- 积分
- 1701
UID83
主题
在线时间 小时
注册时间2006-1-24
--------------Legal Notices--------------
. D. u _( H, I: _0 w
# o* Z+ ]: Z5 Z+ Y! f: h, m; q% T7 C
Copyright 2004, Unigraphics Solutions Inc.! l! S! i2 i' _' i
) @" ]5 k+ s& t6 ~# i
2 _# E# E2 m/ GAll rights reserved.
' \* ^2 g0 i0 E; t3 p* J _% R- x8 Q; ?/ p# s/ A j
7 x5 ]) p3 D& Y: j, ?+ @Including software, file formats, and audio-visual displays; may be used pursuant to applicable software license agreement; contains confidential and proprietary information of Unigraphics Solutions Inc. and/or third parties which is protected by copyright and trade secret law and may not be provided or otherwise made available without proper authorization.
% t/ ^9 b/ Q+ l3 F4 t. [( b8 y
; p1 X9 i- {) cRestricted Rights LegendUse duplication, or disclosure by the Government is subject to restrictions as set forth in subparagraph (c) (1) (ii) of the Rights in Technical Data and Computer Software clause at DFARS 252.227-7013 or subparagraphs (c) (1) and (2) of Commercial Computer Software -- Restricted Rights at 48 CFR 52.227-19, as applicable.$ {% X" {7 o6 y3 D4 Z
: B& K& f" P& |8 F- q Q+ i& ?
5 ?; e( z z! [' _- {Unpublished -- rights reserved under the copyright laws of the United States.
7 M; O' c+ c/ ~1 w# _" s( U: L+ A8 f, ]& v5 C/ Q( L0 J
( Q( s" c( f6 M+ s8 b
--------------------End of Legal Notices--------------------2 Z* Q' a+ i' m/ q9 J
& f+ ~4 f( y' C0 F
2 h) `/ N; \8 l# }# x0 r( s9 B, S7 p--------------Release Notes:--------------
' y' j j; J( }5 H+ u4 \) y2 d Y4 B9 K! D" _4 p# j2 L0 k
; ^3 L1 G8 q8 g5 v6 ?Product: Solid Edge Version: 15.00.01.05Date: 10-Feb-2004+ b% _% f8 p; J
; p. t/ k2 c2 U) R+ a2 P G; k# m& c6 S2 a& S8 t8 ?. r
This Update has been verified to operate properly on:?Windows 2000 Professional?operating system running Service Pack 1, 2, 3 or 4?Windows XP Professional?operating system running Service Pack 1
" m- E5 T# B! `( Z$ i3 N+ Q" f( w
2 r- v2 s ?$ \V15 Update 1 should be installed on top of Solid Edge Version 15.00.00.72.- Z( `! r# @! F5 b* n
; Z5 ]+ O! Y) e- c7 `; [& Y
5 w% ]8 D- t, `- Z4 c8 \. X
--------------------End of Release Notes--------------------
. \0 w7 G9 Q% P
; O( }8 e. |; T' `) Q3 j D: s; q* v# p: o
---------------------------------Update 1 addresses the following:---------------------------------) k: l8 z# D1 Z# S
' O; q8 [0 u: R5 T- ~: h
( k" u7 T9 Y* Q* j) G4 g
=====Assembly===== PR 2031552: Fixed a crash using the "Transfer" command.PR 2032793: Fixed a crash in assembly when closing a sub-assembly.PR 4879845: Fixed a crash in assembly/draft using the Variable table and undo / redoPR 4884234: Fixed a crash when using Create in Place and include from peerPR 4885491: Fixed a crash selecting cutout in pathfinder.PR 4886843: Fixed a crash selecting cutout in pathfinderPR 1279779: Fixed a problem where assembly sketches are now locatable for coordinate system creationPR 2031613: Fixed a family of assembly performance issue switching members and creating new members.PR 2032603: Fixed a problem deleting a file during save when the file resides in a folder that is read-only.PR 4873684: Fixed a problem with measure distance locating the wrong sphere center point and line midpoint.PR 4877598: Fixed a problem with the multiple solutions dialog appearing when an assembly feature recomputes.PR 4878364: Fixed a problem using Replace Part on a Assembly with Assembly FeaturesPR 4879145: Fixed a problem where features are pasted when placing syslib if during paste you redefine the plane. PR 4883430: Fixed a problem where sketches/ref planes can be located even if the hide previous level is turned on.PR 4883552: Fixed a problem where you can not locate sketches after deleting a cutout until Solid Edge is restarted.PR 4884007: Fixed a problem where assembly features in a top level assembly display during in place activation.PR 4885422: Fixed a problem where hidden sketches are redisplaying