d z( V( b$ f
FONTasm! v2.0 Qty:
6 n% W6 T! p8 \, P1 v9 c! D5 X. t/ W) j! ~
guthrie SHXConvert v3.0 – SHX Font Utilities
0 R# z( Y& Z% V# c& P0 k( A0 f- c+ w
guthrieCAD::GIS Software4 _ t$ l2 `4 R- k: S' u; m' O. `
0 A( r4 Y9 y' o
' q2 k4 [4 h2 }. dSHXConvert is a standalone utility for compiling, decompiling, converting, and exploding AutoCAD SHX Font/Shape files.
, Z, E9 x4 } j, ?% WThe 5 basic modes are:
) G4 M( A/ H; J7 k. H( v? Compile (SHP to SHX)! N! N9 l# K3 E& q, E+ ]
? Decompile (SHX to SHP)- d" D: p# y8 }
? Explode (SHP/SHX to ASCII DAT)
# Q6 E0 a6 q: A! q7 j- F) S? Convert (SHP/SHX to DXF/DWG)" |+ g: I& h% `+ Z9 |" P
? Replace (SHX in DXF/DWG to DXF/DWG)
* v6 p" Y+ F3 D/ ~+ \New Version 4!8 D6 b) a2 v$ V/ b3 ?8 y; H
? Supports reading of AutoCAD 2004/2005/2006 drawings2 ]( J# b& D4 O0 B7 U/ Q2 Q
? Option to explode Text directly to entities instead of Blocks8 Q) e% d. w- g1 } Q) b/ n
? Full MTEXT support* ~; Z/ R0 L/ h- a4 m- f
Features
% O Y7 \1 O$ w? Compile/Decompile AutoCAD SHX Font/Shape files outside of AutoCAD/ x: d; F( Q9 M6 t8 U
? Convert entire SHX files to equivalent DXF files.; z7 T; E/ p) F* d" J0 Z
? Explode all text inside a DWG/DXF file into component geometry (lines & arcs).
7 K5 A2 T/ T- q7 _' G, w? Replace all references to .SHX Shapes or fonts in a DWG/DXF file with entities or
/ T3 q4 ?- R5 q, z8 [# i Blocks. (SHX files must be present).
( _0 [0 r$ E$ {& s c? Explode SHP/SHX files to a simple vector ASCII DAT file.
) F) d5 a: k* _? Optionally preserve Arcs in shapes as true arcs and not a series of little lines.
* f2 B) z3 [! W? Send DXF/DWG files to clients without worrying about sending the font files.6 I! B9 o/ x9 r! Y
? Ideally suited for CAM and CNC cutting machine applications.8 u4 Y3 U7 r/ N1 M- i* _$ O8 \
? AutoCAD-86 v1.0, v1.1, Bigfont, and Unifont 2.0 SHX formats.
, P" A# }& q# fOperating System: Win9x/NT/ME/2000/XP- d4 v! O, V" ~3 r; t: K
Only $150 `& \5 {: S+ e! H9 o
To Download Feature Restricted Demo (3.8MB Zip), Right Click & Select "Save Target As" ; G1 \6 M5 @% `% D
SHXConvert v4.0 Ordering
/ Y H' g. U9 ]# G4 ?# `SHXConvert v4.0 Qty: * _7 x' c9 V9 A
: T/ j8 H; d! J( D3 M& ]
Font Services / a) R" z( J, ~
Font Services Provided by TC Fonts
5 _! F" @( j& [$ xConversion
7 p( n$ r, w7 K# e1 Y1 B5 d0 j$ g Truetype font (TTF) to filled/centerline AutoCAD SHX font, DWG file, or DXF file# w8 A( h& _1 J! c5 z
Postscript font (PFB) to Truetype, AutoCAD SHX font, DWG file DXF file9 | V+ Q" ? b- u
DWG file, DXF file, CorelDraw CDR or Adobe Illustrator AI to Truetype font (TTF) or AutoCAD SHX font
% U+ @% l& `: `5 u) I! }2 g) v8 h. c AutoCAD SHX to Truetype!
# c6 V8 o, v, @6 j$ A# m$ |/ BCustomization0 h2 T8 L9 A1 Q; \, y6 Y4 W# E5 T
1 Z- i S2 L- B, M1 \. ^. WCreation8 K8 C, b8 V6 Y4 {3 i
Truetype or AutoCAD SHX font
$ Y/ Y7 ` Z$ T9 a5 v4 u/ o( ZFor more information & pricing, contact TC Fonts.
) V7 `: |: ?7 n) ? 4 I+ T6 j+ Q8 y4 U8 g
Copyright ? 2006 Dave Edwards Consulting
' G& Q7 a! y. u- v7 Ositemanager@tcfonts.com. }+ q! ` _& S+ M" s6 Z" {
) {9 @9 B3 r* `9 c: i3 E( P
[ 本帖最后由 vcmasm2008 于 2008-3-4 22:00 编辑 ] |
