1天前
查看: 2267|回复: 1
[求助] DOMEX 355MC 材料类型
发表于 2008-5-8 09:01:04 | 显示全部楼层 |阅读模式 来自: 中国浙江嘉兴
我在图纸上看到DOCOL 350和DOMEX 355MC两种材料,却不知道它们分别对应(或相接近于)我国什么牌号的材料.请高手帮忙帮忙.最好有力学性能及化学成分.谢谢!!!
发表于 2008-5-8 09:05:31 | 显示全部楼层 来自: 中国陕西西安
Domex 355MC HSLA Steel
- d5 s5 o6 y3 u/ l 4 W  ^2 ?" |; O0 F5 ]* x/ j
7 }8 l, P* G- Z! a, eSubcategory: Low Alloy Steel; Metal
  p% t7 @6 K6 A8 I' n6 c6 K( z+ W) p  G* G+ b. `; S; Q/ l/ j
Material Notes: 5 ~4 `# X+ N, j8 l& E; H
HSLA Steel
% y) q6 j* r3 W/ ~7 M/ H* Y7 N  {; x! o: s# l
Characteristics: For hot-dip galvanizing, a thin Zn coating (50-80 microns) is specified. Iron content calculated as remainder
/ O+ s3 {& J  u! ?9 d* g+ C, q5 W0 O9 C7 W; K, D6 T% f. R
Domex MC grade steels conform to the provisions of EN 10149-2 standard and often have better properties.
: m3 n; P7 |7 {3 j
  W1 g" V3 `: ~, K1 w3 l7 U! HProperty data is for hot-rolled steel..) T: }* D- L2 D( V7 M# z
0 A3 I# N' D8 Z4 f4 Q+ @
Domex is the brand name of hot rolled products from SSAB Tunnplat. Domex cold-forming steels are modern structural steels. General use of Domex high strength steels offers a number of benefits compared to ordinary structural steels: Lower weight, Simpler production, Lower creep rate, Longer useful life, Higher load-bearing capacity, Lower transport costs, Reduced stocks, Lower overall cost.9 R( h( n" f' O! I4 X8 @
! G! g# A. `9 r& D( T7 |- |
Data provided by SSAB Tunnplat.% A$ {$ K! z4 D
$ a( g2 r8 T* _355MC(相当于国内的16Mn或Q345),