when creating assembly featuresPR 4892853: Fixed a problem to help eliminate "lock-up" situations when using the Physical Motion option in Move Part.PR 1293657: Fixed a problem were a coordinate system placed into an assembly has wrong position.PR 129664: A fix has been made to correct a cutaway view problem that occurs with specific testcases.PR 1300108: Fixed a problem where a revolved cutout assembly feature is not cutting 360 degsPR 2031352: Fixed a problem remembering part visibility status under hidden subassemblies.PR 4853823: Fixed a problem where Revolved Cutout is marked as failed if 360 used.PR 4866966: Fixed a problem with the "To" step using Select From SketchPR 4867036: Fixed a problem where you can't pick a face after activating a partPR 4876149: Fixed a problem where the From/To Extent isn't working correctly during feature Edit.PR 4876152: Fixed a problem where the multiselect collector is missing after doing a rotate in Select Parts Step.PR 4884358: Fixed a problem where coincident and parallel assembly reference planes are not recomputing correctlyPR 4896494: Fixed a problem with abnormally large range boxes in assembly.PR 4898239: Enabled collision detection and physical motion with an academic license.PR 4899837: Fixed a crash when searching for a file using a wildcardPR 4883476: Fixed a problem where a part disappears when editing a driving sketch.PR 4902260: Fixed a problem where search with "contains" fails on localized system.PR 4904986: Added Revision Manager back on the shortcut menu from Windows ExplorerPR 4912208: Fixed a customer abort captured and posted using the automatic crashlog capture tool. PR 1291821: Fixed a problem where Links in variable table are lost during "save as" operationPR 2033786: Fixed a problem where the assembly path finder does not display correctly.PR 4847244: Fixed a problem with Solid Edge performance when reading in UG filesPR 4904919: Fixed a problem where assembly driven hole features do not delete as they shouldPR 4904965: Fixed a problem where parts change colors when adding assembly featuresPR 4905210: Fixed a problem with the constraint/dimension conversion of pre-V15 files.PR 4907326: Fixed a problem where Bill of material report showed the sub-occurrences scattered =====Part===== PR 2032604: Fixed a crash when exiting relationship command without doing anything.PR 4884688: Fixed a crash using undo.PR 4889992: Fixed a crash during creation of bound surface if tangency is toggled on/offPR 4890953: Fixed a crash when editing a feature libraryPR 4891716: Fixed a crash when connecting or deleting points in Contour CurvePR 1296355: Fixed a problem where custom property attributes in weldments were sometimes lostPR 1298593: Fixed a problem where you could not migrate a interpart copy to the latest state of the part.PR 1298927: Fixed a problem where a right mouse click from side step will re-initiate the offset command PR 1299020: Fixed a problem where inner corner treatment for flat pattern does not work.PR 1299239: Fixed a problem of incorrect conversions being performed for g/dm3 and kg/LPR 1301287: Fixed a problem where deleting a member of a Family of Parts, and closing the file, does not prompt to save.PR 2032280: Fixed a problem where a feature becomes failed when the top feature recomputes.PR 2032370: Fixed a problem where selecting edges to include in a sketch locks up Solid EdgePR 4874453: Fixed a problem where Solid Edge writes ASCII STL as comma delimited when delimiter is set to commaPR 4878855: Fixed a problem where bend centerlines are missing. Need to recompute flat pattern and update DV. PR 4879446: Fixed a problem where a swept cutout from v11 fails on recompute.PR 4880749: Fixed a problem to correct the display of Japanese characters in 3D dimensions and annotations.PR 4883882: Fixed a problem where show sketch colors do not refresh displayPR 4884366: Fixed a problem with