10天前
查看: 8070|回复: 24
[转帖]Mastercam软件的后置处理文件及其设定方法
发表于 2004-2-16 22:03:00 | 显示全部楼层 来自: 中国湖北襄阳
# -------------------------------------------------------------------------- # Motion NC output 运动 NC 输出 # -------------------------------------------------------------------------- #绝对方式输出的变量为 xabs, yabs, zabs. #增量方式输出的变量为 xinc, yinc, zinc. # -------------------------------------------------------------------------- prapidout #输出直线运动的NC指令 - 快速                                                 pcan1, pbld, n, sgplane, `sgcode, sgabsinc, pccdia,        pxout, pyout, pzout, strcantext, scoolant, e plinout #输出直线运动的NC指令 - 进给                                                 pcan1, pbld, n, sgplane, `sgcode, sgabsinc, pccdia,        pxout, pyout, pzout, feed, strcantext, scoolant, e pcirout #输出圆弧插补的NC指令                                                 if arcrad >= max_arc, result = mprint(saxiswarn)                                                 pcan1, pbld, n, sgplane, sgcode, sgabsinc, pccdia,        pxout, pyout, pzout, parc, feed, strcantext, scoolant, e pcom_moveb #Common motion preparation routines, before                                                 pxyzcout                                                 ps_inc_calc                                                          pncoutput #Movement output                                                 pcom_moveb                                                 comment                                                 pcan                                                 if gcode = zero, prapidout                                                 if gcode = one, plinout                                                 if gcode > one & gcode < four, pcirout                                                 pcom_movea        pcom_movea #Common motion preparation routines, after                                                 pcan2                                                 pe_inc_calc pdwl_spd #Call from NCI gcode 4                                                 pspindle                                                 comment                                                 if prv_spdir2 <> spdir2, pbld, n, *sm05, e                                                 if prv_speed <> speed | prv_spdir2 <> spdir2,        pbld, n, *speed, *spindle, pgear, e                                                 pcan                                                 if fmtrnd(dwell), pcan1, pbld, n, *sgcode, *dwell, strcantext, e                                                 else, pcan1, pbld, n, strcantext, e                                                 pcan2 prapid #输出直线运动的NC指令 - 快速                                                 pncoutput        pzrapid #输出直线运动的NC指令 - 快速 Z only                                                 pncoutput        plin #输出直线运动的NC指令 - 进给                                                 pncoutput pz #输出直线运动的NC指令 - 进给 Z only                                                 pncoutput pmx #输出NCI向量的NC指令                                                 pncoutput        pcir #输出圆弧插补的NC指令                                                 pncoutput        # -------------------------------------------------------------------------- # Motion output components 运动输出组成 # -------------------------------------------------------------------------- pbld #Canned text - 单节删除                                                 if bld, '/'        pfbld #强制 - 单节删除                                                 "/" pccdia #切削补偿                                                 #Force Dxx#                                                 if prv_cc_pos <> cc_pos & cc_pos, prv_tloffno = c9k                                                 sccomp                                                 if cc_pos, tloffno        pfxout #Force X axis output                                                 if absinc = zero, *xabs, !xinc                                                 else, *xinc, !xabs        pxout #X output                                                 if absinc = zero, xabs, !xinc                                                 else, xinc, !xabs pfyout #Force Y axis output                                                 if absinc = zero, *yabs, !yinc                                                 else, *yinc, !yabs        pyout #Y output                                                 if absinc = zero, yabs, !yinc                                                 else, yinc, !yabs pfzout #Force Z axis output                                                 if absinc = zero, *zabs, !zinc                                                 else, *zinc, !zabs        pzout #Z output                                                 if absinc = zero, zabs, !zinc                                                 else, zinc, !zabs parc #选择圆弧输出格式                                                 if arcoutput = zero,        [        #圆弧输出为 IJK        i, j, k        ]                                                 else,        [        #圆弧输出为 R        if abs(sweep)<=180 | arcoutput=one, result = nwadrs(srad, arcrad)        else, result = nwadrs(srminus, arcrad)        *arcrad        ]        # -------------------------------------------------------------------------- # Drilling 钻孔 # -------------------------------------------------------------------------- pdrlcommonb #Canned Drill Cycle common call, before                                                 if gcode = 81,                         [        result = newfs (two, zinc)        if drillcyc = three, drlgsel = fsg1(-ss) + drillcyc * two        else, drlgsel = fsg2(dwell) + drillcyc * two        if initht <> refht, drillref = zero        else, drillref = one        prv_refht_a = c9k        prv_refht_i = c9k                         ]                                                 z = depth                                                 prv_zia = initht                                                 feed = fr_pos                                                 prv_dwell = zero                                                 @dwell                                                 pcom_moveb                                                 comment                                                 pcan prdrlout #R drill position                                                 refht_a = refht                                                 refht_i = refht - initht                                                 if absinc = zero, refht_a, !refht_i                                                 else, refht_i, !refht_a pdrill #钻孔固定循环                                                 pdrlcommonb                                                 pcan1, pbld, n, *sgdrlref, *sgdrill, pxout, pyout, pfzout,        prdrlout, dwell, *feed, strcantext, e                                                 pcom_movea ppeck #啄式钻孔固定循环                                                 pdrlcommonb                                                 pcan1, pbld, n, *sgdrlref, *sgdrill, pxout, pyout, pfzout,        prdrlout, *peck1, *feed, strcantext, e                                                 pcom_movea pchpbrk #断屑固定循环                                                 pdrlcommonb                                                 pcan1, pbld, n, *sgdrlref, *sgdrill, pxout, pyout, pfzout,        prdrlout, *peck1, *feed, strcantext, e                                                 pcom_movea ptap #攻螺纹固定循环                                                 pdrlcommonb                                                 pcan1, pbld, n, *sgdrlref, *sgdrill, pxout, pyout, pfzout,        prdrlout, *feed, strcantext, e                                                 pcom_movea pbore1 #镗孔固定循环 #1                                                 pdrlcommonb                                                 pcan1, pbld, n, *sgdrlref, *sgdrill, pxout, pyout, pfzout,        prdrlout, dwell, *feed, strcantext, e                                                 pcom_movea pbore2 #镗孔固定循环 #2                                                 pdrlcommonb                                                 pcan1, pbld, n, *sgdrlref, *sgdrill, pxout, pyout, pfzout,        prdrlout, *feed, strcantext, e                                                 pcom_movea pmisc1 #Canned Misc #1 Cycle                                                 pdrlcommonb                                                 pcan1, pbld, n, *sgdrlref, *sgdrill, pxout, pyout, pfzout,        prdrlout, shftdrl, dwell, *feed, strcantext, e                                                 pcom_movea pmisc2 #Canned Misc #2 Cycle (User Option)                                                 pdrill pdrill_2 #Canned Drill Cycle, additional points                                                 pdrlcommonb                                                 pcan1, pbld, n, pxout, pyout, pzout, prdrlout, dwell,        feed, strcantext, e                                                 pcom_movea ppeck_2 #Canned Peck Drill Cycle                                                 pdrill_2 pchpbrk_2 #Canned Chip Break Cycle                                                 pdrill_2 ptap_2 #Canned Tap Cycle                                                 pdrill_2 pbore1_2 #Canned Bore #1 Cycle                                                 pdrill_2        pbore2_2 #Canned Bore #2 Cycle                                                 pdrill_2 pmisc1_2 #Canned Misc #1 Cycle                                                 pdrill_2 pmisc2_2 #Canned Misc #2 Cycle                                                 pdrill_2 pdrlcst #自定义钻孔循环 8 - 19 (user option)                                                 #Use this postblock to customize drilling cycles 8 - 19                                                 pdrlcommonb                                                 "CUSTOMIZABLE DRILL CYCLE ", pfxout, pfyout, pfzout, e                                                 pcom_movea pdrlcst_2 #自定义钻孔循环 8 - 19, additional points (user option)                                                 #Use this postblock to customize drilling cycles 8 - 19                                                 pdrlcommonb                                                 "CUSTOMIZABLE DRILL CYCLE ", pfxout, pfyout, pfzout, e                                                 pcom_movea pcanceldc #Cancel canned drill cycle                                                 result = newfs (three, zinc)                                                 z = initht                                                 prv_zia = initht                                                 pxyzcout                                                 !zabs, !zinc                                                 prv_gcode = zero                                                 pbld, n, "G80", e
 楼主| 发表于 2004-2-16 22:12:00 | 显示全部楼层 来自: 中国湖北襄阳
希望它对大家有所帮助!!!
 楼主| 发表于 2004-2-16 22:00:00 | 显示全部楼层 来自: 中国湖北襄阳
