发表于 2008-7-7 22:04:08
来自: 中国浙江宁波
lisp可以尝试调用acad命令:-attedit来编辑属性;
# q: [4 H1 b! K1 t# ]) W0 n% U o可以试试下面的代码:
( b7 F2 H& M$ B( |# c: Z1 I' A(defun c:test ()
' \: q- D3 i( R(vl-load-com)
" B% J) N+ q0 h! v# v# i(setq att (getstring "\nChange attribute [Angle/Color/Height/Layer/Position/Style/Value/Tagstring]: "))6 w, ?7 B& y8 p% i
(setq obj (car (nentsel "\nSelect an Attribute: ")))
) y9 S: c1 x( |3 O$ r q5 h(setq obj (vlax-ename->vla-object obj))
+ g1 H. u; d: f7 [4 p% j(cond
% a8 Z" w0 `' S((= (strcase att) "A"); \# ~/ D7 k! Q. c& l
(setq ang (getstring t "\nNew Angle: ")): u' A3 B* s4 s* T& } {$ V
(vlax-put-property obj 'rotation ang))* `0 }; A# f0 L* C; _/ A3 v2 N
((= (strcase att) "C")
* T. E3 n8 N S3 ~: G/ J(setq col (getstring "\nNew Color Number: "))0 g- [+ o4 G) q1 J
(vlax-put-property obj 'color col))
- t' I& [* y+ M- t* H6 T6 b((= (strcase att) "H"), p u/ P* j# D# d
(setq ohei (vlax-get-property obj 'height))
/ n. Z0 U# V; f( P# w' i(setq hei (getdist (strcat "\nNew Height <" (rtos oh 2 2) ">:")))6 N- @. J3 E- H; h' Z7 D
(if (= hei "")(setq hei ohei))) |# P6 H/ ]$ @6 N; ~
(vlax-put-property obj 'height hei))
8 c/ e3 c" O& y6 l5 b" u((= (strcase att) "L")9 @7 g0 i) {* X' G$ O4 I2 v# E
(setq lay (getstring "\nNew Layer:"))( C$ {' W, _; ~
(if (not (tblsearch "LAYER" lay))
9 ~3 ^ @8 T1 S, ]1 A+ P* V& |8 q- V(alert (strcat "\nLayer " (strcase lay) " doesn't exist!"))9 j9 a" S# o/ Z. y. f1 w* P
(vlax-put-property obj 'layer lay)3 b5 P( b/ o+ Q5 n: S
- B% y$ ?$ R( }! V0 z$ ~((= (strcase att) "P"); \# H9 d! A( }' T0 I
(setq pos (getpoint "\nNew Position:")): ^* z( o! _- q9 J1 J! Y5 O/ q
(vlax-put-property obj 'textalignmentpoint (vlax-3d-point pos)))
u* D! J s" R# u7 T((= (strcase att) "S")0 _4 S2 j# }. {/ n: Y) j
(setq sty (getstring "\nNew Style: "))
3 w# t& B) I! D7 Y" S( H(if (not (tblsearch "STYLE" sty))
9 I0 k- k e: P(alert (strcat "\nThe style " (strcase sty) " doesn't exist!"))
) o1 q3 ^1 c$ B: {. W* H, q" g3 ^(vlax-put-property obj 'stylename sty)
6 x8 l( Z4 G2 D))8 }& ~& J7 ?. {/ M% k5 n
((= (strcase att) "V")
& C, `, }' _2 N* i2 U(setq val (getstring t "\nNew value: "))
3 z* P: `3 K, x- ~(vlax-put-property obj 'textstring val))
$ P: S$ u- `2 ^" P9 M$ ^9 u);c$ M9 ]* ?6 T) R# B- I2 z
(princ)
- q" t+ s0 d6 U* ] k) e/ r);defun $ _3 }7 z" T8 o' _ |" A5 L
VBA完成属性编辑相对来说操作更方便,VBA可以按下面的代码获得和编辑属性# W' i# t5 P2 G" K* r5 C+ ^: n
' Get the attributes for the block reference
z, W/ c* u4 N- A4 A1 b, o Dim varAttributes As Variant0 h- {' W1 [ y" }, i6 k
varAttributes = blockRefObj.GetAttributes/ E! m/ ?* _8 `) Y7 U+ }; l
4 P! X# ?/ I: i( Z" x) h
' Move the attribute tags and values into a string to be displayed in a Msgbox4 F! ^- [" G, u4 k1 F# J
Dim strAttributes As String
; }. W) G2 K" y% ]7 T% T6 Z Dim I As Integer
7 X8 \8 r$ q9 l For I = LBound(varAttributes) To UBound(varAttributes)2 O" p" r6 R, P; Z1 s0 {
strAttributes = strAttributes & " Tag: " & varAttributes(I).TagString & _
& a% c5 K% O1 d0 L r " Value: " & varAttributes(I).textString & " "2 |: @5 a, B! b. }$ W' L5 _5 u
Next
! W! u" s: S5 Z& s5 Y \ MsgBox "The attributes for blockReference " & blockRefObj.name & " are: " & strAttributes, , "GetAttributes Example"9 v2 F6 Y' A* f: H' `: w2 v
. V8 A8 \$ Z( {6 B/ h+ t6 k3 y ' Change the value of the attribute; y. `) ?0 X0 r
' Note: There is no SetAttributes. Once you have the variant array, you have the objects.( B; r. i0 |2 d0 ~
' Changing them changes the objects in the drawing.
$ T$ `! P/ a2 R' { varAttributes(0).textString = "NEW VALUE!" |
