发表于 2008-3-7 12:23:30
来自: 中国广东深圳
Geomet process standard:1C1B和2C2B
8 Y) x* @. V {5 dGeomet coating film has a silver-metallic look,layers of metal flakes are connected with one another through the use of a special inorganic binder,because the film is extremely thin-only about 8um-it won't negatively affect the optimal fit between bolts and nuts,2C2B is the standard manugacturing process.
5 J" }+ l6 a# _* \( wit is a water-based coating technology and is completely chromium-free.4 ?9 N( ]% t, ?
it provides a very high degree of corrosion resistance when put through its paces in the salt spray test(JIS-Z-2731) and cyclic corrosion test. |