# -------------------------------------------------------------------------- # NC 输出的字符串和字符串选择定义 # -------------------------------------------------------------------------- #Address string definitions 位址串定义 strm "M" strn "N" stro "O" strp "P" srad "R" srminus "R-" sblank #Cantext 字符串定义 (spaces must be padded here) sm00 "M00" sm01 "M01" strtextno strcantext # -------------------------------------------------------------------------- # 错误信息 # -------------------------------------------------------------------------- saxiswarn " WARNING-THE RAD OF ARC IS TOO LARGE" # -------------------------------------------------------------------------- # 一般的 G 和 M 代码串选择表 General G and M Code String select tables # -------------------------------------------------------------------------- # 运动 G 代码选择 sg00 G00 #快速定位 sg01 G01 #直线进给 sg02 G02 #圆弧插补 CW sg03 G03 #圆弧插补 CCW sg04 G04 #暂停 sgcode #Target for string fstrsel sg00 gcode sgcode # -------------------------------------------------------------------------- # 选择工作平面 G 字串 sg17 G17 #XY 平面代码 sg19 G19 #YZ 平面代码 sg18 G18 #XZ 平面代码 sgplane #Target string fstrsel sg17 plane sgplane # -------------------------------------------------------------------------- #选择 英制/米制 字串 sg20 G20 #英制代码 sg21 G21 #米制代码 smetric #Target string fstrsel sg20 met_tool smetric # -------------------------------------------------------------------------- #选择参考点回归字串 sg28 G28 #第一参考点回归 sg30 G30 #第二参考点回归 sg28ref #Target string fstrsel sg28 mi3 sg28ref # -------------------------------------------------------------------------- # 切削补偿 G 字串选择 scc0 G40 #切削补偿取消 scc1 G41 #切削左补偿 scc2 G42 #切削右补偿 sccomp #Target for string fstrsel scc0 cc_pos sccomp # -------------------------------------------------------------------------- # 钻孔固定循环字符串选择 sg81 G81 #钻孔 - 无暂停 sg81d G82 #钻孔 - 有暂停 sg83 G83 #啄式钻孔 - 无暂停 sg83d G83 #啄式钻孔 - 有暂停 sg73 G73 #断屑 - 无暂停 sg73d G73 #断屑 - 有暂停 sg84 G84 #攻螺纹 - 右手 sg84d G74 #攻螺纹 - 左手 sg85 G85 #镗孔 #1 - 无暂停 sg85d G89 #镗孔 #1 - 有暂停 sg86 G86 #镗孔 #2 - 无暂停 sg86d G86 #镗孔 #2 - 有暂停 sgm1 G76 #misc #1 - 无暂停 sgm1d G76 #misc #1 - 有暂停 sgm2 G81 #misc #2 - 无暂停 sgm2d G82 #misc #2 - 有暂停 sgdrill #Target for string        fstrsel sg81 drlgsel sgdrill # -------------------------------------------------------------------------- # 选择增量或绝对 G字符串 sg90 G90 #绝对代码 sg91 G91 #增量代码 sgabsinc #Target string fstrsel sg90 absinc sgabsinc # -------------------------------------------------------------------------- #钻孔固定循环参考高度 sg98 G98 #Z轴回到起始高度 sg99 G99 #Z轴回到参考高度 sgdrlref #Target for string        fstrsel sg98 drillref sgdrlref # Drill cycle G string select # -------------------------------------------------------------------------- # Generate string for spindle sm04 M04 #主轴反转 sm05 M05 #主轴停止 sm03 M03 #主轴正转 spindle #Target for string fstrsel sm04 spdir2 spindle # -------------------------------------------------------------------------- # 冷却 M 字符串选择 sm09 M09 #冷却液 Off sm08 M08 #冷却液 喷射 sm08_1 M08 #冷却液 喷雾 sm08_2 M08 #Coolant Tool scoolant #Target for string fstrsel sm09 coolant scoolant # -------------------------------------------------------------------------- # 定义齿轮选择代码 flktbl 1 3 #Lookup table definition - table no. - no. entries        40 0 #底速齿轮档        41 400 #中速齿轮档        42 2250 #高速齿轮档 # -------------------------------------------------------------------------- # 刀具交换 / NC输出变量格式 # -------------------------------------------------------------------------- fmt T 4 t #刀具号 fmt T 4 first_tool #第一把使用的刀具 fmt T 4 next_tool #下一把使用的刀具 fmt D 4 tloffno #直径偏移号 fmt H 4 tlngno #长度偏移号 fmt G 4 g_wcs #WCS G address fmt P 4 p_wcs #WCS P address fmt S 4 speed #主轴转速 fmt M 4 gear #Gear range # -------------------------------------------------------------------------- fmt N 4 n #序号 fmt X 2 xabs #X 坐标输出 fmt Y 2 yabs #Y 坐标输出 fmt Z 2 zabs #Z 坐标输出 fmt X 3 xinc #X 坐标输出 fmt Y 3 yinc #Y 坐标输出 fmt Z 3 zinc #Z 坐标输出 fmt I 3 i #x 轴方向上的圆弧中心描述 fmt J 3 j #y 轴方向上的圆弧中心描述 fmt K 3 k #z 轴方向上的圆弧中心描述 fmt R 2 arcrad #圆弧半径 fmt F 15 feed #进给率 fmt P 11 dwell #暂停 fmt M 5 cantext #Canned text # -------------------------------------------------------------------------- #Move comment (pound) to output colon with program numbers fmt O 7 progno #Program number #fmt ":" 7 progno #Program number # -------------------------------------------------------------------------- fmt Q 2 peck1 #First peck increment (positive) fmt Q 2 shftdrl #Fine bore tool shift fmt R 2 refht_a #Reference height fmt R 2 refht_i #Reference height # -------------------------------------------------------------------------- fmt "TOOL:" 4 tnote # 注释格式 fmt " DIA. OFF:" 4 toffnote # 注释格式 fmt " LEN.:" 4 tlngnote # 注释格式 fmt " DIA.:" 1 tldia # 注释格式 # -------------------------------------------------------------------------- # Tool Comment / Manual Entry Section 刀具注释/手工输入部分 # -------------------------------------------------------------------------- ptoolcomment #Comment for tool                                                 tnote = t                                                 toffnote = tloffno                                                 tlngnote = tlngno                                                 "(", *tnote, *tldia, *sopnote, "", e pstrtool #Comment for tool                                                 if strtool <> sblank,        [        strtool = ucase(strtool)        *strtool, " "        ] pcomment #Comment from manual entry (must call pcomment2 if booleans)                                                 pcomment2 pcomment2 #Comment from manual entry                                                 scomm = ucase (scomm)                                                 if gcode = 1007, "(", scomm, ")"                                                 