editing a layout sketch causing the associated part to fail. PR 4885172: Fixed a problem where some file would recompute on file open.PR 4888985: Fixed a problem that will improve display performance in the absence of the color manager settings. PR 4895025: Enabled From Surface in pattern along curve.PR 4897211: Fixed a problem where, Author was not displayed correctly on revision dialogPR 1304289: Fixed a problem combo box list is empty in treatment step, no previous values storedPR 4895336: Fixed a problem with scroll bars in QuickPick after removing edge.exe.manifest.PR 4905913: Fixed a problem to avoid a crash and/or hang when running 3Dlabs WildcatVP or Oxygen graphics cards.PR 4900714: Fixed a problem where DeleteBlends.Add(BlendFaces) API does not workPR 4900494: Fixed a crash when both Rectangular pattern and Textprofile objects co-existPR 4887783: Fixed a problem where a gap dimension is not displayed correctly. - Note: The dimension is displayed correctly now, but for legacy files, we have to edit the feature manually to force it recompute ( dis-select the flange face and re-reselect it). =====Draft===== PR 1297810: Fixed a problem where Solid Edge crashes during import of the given AutoCAD filePR 1298078: Fixed a problem where Solid Edge crashes during import of the given AutoCAD filePR 2030449: Fixed a problem where the given draft file crashes during export to autocad on Japanese os.PR 2032358: Fixed a crash while editing callout.PR 2032409: Fixed a crash when exporting leaders to AutoCadPR 4881728: Fixed a crash when opening a mds file. PR 4889234: Fixed a crash during the display of Shaded Drawing Views.PR 1300970: Fixed a lockup exporting a given draft file to AutoCAD.PR 2032417: Fixed a performance problem switching to a draft view.PR 2032867: Fixed a problem where the draft file can no longer be saved after copying and pasting centermarks.PR 4739762: Fixed a problem that would cause cut depth discrepancies in broken-out section views.PR 4878092: Fixed a problem where user defined detail envelopes are not exportingPR 4878179: Fixed a problem in the numbering of occurrences in the Drawing View Properties dialog box.PR 4881620: Fixed a performance regression placing drawing viewsPR 4889126: Fixed a problem where the "show fill style" check box is not being honored.PR 4889337: Fixed a problem that would cause drawing view update failures after modifying assembly features.PR 1303090: Fixed a problem where Create 3D command is not working in sheet metal files. PR 4880099: Fixed a problem where a dimension is reattaching to another feature in DV on update.PR 4898004: Fixed a problem where the user could not delete constraints in the Detail Profile editing environment.PR 1304195: Fixed a problem with objModMem.DisplayType = seShowPart.PR 1304282: Fixed a problem where unable to copy objects in Draft file.PR 2033417: Fixed a problem where a cutting plane line on a view in the broken state would not move correctlyPR 4823451: Fixed a problem where SAT files cannot be read by other applicationsPR 4897809: Fixed a problem where weldments do not display correctly on draft parts list.PR 4897809: Fixed a problem with parts list of weldment and the mass column is included.PR 4904798: Fixed a problem where hole table column width was being set to zero.PR 4906734: Fixed a problem with copy/paste of views with threaded hole data.PR 4907809: Fixed a problem where parts list balloons are incorrect when placed on a weldment view9 }5 m' `8 K# A; W" }9 T, f
$ G, X( C- Q( H$ ~2 T8 o9 v
' @; ^) k! B6 P=====API===== PR 4895281: Fixed a problem that caused a crash using Property Manager with custom propertiesPR 1297142: Fixed a problem where command button state and enabled property's don't hold there valuePR 4887313: Fixed a problem creating an instance of Insight Connect via APIPR 4895763: Using Host Browse option will not have any problem for TDMMigration.PR 1300056: Fixed a problem where Solid Edge Viewer crashes after 100 files opened through API.PR 4912111: Fixed a crash when selecting Project Tab in File Properties started via Internet Explorer.PR 4901675: Fixed a problem where the property seed file is not read if it is in a different location =====Insight===== PR 4902240: Fixed a problem where an image could not be inserted into View & Markup in 2DPR 4866409: Fixed a problem where Insight Connect View & Markup aborts if it cannot view the filePR 4885527: Fixed a problem where deleting files from pcf causes an abort.PR 4888928: Fixed a crash when adding folder map information during Add To Library logged in is non-AdminPR 4892615: Fixed a crash when opening a View & Markup file that contains 2-byte char in filename.PR 1298369: Fixed a problem where "Move all documents through workflow" command is failing.PR 4820661: Fixed a problem where the Browse for folder lists previous selection twice.PR 4882660: Fixed a problem were you are able to add a managed file with no man props to assy and save - no errorsPR 4883013: Fixed a problem with reverse property synchronization.PR 4884140: Fixed a problem where no error is displayed for required custom properties with no values. PR 4884935: Fixed a crash closing a PCF file with Markup.PR 4885126: Fixed a problem where loading Insight server is not modifying the ONET.xml template filesPR 4885271: Fixed a problem where client downloaded partial file which was corrupt in local cache.PR 4886451: Fixed a problem where a PCF file can not be opened from Outlook if Solid Edge is not runningPR 4887048: Fixed a problem where after adding a Document Library to Propman, lists a single entry for each folderPR 4889120: Fixed a problem where LCA fails to change status of linked documents from dftPR 4889306: Fixed a problem where you cannot insert image into .pcf of a draft docPR 4891182: Fixed a problem where modifying a managed pcf file created by another user should not ask for folder mapPR 4892668: Fixed a problem with web parts failing to load if filename contains the "=" character.PR 4894660: Fixed a translation issues in Japanese web parts.PR 4895848: Fixed a problem where the migrated file name format can differ based on options in TDMToSE.ini.PR 4839984: Fixed a problem getting the Share Point User Roles.PR 4861947: Fixed a problem where hidden parts are getting removed from the assembly during PCF save operation.PR 4900750: Fixed a problem with the installation of SE V15 and E-VIS on the same machine. PR 4902425: Fixed a problem with revise errors when file resides at root level of document library PR 4906665: Fixed a crash identified during file open from the IE browserPR 4910331: Fixed a crash if a value is entered in a required "number" type cell.PR 4910633: Fixed a problem where opening managed PCF files fails. PR 4910561: Fixed a problem where LCA works for Administrative users and File->Save is giving insufficient privilege messages for non-Administrative users.& c8 M# K8 W3 q" _0 B8 r% s3 x
; d3 ?( j& @; b* {) w
$ Z D+ S: {3 S2 x$ E6 g6 c
=== SEViewer===* G; j$ I& c6 k7 ~
7 G+ p0 o* r' N; B9 M5 h& m$ j" ^$ G$ S9 o' ^
PR 4905794: Fixed a problem where printing a draft file from the viewer fails, "Failed to get IDAKClient interface".PR 4882074: Fixed a problem where printing 3D files from the viewer generates an error - Failed to get the IDAK interface
w- k" {" h& W4 a
" r4 Y1 U6 }6 _3 `
9 X; ^* s3 s1 X9 Y---End ---
& g0 T! _% `0 u* V* |+ ]1 ?/ J% U g) V! u* k e2 Y
http://www.3dportal.cn/attach/down.php?id=3265
) b- B$ }* M: a3 W" R. Ehttp://www.3dportal.cn/attach/down.php?id=3266
$ N: y9 _ i+ Hhttp://www.3dportal.cn/attach/down.php?id=32671 {( E6 \' ]! w- B. w
http://www.3dportal.cn/attach/down.php?id=3268
8 e: I- R) ]% I1 H: bhttp://www.3dportal.cn/attach/down.php?id=3269
& e& i) x3 f8 d6 _0 d
4 a$ o! b+ b) s( C5 U4 a) d[ 本帖最后由 wei820512 于 2006-12-23 23:08 编辑 ] |
