查看: 1222|回复: 0
[分享] Disamatic Molding Explained
发表于 2008-7-9 20:05:51 | 显示全部楼层 |阅读模式 来自: 中国辽宁大连
$ X9 L2 J, C" U1 f- g( d2 ~$ K/ F
Currently, all Metal Technologies foundries utilize Disamatic Molding Machines to produce molds for our castings. Disamatics offer a highly efficient means of rapidly and automatically creating a string of flaskless molds. These molds are built for vertical casting and are created in a vertical molding environment. For an explanation of the process, read through the text below and click on the thumbnail images to see illustrations.
0 C' y# u7 u4 f- Z; C& t7 |8 r6 H
Step 1. Sand is blown into the Molding Chamber from above.
2 q, F& X5 q! d8 U
Step 2. The Ram advances, pushing the Ram Pattern. This compresses the sand in the Molding Chamber to form mold impressions.
- g" s* J' F. b7 X
! s7 `- K; k/ U! o9 ?: V) u# x
Step 2. (cont) The compression creates opposite halves of consecutive molds to placed in the mold string.
; c5 v8 z0 K' {4 }* D( T# @
Step 2. (cont) Castings cannot be formed using a single mold, but when a new mold is placed in the mold string, its leading edge meets the trailing edge of the previous mold to create a completed mold cavity. ' Y! n8 y9 F0 z8 R4 c& Z
8 C- ]" N- f" m3 C
Step 3. The Swing Pattern moves back and up to allow the mold to exit the Molding Chamber.
& \9 ?( {6 D; B$ l0 v
! O* y# I% ^0 R* t# H, r& l
Step 4. The Ram extends, pushing the new mold into the existing mold string.5 q: y2 i' I3 `! ^4 H
! j7 q9 S; L: ~' S: L
Step 5. The Ram and Swing patterns return to their original position to begin the process again.
% ^5 H7 Y2 _+ R3 J/ y, R- }
Step 6. Sand is blown into the Molding Chamber for the next mold. A little further down the mold string, iron is poured into the top of a formed mold via the pouring sprue left by the pattern impressions.