else, "(", scomm, ")", e # -------------------------------------------------------------------------- # 文件起始和刀具交换设置 # -------------------------------------------------------------------------- psof0 #Start of file for tool zero                                                 psof psof #Start of file for non-zero tool number                                                 toolchng = one                                                 if ntools = one,        [        #skip single tool outputs, stagetool must be on        stagetool = m_one        !next_tool        ]                                                 "%", e                                                 *progno, e                                                 "(PROGRAM NAME - ", progname, ")", e                                                 "(DATE=Day-Month-Year - ", date, " TIME=Hr:Min - ", time, ")", e                                                 ptoolcomment                                                 pbld, n, *sgcode, *sgplane, "G40", "G49", "G80", "G54", *sgabsinc, *smetric, e                                                 sav_absinc = absinc                                                         pcom_moveb                                                 absinc = zero                                                 pcan1, pbld, n, *sgcode, *sgabsinc, pwcs, pfxout, pfyout, *zr,        *speed, *spindle, pgear, strcantext, e                                                 pe_inc_calc                                                 ps_inc_calc                                                 absinc = sav_absinc                                                 pbld, n, sgabsinc, e        pretract #刀具路径末尾,换刀                                                 sav_absinc = absinc                                                 absinc = one                                                 sav_coolant = coolant                                                 coolant = zero                                                 #cc_pos is reset in the toolchange here                                                 cc_pos = zero                                                 gcode = zero                                                 pbld, n, sccomp, *sm05, e                                                 absinc = sav_absinc                                                 coolant = sav_coolant        peof0 #End of file for tool zero                                                 peof peof #End of file for non-zero tool                                                 pretract                                                 comment                                                 #Remove pound character to output first tool with staged tools # #if stagetool = one, pbld, n, *first_tool, e                                                 n, "M30", e                                                 "%", e pwcs #G54+ coordinate setting at toolchange        if workofs <> prv_workofs | (force_wcs & toolchng),        [        if workofs < 6,        [        g_wcs = workofs + 54        *g_wcs        ]        else,        [        p_wcs = workofs - five        "G54.1", *p_wcs        ]        ]        !workofs        pgear #Find spindle gear from lookup table                                                 if use_gear = one,        [        gear = frange (one, speed)        *gear        ] #换刀设置 pspindle #主轴转速计算 for RPM                                                 speed = abs(ss)                                                 if maxss = zero | maxss > max_speed, maxss = max_speed                                                 if speed > max_speed, speed = maxss                                                 if speed < min_speed, speed = min_speed                                                 spdir2 = fsg3(spdir) pq #Setup post based on switch settings                                                 if stagetool = one, bldnxtool = one                                                 if arctype = one | arctype = four,        [        result = newfs(two, i)        result = newfs(two, j)        result = newfs(two, k)        ]                                                 else,        [        result = newfs(three, i)        result = newfs(three, j)        result = newfs(three, k)        ] pheader #文件开始前调用                                                 if met_tool = one, #米制常量和变量调整        [        ltol = ltol_m        vtol = vtol_m        maxfeedpm = maxfeedpm_m        ] ptoolend #刀具路径末尾,读取新刀具资料之前                                                 !speed, !spdir2 ptlchg1002 #Call at actual toolchange, end last path here                                                 pspindle                                                 if gcode = 1000,        [        #Null toolchange        ]                                                 else,        [        #Toolchange and Start of file        if gcode = 1002,        [        #Actual toolchange        pretract        ]        if stagetool = one, prv_next_tool = m_one        prv_xia = vequ(xh)        prv_feed = c9k        ]
 楼主| 发表于 2004-2-16 22:09:00 | 显示全部楼层 来自: 中国湖北襄阳
把这一段修该一下就可以把圆角刀的圆角R也加上去 # -------------------------------------------------------------------------- fmt "TOOL:" 4 tnote # 注释格式 fmt " DIA. OFF:" 4 toffnote # 注释格式 fmt " LEN.:" 4 tlngnote # 注释格式 fmt " DIA.:" 1 tldia # 注释格式 # -------------------------------------------------------------------------- # Tool Comment / Manual Entry Section 刀具注释/手工输入部分 # -------------------------------------------------------------------------- ptoolcomment #Comment for tool                                                 tnote = t                                                 toffnote = tloffno                                                 tlngnote = tlngno                                                 "(", *tnote, *tldia, *sopnote, "", e pstrtool #Comment for tool                                                 if strtool <> sblank,        [        strtool = ucase(strtool)        *strtool, " "        ] pcomment #Comment from manual entry (must call pcomment2 if booleans)                                                 pcomment2 pcomment2 #Comment from manual entry                                                 scomm = ucase (scomm)                                                 if gcode = 1007, "(", scomm, ")"                                                 else, "(", scomm, ")", e 该成: # -------------------------------------------------------------------------- fmt "TOOL:" 4 tnote # 注释格式 fmt " DIA. OFF:" 4 toffnote # 注释格式 fmt " LEN.:" 4 tlngnote # 注释格式 fmt " DIA.:" 1 tldia # 注释格式 fmt " R - " 4 tcr # 注释格式 # -------------------------------------------------------------------------- # Tool Comment / Manual Entry Section 刀具注释/手工输入部分 # -------------------------------------------------------------------------- ptoolcomment #Comment for tool                                                 tnote = t                                                 toffnote = tloffno                                                 tlngnote = tlngno                                                 "(", *tnote, *tldia, *sopnote, *tcr,")", e pstrtool #Comment for tool                                                 if strtool <> sblank,        [        strtool = ucase(strtool)        *strtool, " "        ] pcomment #Comment from manual entry (must call pcomment2 if booleans)                                                 pcomment2 pcomment2 #Comment from manual entry                                                 scomm = ucase (scomm)                                                 if gcode = 1007, "(", scomm, ")"                                                 else, "(", scomm, ")", e [glow=255,red,2]文字[/glow]
 楼主| 发表于 2004-2-16 22:06:00 | 显示全部楼层 来自: 中国湖北襄阳
[fly]# -------------------------------------------------------------------------- # Canned Text # -------------------------------------------------------------------------- pcan #Canned text - before output call                                                 strcantext = sblank                                                 if cant_no > zero,        [        if cant_pos1 = zero, pcant_1        if cant_pos2 = zero, pcant_2        if cant_pos3 = zero, pcant_3        if cant_pos4 = zero, pcant_4        if cant_pos5 = zero, pcant_5        if cant_pos6 = zero, pcant_6        if cant_pos7 = zero, pcant_7        if cant_pos8 = zero, pcant_8        if cant_pos9 = zero, pcant_9        if cant_pos10 = zero, pcant_10        pbld, n, strcantext, e        strcantext = sblank        ] pcan1 #Canned text - with move                                                 strcantext = sblank                                                 if cant_no > zero,        [        if cant_pos1 = one, pcant_1        if cant_pos2 = one, pcant_2        if cant_pos3 = one, pcant_3        if cant_pos4 = one, pcant_4        if cant_pos5 = one, pcant_5        if cant_pos6 = one, pcant_6        if cant_pos7 = one, pcant_7        if cant_pos8 = one, pcant_8        if cant_pos9 = one, pcant_9        if cant_pos10 = one, pcant_10        ]                                                 if cstop, strcantext = strcantext + sm00                                                 if cgstop, strcantext = strcantext + sm01                                                 #Output of strcantext occurs at the end of the output line pcan2 #Canned text - after output call                                                 strcantext = sblank                                                 if cant_no > zero,        [        if cant_pos1 = two, pcant_1        if cant_pos2 = two, pcant_2        if cant_pos3 = two, pcant_3        if cant_pos4 = two, pcant_4        if cant_pos5 = two, pcant_5        if cant_pos6 = two, pcant_6        if cant_pos7 = two, pcant_7        if cant_pos8 = two, pcant_8        if cant_pos9 = two, pcant_9        if cant_pos10 = two, pcant_10        pbld, n, strcantext, e        strcantext = sblank        ] pcant_1 #Canned text - output call                                                 cantext = cant_val1                                                 pcant_out pcant_2 #Canned text - output call                                                 cantext = cant_val2                                                 pcant_out pcant_3 #Canned text - output call                                                 cantext = cant_val3                                                 pcant_out pcant_4 #Canned text - output call                                                 cantext = cant_val4                                                 pcant_out pcant_5 #Canned text - output call                                                 cantext = cant_val5                                                 pcant_out pcant_6 #Canned text - output call                                                 cantext = cant_val6                                                 pcant_out pcant_7 #Canned text - output call                                                 cantext = cant_val7                                                 pcant_out pcant_8 #Canned text - output call                                                 cantext = cant_val8                                                 pcant_out pcant_9 #Canned text - output call                                                 cantext = cant_val9                                                 pcant_out pcant_10 #Canned text - output call                                                 cantext = cant_val10                                                 pcant_out pcant_out #Canned text - build the string for output                                                 #Assign string select type outputs                                                 if cantext = three, bld = one                                                 if cantext = four, bld = zero                                                 #Build the cantext string                                                 if cantext = one, strcantext = strcantext + sm00                                                 if cantext = two, strcantext = strcantext + sm01                                                 if cantext > four,        [        strtextno = no2str(cantext)        strcantext = strcantext + strm + strtextno        ] # -------------------------------------------------------------------------- # 坐标计算,通常不需要修改 # -------------------------------------------------------------------------- pxyzcout #Map coordinates        xabs = vequ (x)        feed = fr_pos        if feed > maxfeedpm, feed = maxfeedpm #Incremental calculations ps_inc_calc #Incremental calculations, start                                                 xia = fmtrnd(xabs)                                                 yia = fmtrnd(yabs)                                                 zia = fmtrnd(zabs)                                                 xinc = vsub (xia, prv_xia)                                                          pe_inc_calc #Incremental calculations, end                                                 !xia, !yia, !zia                                                 !x, !y, !z                                          # -------------------------------------------------------------------------- # Numbered questions for Mastercam Version 8 # -------------------------------------------------------------------------- 38. 快速进给率? 300.0 #76. 配置文件名? 80. 接收和发送的通信端口号 (1 or 2) ? 2 81. 传输速率 (110,150,300,600,1200,2400,4800,9600,14400,19200,38400)? 9600 82. 奇偶校验 (E/O/N)? E 83. 数据位 (7 or 8)? 7 84. 停止位 (1 or 2)? 2 85. Strip line feeds? N 86. 每行末延迟(秒)? 0 87. Ascii, Eia, or Binary (A/E/? A 88. Echo keyboard to screen in terminal emulation? n 89. Strip carriage returns? N 90. NC和材料文件所处的磁盘和目录? 91. 执行的后置处理器名? MP 92. 反向处理器名(nic->nc)? RP 93. 反向处理 PST 文件名? RPFAN 100. 序号之小数点前的位数? 3 101. 序号之小数点后的位数? 0 103. 最大的主轴转数? 6000 107. 换刀平均时间(seconds)? 2.0 #110. 默认的刀具库? TOOLS.TL8 158. 挖槽精加工时使用磨损补偿? n 159. Compensate the first and last point in cutter comp. in control simulation? y 160. Display first and last entity in toolpath when simulating cutter compensation in control? y 161. 打开机械原点按钮? y 162. 打开参考点按钮? y 163. 打开杂项变数按钮? y 164. 打开旋转轴按钮? n 165. 打开刀具平面按钮? y 166. 打开构图平面按钮? y 167. 打开刀具显示按钮? y 168. Check tplane during automatic work origin creation? y                                                         #在自动工作原点建立时检查刀具平面 # -------------------------------------------------------------------------- # 定义杂项实数值 # -------------------------------------------------------------------------- 201. Default miscellaneous real variable 1 (mr1)? 0.0 202. Default miscellaneous real variable 2 (mr2)? 0.0 203. Default miscellaneous real variable 3 (mr3)? 0.0 204. Default miscellaneous real variable 4 (mr4)? 0.0 205. Default miscellaneous real variable 5 (mr5)? 0.0 206. Default miscellaneous real variable 6 (mr6)? 0.0 207. Default miscellaneous real variable 7 (mr7)? 0.0 208. Default miscellaneous real variable 8 (mr8)? 0.0 209. Default miscellaneous real variable 9 (mr9)? 0.0 210. Default miscellaneous real variable 10 (mr10)? 0.0 # -------------------------------------------------------------------------- # 定义杂项整数值 # -------------------------------------------------------------------------- 301. 工作坐标系 [0-1=G92, 2=G54's] (mi1)? 2 302. 绝对或增量 [0=ABS, 1=INC] (mi2)? 0 303. 参考点回归 [0=G28, 1=G30] (mi3)? 0 304. 杂项整数变量 4 (mi4)? 0 305. 杂项整数变量 5 (mi5)? 0 306. 杂项整数变量 6 (mi6)? 0 307. 杂项整数变量 7 (mi7)? 0 308. 杂项整数变量 8 (mi8)? 0 309. 杂项整数变量 9 (mi9)? 0 310. 杂项整数变量 10 (mi10)? 0 # -------------------------------------------------------------------------- # 配置文件关联参数 (缺省为 "y" # -------------------------------------------------------------------------- #400. 关联的配置文件名? 401. 读取系统颜色部分? y 402. 读取配置部分地区? y 403. 读取公差部分? y 404. 读取资料路径部分? y 405. 读取通信部分? y 406. 读取绘图设置部分? y 407. 读取杂项部分? y 408. 读取 NC-设置部分? y 409. 读取 DIALOG SCRIPTS 部分? y 410. 读取DESIGN设置部分? y 411. 读取打印设置部分? y 412. 读取 ALT-KEY 分配部分? y 413. 读取CAD部分? y 414. 读取 载入/离开 部分? y 415. 读取 荧屏 部分? y 416. 读取文件名部分? y 1500. Chook to execute from 'Misc. values' button? y 1501. 插入参数信息到 ascii NCI? n 1502. 写入操作信息到二进制文件 (.ops)? n [/fly]
 楼主| 发表于 2004-2-16 21:52:00 | 显示全部楼层 |阅读模式 来自: 中国湖北襄阳
Mastercam系统配置的是适应单一类型控制系统的通用后置处理,该后置处理提供了一种功能数据库模型,用户根据数控机床和数控系统的具体情况,可以对其数据库进行修改和编译,定制出适应某一数控机床的专用后置处理程序。 Mastercam系统后置处理文件的扩展名为PST,称为PST文件,它定义了切削加工参数、NC程序格式、辅助工艺指令,设置了接口功能参数等,其结构由八个部分组成: 1. 注解 程序每一列前有“#”符号表示该列为不影响程序执行的文字注解。如: # mi2-Absolute, or Incremental positioning 0=absolute 1=incremental 表示mi2定义编程时数值给定方式,若mi=0为绝对值编程,mi=1为增量值编程。 在这一部分里,定义了数控系统编程的所有准备功能G代码格式和辅助功能M代码格式。 2. 程序纠错 程序中可以插入文字提示来帮助纠错,并显示在屏幕上。如: # Error messages (错误信息) psuberror # Arc output not allowed "ERROR-WRONG AXIS USED IN AXIS SUBSTITUTION", e 如果展开图形卷成旋转轴时,轴替换出错,则在程序中会出现上面引号中的错误提示。 3. 定义变量的数据类型、使用格式和常量赋值 如规定G代码和M代码是不带小数点的两位整数,多轴加工中心的旋转轴的地址代码是A、B和C,圆弧长度允许误差为0.002,系统允许误差为0.00005,进给速度最大值为10m/min等。 4. 定义问题 可以根据机床加工需要,插入一个问题给后置处理程序执行。 如定义NC程序的目录,定义启动和退出后置处理程序时的C-Hook程序名。 5. 字符串列表 字符串起始字母为s,可以依照数值选取字符串,字符串可以由两个或更多的字符来组成。 字符串sg17,表示指定XY加工平面,NC程序中出现的是G17,scc1表示刀具半径左补偿,NC程序中出现的是G41,字符串sccomp代表刀具半径补偿建立或取消。 6. 自定义单节 可以让使用者将一个或多个NC码作有组织的排列。 自定义单可以是公式、变量、特殊字符串等: pwcs # G54+ coordinate setting at toolchange if mil >1, pwcs_g54 表示用pwcs单节指代#G54+在换刀时坐标设定值,mil定义为工件坐标系(G54~G59) 7. 预先定义的单节 使用者可按照数控程序规定的格式将一个或多个NC代码作有组织的排列,编排成一条程序段。 8. 系统问答 后置处理软件提出了五组问题,供使用者回答,可按照注解文字、赋值变量、字符串等内容,根据使用的机床、数控系统进行回答。 设计后置处理文件,一般是按照NC程序的结构模块来进行。根据NC程序的功能,后置处理文件分成六个模块如下: 1. 文件头 文件头部分设定程序名称和编号,此外,SINUMERIK 810D系统还必须指定NC程序存放路径,并按照以下格式输出: “%_N_(程序名及编号)_(路径)”。 NC程序可存放在主程序、子程序和工作程序目录下,扩展名分别为:MPF、SPF、WPD,一般放在工作程序目录下。因此经修改的Pst文件格式为: Pheader # Start of file " %_N_", progname, "_WPD" (程序名、存放目录) 2. 程序起始 在程序开始,要完成安全设定、刀具交换、工件坐标系的设定、刀具长度补偿、主轴转速控制、冷却液控制等,并可显示编程者、编程日期、时间等注解。 修改后的有刀具号Pst文件开头格式如下: # Start of file for non-zero tool number ...... pspindle (主轴转速计算) pcom_movbtl (移动设备) ptoolcomment (刀具参数注解) ...... pbld, n, *sgcode, *sgplane, "G40", "G80", *sgabsinc (快进、XY加工平面、取消刀补、取消固定循环、绝对方式编程) if mil <=one, pg92_rtrnz, pg92_rtrn, pg92_g92 (返回参考点) ...... pbld, n, *sgcode, *sgabsinc, pwcs, pfxout, pfyout, pfcout, *speed, *spindle, pgear, pcan1 (快进至某位置、坐标系编置、主轴转速等) pbld, n, pfzout, *tlngno, scoolant, [ if stagetool=one, *next_tool] (安全高度、刀长补偿、开冷却液) pcom_movea (加工过程) 3. 刀具交换 刀具交换执行前,须完成返回参考点、主轴停止动作,然后换刀,接着完成刀具长度补偿、安全设定、主轴转速控制。 Pst文件中用自定义单节ptlchg指代换刀过程,编辑修改后的程序如下: Ptlchg # Tool change ...... ptoolcomment (新刀参数注解) comment (插入注解) if stagetool <> two, pbld, n, *t, e (判断、选刀) n, "M6" (换刀) pindex (输出地址) pbld, n, *sgcode, *sgabsinc, pwcs, pfxout, pfyout, pfcout, *speed, *spindle, pgear, pcan1 (快进至某位置、坐标系偏置、主轴转速等) pbld, n, pfzout, *tlngno, "M7", [if stagetool=one, *next_tool] (安全高度、刀长补偿号、开冷却液) pcom_movea (加工过程) 4. 加工过程 这一过程是快速移动、直线插补、圆弧插补、刀具半径补偿等基本加工动作。 对于几乎所有系统,这些加工动作的程序指令基本相同。只是注意SINUMERIK 810D系统的刀具长度补偿值由字母D后加两位数字调用,不需要G43/G44指令;而半径补偿值则由G41/G42调用,不需要再接地址代码。用G40取消刀具长度和刀具半径补偿。 5. 切削循环 Mastercam软件提供了6种内定的孔加工固定循环方式:一般钻削(Drill/Cbore)、深孔啄钻(Peck Drill)、断屑钻(Chip Break)、右攻丝(Tap)、精镗孔(Bore#1)、粗镗孔(Bore #2),通过杂项选项(Misc #1/Misc #2)可设定左攻丝、背镗孔、盲孔镗孔、盲孔铰孔等循环,并采用G73~G89代码来表示。 如对于深孔钻削固定循环,Mastercam采用的格式为:G83 X_Y_Z_R_Q_F;而SINUMERIK 810D系统用CYCLE83指代深孔钻削循环,其NC程序要求给出循环加工所有参数,输出格式为: CYCLE83(RTP,RFP,SDIS,DP,DPR,FDEP,FDPR,DAM,DTB,DTS,FRF,VARI) 在pst文件中需按SINUMERIK 810D系统格式进行定义、修改和编写。 6. 程序结尾 程序结尾一般情况下是取消刀补、关冷却液、主轴停止、执行回参考点,程序停止等动作。下面是修改后的pst程序结尾: Ptoolend_t #End of tool path, toolchange ...... pbld, n, sccomp, "M5", *scoolant, e (取消刀补、主轴停止、关冷却液) pbld, n, *sg74, "Z1=0. X1=0. Y1=0.", e (返回参考点) if mi2=one, pbld, n, *sg74, "X1=0.", "Y1=0.", protretinc, e else, protretabs (程序结束)
 楼主| 发表于 2004-2-16 21:58:00 | 显示全部楼层 来自: 中国湖北襄阳
例子中文说明:[转贴] # POST 名称 : wgkG54 # 类型 : MILL # 机床名称 : GENERIC FANUC # 控制器名称 : GENERIC FANUC # 描述 : GENERIC FANUC 3 AXIS MILL POST # Associated Post : NONE # 车/铣复合 : NO # 4-axis/Axis subs. : NO # 五轴 : NO # 子程序支持 : NO # 自动换刀 : NO # 工作坐标系 : G54 # Executable : MP 8.00 # # # # 这个POST支持FANUC控制器普通三轴铣床的的G 代码输出, # 不支持自动换刀,有最大圆弧报警 # 它来源于MP-EZ.PST # 是针对Mastercam Mill V8的特征而设计的 # # # -------------------------------------------------------------------------- # 修改日志: # -------------------------------------------------------------------------- # Programmers Note: # CNC 05/01/00 - Initial post setup, jce # 2002-10-11 - 去掉自动换刀,xxx # 2002-10-12 - 增加中文注释,xxx # 2002-10-21 - 增加最大圆弧警告,xxx # 2002-11-05 - 修改坐标系为G54,xxx # -------------------------------------------------------------------------- # 特征: # -------------------------------------------------------------------------- # # # 下列 Misc.(杂项) 必须使用整数: # # mi2 - 绝对或增量坐标 at top level # 0 = 绝对 # 1 = 增量 # # mi3 - 选择G28或G30来执行参考点回归. # 0 = G28, 1 = G30 # # Canned text: # 在轮廓点里插入"cantext".以允许/禁止 下列Mastercam里许可的功能, # Entering cantext on a contour point from within Mastercam allows the # following functions to enable/disable. # Cantext 值: # 1 = Stop = 输出 "M00" 停止码 # 2 = Ostop = 输出 "M01" 选择停止码 # 3 = Bld on = 在 NC 单节打开 单节删除码(\) # 4 = bLd off = 在 NC 单节关闭 单节删除码(\) # # # 钻孔: # 在这个 POST 里支持所有的钻孔方法. # # 附加注意事项: # 1) G54 calls are generated where the work offset entry of 0 = G54, # 1 = G55, etc. # 2) 由NCI变量"met_tool"决定是否使用米制 # # 3) 以增量方式从换刀起始位置计算运动量. # 起始位置通常定义为所有换刀时刀具所处的最后位置 # Incremental mode calculates motion from home position at toolchanges. # The home position is used to define the last position of the tool # for all toolchanges. # 4) 变量 'absinc' 现已被预先定义, 设定 mi2 (杂项整数)以定义 # 绝对/增量程序输出. # # -------------------------------------------------------------------------- # Debugging and Factory Set Program Switches 调试和加工设置程序切换 # -------------------------------------------------------------------------- m_one : -1 #定义常数 zero : 0 #定义常数 one : 1 #定义常数 two : 2 #定义常数 three : 3 #定义常数 four : 4 #定义常数 five : 5 #定义常数 c9k : 9999 #定义常数 fastmode : 1 #Posting 速度最佳化 bug1 : 2 #0=不显示, 1=普通列表框, 2=编辑器 bug2 : -30 #Append postline labels, non-zero is column position? bug3 : 0 #Append whatline no. to each NC line? bug4 : 1 #Append NCI line no. to each NC line? whatno : yes #不执行 whatline branches(分枝)? (leave as yes) get_1004 : 1 #Find gcode 1004 with getnextop? rpd_typ_v7 : 0 #Use Version 7 style contour flags/processing? strtool_v7 : 2 #Use Version 7+ toolname? tlchng_aft : 2 #Delay call to toolchange