查看: 2427|回复: 2
[分享] 填数程序
发表于 2008-6-10 08:15:44 | 显示全部楼层 |阅读模式 来自: 中国辽宁鞍山
填数程序6 J$ H0 z  I3 A4 ~
7 Y2 s$ h6 w2 W$ W
" l; _# y9 J- m# o
(defun c:tt()
/ m/ {+ w# g; v8 v6 n(setvar "cmdecho" 0)
  ]9 s% }# x$ U' Y (setq n1 (getreal "\n 请输入字的高度<3>:"))
0 X) A; O: m4 ~/ Y, _8 |    (IF (= n1 nil) (setq n1 3))- v; Z  c# ~& ]: O% h
(setq rot1(getreal "\n 请输入字的角度<0>:"))
; N; n" N+ T3 B( d7 `    (IF (= rot1 nil) (setq rot1 0))6 m& G* z0 s* s' g, V1 l/ j8 [
(setq n2 (getint "\n 请输入第一个数字<1>:"))* \9 y" ~5 F  \/ F; I9 a
    (IF (= n2 nil) (setq n2 1))
$ P* \3 a0 l& g( l6 q (setq n3 (getint "\n 请输入数字的个数:"))
4 J( M' t$ }- U% T3 x (setq p1 (getpoint "\n 请给出第一个数字的位置:"))4 y) I% A" Y# n
(setq dir1 (getint "\n 请输入书写的方向 1 水平,2 垂直<1>:"))
- {: E' o% N3 G    (IF (= dir1 nil) (setq dir1 1))/ L0 ^; R) d# Y. k" k
(setq dis1 (getreal "\n 请输入数字的间距<10>:"))8 y; \: O  Y& \1 Z- Q) I- R5 q
    (IF (= dis1 nil) (setq dis1 10))
* N2 ?1 P% X6 y2 d( x (setq prefix (getstring "\n 请输入前缀<nil>:"))% @, a4 B( x" W( |
(setq suffix (getstring "\n 请输入后缀<nil>:"))
$ Y# N, s/ m9 ^8 [  a; t, V (setq mo (getstring "\n 请输入对齐方式<m>:"))
8 x# I/ g6 a( f0 k/ x  (IF (= mo "") (SETQ mo "m"))9 w3 w% Y$ k' A( h
(setq x (car p1))
! t. e1 O0 ~9 p" w6 D* F (setq y (cadr p1))% j5 f4 Y& W8 \5 G$ r
(setq z (caddr p1))
" J5 G& y! j+ j2 |; p (setq n1 (* k n1))$ J' y6 h5 J3 w5 I) E5 `
(setq dis1 (* k dis1))
& H6 l& ]: J# o, O  `$ d$ l (if (= dir1 1)
9 _/ H9 g+ f) r8 m   (repeat n3
: B  l+ v* e- @7 X     (setq n4 (strcat prefix (itoa n2) suffix)). q+ d7 [4 E1 N. y) `% \
    (command "text" mo p1 n1 rot1 n4)
$ g% ~9 y* k. Z7 a3 ?% P     (setq n2 (+ n2 1))
0 W& Q  w0 n. W% c" y0 G1 m     (setq x (+ x dis1))
' l& J" E6 t* N* x6 M, \     (setq p1 (list x y z))
# p' `* F  l, P   )
$ {7 m* S% `# W4 ]4 N. V  E  )
5 z' X$ u! ]3 G# A% c (if (= dir1 2)
- \' o6 e" X! R   (repeat n3
7 d) w* p  z1 g" k  h' |0 h     (setq n4 (strcat prefix (itoa n2) suffix))
: s. c. i" a: I9 _3 J! V    (command "text" mo p1 n1 rot1 n4): j4 v  p' q! M9 B! R3 H: k! i
     (setq n2 (+ n2 1))5 }1 e# N, Z; U" S  z; {
  ;   (setq n2 (itoa nn))0 ]% ^, _5 V; R) K# Y
     (setq y (+ y dis1))
/ Q9 D( t  e% L2 J     (setq p1 (list x y z))! i+ o. F1 b/ [  c0 G0 a
   )" \& a3 L9 ?' @; E* S
6 x% z+ r0 Y# _(setvar "cmdecho" 1)
  L& i  E; ?% T. ]4 p  I)
 楼主| 发表于 2008-6-10 11:13:05 | 显示全部楼层 来自: 中国辽宁鞍山
使用方法是将上述源代码存为文本文件,再将后缀改为LSP,在CAD中调用该文件,然后执行"tt"命令即可
发表于 2009-2-20 23:09:09 | 显示全部楼层 来自: 中国云南红河哈尼族彝族自治州
试试看好用不,
