Sub falan()
5 L. ^! y; T- T/ |$ F- QDim centerp As Variant '中心坐标; o5 ^6 `& }0 Y$ s7 y# @
Dim templay As AcadLayer '定义临时层
0 Z( n: v; \; r E5 n3 KDim lay0 As AcadLayer '定义粗实线层
. O( O( E+ p9 WDim lay1 As AcadLayer '定义中心线层% C9 t9 _" y0 t6 b8 C" _! J2 R
Dim oldlay As AcadLayer '定义原来的层! ^ n& W( j% ]) l9 y2 F$ i
Dim ent As AcadCircle '定义对象/ U) u9 D$ H v# o# O, L2 [
On Error Resume Next) t5 k5 s# d: L4 y
wj = ThisDrawing.Utility.GetReal("外径(0~10000)<520>") '输入外径尺寸% n" S% x+ T- ^# @& J' A
If Err.Number <> 0 Then '用户输入的不是有效的数字
; U$ |9 @5 X9 e: b ?# d* @ S wj = 520
, }1 q; N8 M Y+ s0 v6 J$ v Err.Clear '清除错误 A% j0 k3 O6 o, t7 w. W
End If
) v7 Z2 U2 k& z6 u7 F9 snj = ThisDrawing.Utility.GetReal("内径(0~10000)<380>") '输入内径尺寸
9 q. l* s( w! A( d/ B* BIf Err.Number <> 0 Then '用户输入的不是有效的数字
, e' Z! r; z4 l" U3 \5 U nj = 380/ V3 L0 @4 e: [6 f9 d
Err.Clear '清除错误, y' s- e7 }' C& l% ]
End If4 E+ K) t; b# p9 n9 J: p
zxj = ThisDrawing.Utility.GetReal("周围孔中心直径(0~10000)<480>") '输入周围孔中心直径尺寸
# Z& a) I5 P$ zIf Err.Number <> 0 Then '用户输入的不是有效的数字
8 R# C& V4 j- r; L zxj = 480
( B8 t+ `' S% b7 z% r Err.Clear '清除错误
9 B* O1 L# y; A7 z2 N& YEnd If
- @. K/ }3 ?5 V X' Okj = ThisDrawing.Utility.GetReal("周围孔径(0~100)<24>") '输入周围孔径尺寸$ L9 v+ H, m( r5 n. A \" o6 ?
{) `0 @' W2 c! L6 L6 Q kj = 24) o/ M, Z+ b& u$ f c3 M3 t
Err.Clear '清除错误
2 X2 O; u( T9 y# \/ k* {! gEnd If' ^& d* O3 X, Q# Q/ ?; y8 R) x& M& ^
kgs = ThisDrawing.Utility.GetInteger("周围孔个数(0~100)<12>") '输入周围孔个数' H) R# C% v1 c2 \ l
If Err.Number <> 0 Then '用户输入的不是有效的数字, K9 f+ k( Y2 g1 c! H
kgs = 12
) y* e( M) A* R+ Z Err.Clear '清除错误
% a. o% p& A, \* X8 j: ?End If' R3 i! w3 l. F4 @
kgs = kgs + 1
9 }# E! r9 w$ ? Kcenterp = ThisDrawing.Utility.GetPoint(, "定位法兰中心:") '设定中心坐标
. n: d2 l) d. s( s gSet oldlay = ThisDrawing.ActiveLayer '记住当前图层
/ M3 L X! g6 Y9 N* G. y- VFor Each templay In ThisDrawing.Layers '查找图层名为1的图层. y4 h/ h( ~ E% B
If templay.Name = "1" Then
$ ]; W4 d; J" ?, c% q9 h. n Set lay0 = templay '找出图层名为1的为粗线层" h' U1 b, \; B9 B
End If9 K* S4 F3 X8 E% I; O' Z' \1 P
If templay.Name = "0" Then1 q# T& H0 ~9 c& j1 H1 i6 q! {
Set lay1 = templay '找出图层名为0的为中心线层( J7 E9 ~" o6 T
End If/ _% C7 L* r7 ^( q" D+ Q
