Material Number: 1.0980 ; c* W) q) y5 W9 L
Material Name:S420MC7 [5 i0 c& N$ R2 {/ D' Q2 o* V
Standard DIN EN 10149-2 : 1995-11 0 t x" y. g4 e! b2 F
Material Group: Hot rolled flat products made from high yield strength steels (EN) & H! J3 E$ Q: c2 |( n( @
Search Result:Material recoding FeE 420-TM 9 r- b4 z$ n g" y2 RMaterial Description: The thermomechanical rolled steel S420MC, is used for cold formed components like vehicle frames, axles and special sections. / L& J) q1 t6 M1 m! e" B% |4 \0 p* }Tempering > 580 deg. leads to an decrease of the strength of the thermomechanical treated material. The lowest application temperature amounts to - 20 deg. At this temperature the proof of the notch impact energy of min. 40 J can be agreed. $ }3 u n* [: b9 `& GThe min. bending mandrel diameter for the 180°-bending test (transversal specimen) amounts to 0.5*t (t=specimen thickness).
