2天前
查看: 3418|回复: 2
[求助] ASME SB111铜管与管板焊接规范。
发表于 2008-5-13 17:55:23 | 显示全部楼层 |阅读模式 来自: 中国北京
换热器换热管与管板焊接规范求助,ASME SB111(90-10 Cu-Ni)铜管与管板(ASME SB781 70-30 CuNi)焊接规范。
% c' U3 _% j4 ]( X' z谢谢高手回复。
发表于 2008-5-15 16:42:07 | 显示全部楼层 来自: 中国陕西西安
6 t" M/ d' ~1 t, t5 B) U! \: k
5 x) P0 ]- C+ H' N
Material Comparison Tables (ASTM ℃KS, JIS, DIN, BS, NBN, NF, UNI) / \& {# C  \1 [" W, N* m: @
. y. [6 T. x/ B/ d2 r- X7 w9 {3 Y
ASTM
6 |4 D- c: M2 ^; B6 ySTANDARD
UNS NO.
KOREA/JAPANES
GERMAN
BRITISH
ISO
KS/JIS Symbol
KS/JIS Numbe
Remarks
DIN Type
DIN2 Y# F+ o* q/ c' N. r+ |/ B* R
Number
Materiral1 R( m/ T+ e; _  f
Number
Remarks
B.S& _4 F- g2 ^# X; b+ y' n
Number
B.S Grade
Remarks
ISO Type
ISO Number
Ramarks
B 1114 r: ]  o" Z6 {1 u4 g
Copper and Copper-Alloy Seamless Condenser Tube and Ferrule Stock1 A5 _0 i  c! K2 \5 L
C44300C44300C4430T/C4430TD5301/H3300CuZn28Sn17852871CZ111CuZn28Sn1R1337
C68700C68700C6870T/C6870TD5301/H3300CuZN20Al17852871CZ110CuZn20Al2426-I
C70600C70600C7060T/C7060TD5301/H3300CuNi10Fe1Mn176642871CN102CuNi10Fe1Mn429
C71000C71000C7100T/C7100TD5301/H3300
C71500C71500C7150T/C7150TD5301/H3300CuNi30Mn1Fe176642871CN107CuNi30Mn1Fe
C71640C71640C7164T/C7164TD5301/H3300CuNi30Fe2Mn2176642871CN108CuNi30FeMn2
发表于 2008-5-15 16:43:16 | 显示全部楼层 来自: 中国陕西西安
ASTM B111-89a/ASME SB111-89a COPPER AND COPPER ALLOY SEAMLESS CONDENSER TUBES AND FERRULE% D' |0 r# J# v  u. l4 h
(ASTM B 111 - 89 a / ASME SB 111 - 89 a /ASTMB111-89a/ASMESB111-89a)
( k, ]" ~. `3 o+ t; U6 y1. Scope
& T8 x6 F9 s0 C- S* O
( b+ M2 q0 G7 ?7 S5 q
1.1 This specification covers seamless tube and ferrule stock of copper and various copper alloys up 31/8 in, inclusive, in dimeter, for use in surface condensers, evaporators, and heat exchangers. tubes for this application are normally made from the following coppers or copper alloys:
