中国牌号 | 习惯名称 | 相似ISO牌号 | 淬、回火硬度HRC | 抗弯强度MPa | 冲击韧性 MJ/m² | 600℃下的硬度HRC |
W18Cr4V
+ L" g- V/ F/ K( k | T1& M* [4 d9 x/ j5 @$ ^3 o
| HS18-0-10 s | v( ~( G0 r: ?
| 62-65
8 w1 h" k& c. r* f | 34302 s$ z. F' I0 W$ i; ~; e
| 0.29 / T5 \$ |/ k K9 ~- m# n
| 50.5( P1 V7 c2 d( K$ `* K
W6Mo5Cr4V24 ?2 h- R& B- S4 G& @2 G
| M2
5 F9 N2 ]: o; [, B0 K | HS6-5-2; ]+ k1 U/ C7 Q2 j r$ ]# i J
| 63-66
+ g5 Z; C3 p b% O, { | 3500-4000 8 q+ M$ R3 F5 S: v5 P) K4 |
| 0.30-0.40
9 \. E' A' b* @3 U& l | 47-48
. y5 l4 |, [5 Q5 e1 R4 B' r6 R% p* | |
W6Mo5Cr4V3
2 V0 r1 a7 z0 }' X( K r8 n9 L | M3
' t; W& L3 a6 K; ]$ B4 T1 s' ?: B* g | HS6-5-3! J6 q% B: \. k" X" _
| 65-67
/ n' Q8 k, B# I | 3200
0 J: M `2 [# d& j | 0.254 Z, j* f+ n$ u' @
| 51.7
" h" r0 d% c8 ^* C+ H- n |
W9Mo3Cr4V ) Q; \& e1 a. B0 l
| , [# [# q) H9 f: O4 a
| 64-66- L. A: ~' X, y G9 _5 _" b
| r, N1 r1 `5 L D r" R$ K% o
| 4000-4500
; X7 ]2 ~0 l# @7 S2 M | 0.35-0.40 - x% Y J2 b$ K
6 k4 r7 V5 Q- @ |
W6Mo5Cr4V2Co5 . k3 r( x: Y4 s# t& ?1 X" I4 P6 A
# l( S. I' j+ p | HS6-5-2-5
{! K. f9 }. t w: h+ I | 65-66
# q0 f+ Q/ y& {: N5 } | 3000. w" s0 c/ d; ?7 I- J
| 0.30
: O$ a( @) x* `# F# l/ m* l | 54
0 }7 D; d- Z4 O" q$ G |
W10Mo4Cr4V3Co10 y8 n/ J' k; C8 H! x
| 2 ~! d0 r% f; d/ W |
| HS10-4-3-10 & w' c! p8 _3 G6 C" I
| 67-69
7 l4 y, m% }" `+ M1 A | 2350
- d5 I# j" H, T. b% a |
8 r& G/ ^! s) L+ Z# V) r | 55.5
% r& V- X7 P1 i" l. z8 T |
W2Mo9Cr4V2Co8
3 e7 K/ b- Q! | r1 F |
, G; v# j! A Q | HS2-9-2-8 8 A0 I) w' z5 }- y: [( p/ @
| 66-68! n3 b b0 ?2 w1 F- _8 R% K
| 2700-38005 u! w2 s' @( ?+ r9 U1 L
| 0.23-0.351 ?. T0 d7 v9 v2 u" M% g* r
| 55( R# y% T, v& C( v7 b2 [
W7Mo4Cr4V2Co5
: \; J' @3 E9 F# t+ n+ F y | M41! d9 z6 B8 g8 o, K3 o
| HS7-4-2-5
/ \# l+ ^5 I6 l: g+ U, `# B3 b | 66-68
k; j# @5 R) Y6 i0 d0 N | 2500-3000- b7 ?5 J# U8 t0 k
| 0.23-0.353 ]: O! Y- n& \/ I( j5 i! x, L
| 54! ^, @# ?0 F0 w! t7 K
W12Cr4VCo5
: S2 D& j, }, w0 D/ |% f2 B4 s |
& [' m4 d2 I* n' h2 F; v4 | | HS12-0-1-5
$ d. C. n( g- ]% M4 A7 ~ | 66-68
; u# F0 ~. m) \$ ] | 3000
" R/ |2 n# @( n: E% D+ X0 i | 0.25
' W4 V' ~0 A8 d) q) F: M$ h | 54 : V& ?% A2 B. b3 g* n. \4 u
W6Mo5Cr4V2Al
8 `! k. i( S6 K( p$ U | 501钢
( l K% S7 R& F4 s | 2 s L; N) X2 y
| 66-69
7 n) c! k. H- N0 H) X | 3000-4100: b3 S1 Y- e O, @2 W- J* k( U
| 0.25-0.30- j8 P9 `% V( `8 Y
| 55-563 A4 w% Q$ E9 F
110W1.5Mo9.5Cr4VCo8
4 Q' w& W# R- w/ j6 \; e6 W | M421 o, e; L) O9 T6 o, E1 [1 ~
: Q% E- X( }; H | 67-69
& F$ {7 D9 D1 a* K. b | 2650-3730; R3 }% C7 t6 p9 D& Z3 b8 @" S
| 0.23-0.29 g( M9 V* N0 o+ N' N
| 55.2/ T: y6 w& _: D1 w) G
W10Mo4Cr4VAl
; k, Y$ ^. P' _ | 5F6钢
' @' g' E5 o- M+ \+ ? | 6 T1 x6 T! o/ f6 j
| 68-69& A( [$ F8 Z- {8 X
| 3010
" t# W) h( k% ^* L4 t9 [6 F | 0.20
1 Q/ s8 v8 m; q6 @! @% N4 _ | 54.2 r" J% S: ?% n" z