until move line cant_tlchng : 1 #忽视 cantext 入口 on move with tlchng_aft newglobal : 1 #全局变量错误检测 getnextop : 0 #建立下一个变量表 # -------------------------------------------------------------------------- # 一般输出设置 # -------------------------------------------------------------------------- sub_level : 1 #允许自动子程序支持 breakarcs : no #在各象限分割圆弧 arcoutput : 0 #0= IJK,1= R不带符号,2= R (超过180度时带负号) arctype : 2 #圆弧中心 1=abs, 2=St-Ctr, 3=Ctr-St, 4=unsigned inc. arccheck : 1 #检测小圆弧,转化为直线 atol : .01 #arccheck=2时的角度公差 ltol : .002 #arccheck=1时的长度公差 vtol : .0001 #系统公差 maxfeedpm : 500 #进给速度极限 (英寸/分钟) ltol_m : .05 #arccheck=1时的长度公差,米制 vtol_m : .0025 #系统公差,米制 maxfeedpm_m : 10000 #进给速度极限 毫米/分钟 force_wcs : yes #每次换刀时强制输出WCS spaces : 1 #各指令之间插入的空格数 omitseq : no #省略序号 seqmax : 9999 #最大序号 stagetool : 0 #0 = 无预先备刀, 1 = 预备刀具 use_gear : 0 #输出齿轮交换代码,0=no,1=yes max_speed : 6000 #最大主轴转速 min_speed : 1 #最小主轴转速 nobrk : no #Omit breakup of x, y & z rapid moves progname : 1 #使用大写字母表示程序名 max_arc : 50000 #机床允许的最大圆弧半径 # -------------------------------------------------------------------------- # 旋转轴设定 # -------------------------------------------------------------------------- vmc : 1 # 0 = 卧式 , 1 = 立式 # -------------------------------------------------------------------------- # 允许钻孔固定循环功能 # -------------------------------------------------------------------------- usecandrill : yes #使用普通钻孔固定循环 usecanpeck : yes #使用啄式钻孔固定循环 usecanchip : yes #使用断屑钻孔固定循环 usecantap : yes #使用攻螺纹固定循环 usecanbore1 : yes #使用镗孔固定循环1 usecanbore2 : yes #使用镗孔固定循环2 usecanmisc1 : yes #使用杂项固定循环1 usecanmisc2 : yes #使用杂项固定循环2 # -------------------------------------------------------------------------- # 通用自定义变量初始化(不能改变!) # -------------------------------------------------------------------------- xia : 0 #Formated absolute value for X incremental calculations yia : 0 #Formated absolute value for Y incremental calculations zia : 0 #Formated absolute value for Z incremental calculations bld : 0 #单节删除激活 result : 0 #Return value for functions sav_spc : 0 #Save spaces sav_gcode : 0 #Gcode saved sav_absinc : 0 #Absolute/Incremental Saved Value sav_coolant : 0 #Coolant saved toolchng : 1 #On a toolchange flag spdir2 : 1 #Copy for safe spindle direction calculation #Drill variables drlgsel : -1 #Drill Select Initialize drillref : 0 #Select drill reference peckacel : 0 #Fractional percent to reduce peck2 when usecan.. : no drlgcode : 0 #Save Gcode in drill sav_dgcode : 0 #Drill gcode saved # -------------------------------------------------------------------------- # 格式列表 - n=nonmodal, l=leading, t=trailing, i=inc, d=delta # # -------------------------------------------------------------------------- #定义 英制/米制 坐标格式列表 fs2 1 0.7 0.6 #小数, absolute, 7 place, default for initialize ( fs2 2 0.4 l1.3 #小数, absolute, 4/3 place (x,y,z) fs2 3 0.4 l1.3d #小数, delta, 4/3 place (i,j,k) #Common format statements fs2 4 1 0 1 0 #整数, 无前缀 fs2 5 2 0 2 0l #整数, 强制两位前缀 fs2 6 3 0 3 0l #整数, 强制三位前缀 fs2 7 4 0 4 0l #整数, 强制四位前缀 fs2 9 0.1 0.1 #小数, absolute, 1 place fs2 10 0.2 0.2 #小数, absolute, 2 place fs2 11 0.3 0.3 #小数, absolute, 3 place fs2 12 0.4 0.4 #小数, absolute, 4 place fs2 13 0.5 0.5 #小数, absolute, 5 place fs2 14 0.3 0.3d #小数, delta, 3 place fs2 15 0.2 0.1 #小数, absolute, 2/1 place fs2 16 1 0 1 0n #整数, 强制输出 # 输出加工类型字符串定义 # -------------------------------------------------------------------------- # 字符串 - 字符串标签必须由 's' 开头,它们没有预先指派 # -------------------------------------------------------------------------- #Select operation note sop00 "NULL" # String definition sop01 "CONTOUR" # " " sop02 "CONTOUR" # " " sop03 "DRILL CYCLE" # " " sop04 "POCKET...." # " " sop05 "RULED....." # " " sop06 "2D-SWEPT.." # " " sop07 "3D-SWEPT.." # " " sop08 "REVOLVED.." # " " sop09 "LOFT......" # " " sop10 "COONS....." # " " sop11 "TRIM ....." # " " sop12 "FLOWLINE.." # " " sop13 "SURFACE_FINISH" # " " sop14 "SURFACE_ROUGH" # " " sop15 "POINT....." # " " sop16 "DRILL-5AX." sop17 "CURVE-5AX." sop18 "SWARF-5AX." sop19 "flat MILL" sop20 "op20?....." sopnote # Target string fstrsel sop00 opcode sopnote
发表于 2004-2-28 08:10:00 | 显示全部楼层 来自: 中国上海
非常有帮助,谢谢!
发表于 2004-3-16 19:21:00 | 显示全部楼层 来自: 中国辽宁沈阳
太感谢了!
2 H' |$ c3 _$ o4 [
5 z9 u1 e8 k% A! G
发表于 2004-3-24 10:58:00 | 显示全部楼层 来自: 中国福建莆田
好深奥,不过看看多少可以理解一点,多谢了
发表于 2004-4-1 17:56:00 | 显示全部楼层 来自: 中国浙江杭州
很有帮助,一般董C语言的都看的明白。
发表于 2004-4-8 22:20:00 | 显示全部楼层 来自: 中国广东深圳
有点乱.
 楼主| 发表于 2004-4-10 22:52:00 | 显示全部楼层 来自: 中国湖北襄阳
以下是引用lison在2004-4-8 22:20:47的发言:
8 j8 v1 s6 V4 z6 {. o8 H8 C有点乱.1 F  f7 u- f  B. n9 q
& S5 y( N8 j6 f: ]) H. g5 h/ R! s呵呵,最开始不是这样的,论坛修改后就成这样了。运行代码后看,注意安全第一吗" D9 z7 r# g4 r+ G( y
[此贴子已经被作者于2004-4-10 22:54:45编辑过]
0 o8 [5 H7 y, d9 b
发表于 2004-4-19 22:27:00 | 显示全部楼层 来自: 中国上海
好深奥啊。。。。。。
发表于 2004-6-27 09:07:00 | 显示全部楼层 来自: 中国福建厦门
辛苦了,楼主,谢谢.
发表于 2004-6-27 14:52:00 | 显示全部楼层 来自: 中国湖南岳阳
非常有帮助,谢谢!
发表于 2004-7-1 00:55:00 | 显示全部楼层 来自: 中国浙江宁波
请教斑竹:把MPFAN的后处理改了后的NC输出,槽内圆弧拐角是用数条直线凑成的,怎么没用上I,J,K或CT?我用的是西门子802D系统。
发表于 2004-7-15 15:19:00 | 显示全部楼层 来自: 中国江苏无锡
我公司的cnc在输入了mastercam程序后一直报错,手工修改麻烦的很,看来是后置处理的问题
发表于 2004-7-16 08:48:00 | 显示全部楼层 来自: 中国浙江绍兴
辛苦了!看起来不错!
 楼主| 发表于 2004-7-22 23:13:00 | 显示全部楼层 来自: 中国湖北襄阳
以下是引用xyyfc在2004-7-1 0:55:32的发言:
# B2 x6 [6 l& j6 [( W0 E- y) H" D' S
$ h! q1 S0 C+ ?( w: Z& q4 M请教斑竹:把MPFAN的后处理改了后的NC输出,槽内圆弧拐角是用数条直线凑成的,怎么没用上I,J,K或CT?我用的是西门子802D系统。
) y- E" r7 g9 e
发表于 2004-7-24 16:54:00 | 显示全部楼层 来自: 中国陕西西安
很有帮助,谢谢!!
发表于 2004-8-8 16:56:00 | 显示全部楼层 来自: 中国广东东莞
哦!谢谢.
发表于 2006-7-7 09:40:13 | 显示全部楼层 来自: 中国上海
好东西,正需要这方面的资料来学习
发表于 2006-7-10 18:00:52 | 显示全部楼层 来自: 中国浙江宁波
正在学习中,多谢很有帮助
发表于 2006-8-2 16:42:31 | 显示全部楼层 来自: 中国广东东莞
还没有学到这个程度,不过要多学习才是