Next templay
+ ~: q! e; X4 n 7 G8 F( `" Y% Y8 V! ^
ThisDrawing.ActiveLayer = lay0 '把当前图层设为粗线层
1 W/ D0 O8 _* a/ WCall ThisDrawing.ModelSpace.AddCircle(centerp, wj / 2) '画外圆圈1 r( u/ W0 t1 a6 c. y7 d6 q; a
Call ThisDrawing.ModelSpace.AddCircle(centerp, nj / 2) '画内圆圈
1 o- X0 F, J4 p& N2 T5 NSet ent = ThisDrawing.ModelSpace.AddCircle(centerp, kj / 2) '画一个小孔. x4 t/ w d M
Dim centerm(0 To 2) As Double '移动坐标
7 R9 w6 i0 M8 E7 {) J$ Q0 P" fcenterm(0) = centerp(0): centerm(1) = centerp(1) + zxj / 2: centerm(2) = centerp(2)
0 I& P0 q3 b% p% E4 X. `- ~
, Z) b1 a; Z; w$ gDim rent As Variant
0 p: B( n- j. {2 d! b) n# l' N2 hent.Move centerp, centerm
6 @8 u d) T7 Y% A'rent = ent.ArrayPolar(kgs, 2 * pi, centerp)
3 x( Q2 @; D9 nent.ArrayPolar kgs, 2 * 3.1415926, centerp
: f. y0 t* Z9 i% v+ u5 C: V/ p4 [, K5 o& E
ThisDrawing.ActiveLayer = lay1 '把当前图层设为中心线层7 `1 z& |$ b- r( o& [
Call ThisDrawing.ModelSpace.AddCircle(centerp, zxj / 2) '画外圆圈/ M* o& [- J3 y4 ]1 {4 [3 w2 h
Dim clpoint1(0 To 2) As Double '坐标
% P6 D# C+ ?4 @ f/ g) C6 hDim clpoint2(0 To 2) As Double '坐标# o3 j9 H2 U1 b6 D9 j/ c
clpoint1(0) = centerp(0) - 10 - wj / 2: clpoint1(1) = centerp(1): clpoint1(2) = centerp(2)
' [4 F/ i! u7 c; J5 V. @clpoint2(0) = centerp(0) + 10 + wj / 2: clpoint2(1) = centerp(1): clpoint2(2) = centerp(2): g+ S3 a# y" V& L9 }2 G. P; d ?
Call ThisDrawing.ModelSpace.AddLine(clpoint1, clpoint2)
1 E( `; V9 N4 |3 c& Iclpoint1(0) = centerp(0): clpoint1(1) = centerp(1) - 10 - wj / 2: clpoint1(2) = centerp(2)
" Z" q2 G! b- O, }0 ~clpoint2(0) = centerp(0): clpoint2(1) = centerp(1) + 10 + wj / 2: clpoint2(2) = centerp(2)
m0 y9 \7 b! ^! zCall ThisDrawing.ModelSpace.AddLine(clpoint1, clpoint2)8 a' a3 T" h) e* h& _: j
clpoint1(0) = centerp(0): clpoint1(1) = ent.Center(1) - 10 - kj / 2: clpoint1(2) = centerp(2)
+ `! A3 K* n$ o2 y' Q) wclpoint2(0) = centerp(0): clpoint2(1) = ent.Center(1) + 10 + kj / 2: clpoint2(2) = centerp(2): a- v7 ^+ [% u$ K0 l
Dim lent As AcadLine
2 G; B4 {" \* Q+ d8 {Set lent = ThisDrawing.ModelSpace.AddLine(clpoint1, clpoint2)+ o. W/ G' _/ G- }( F2 h
lent.ArrayPolar kgs, 2 * 3.1415926, centerp6 y. W3 Q Z: {- F3 @- Q6 s
lent.Delete- w* L1 e" D9 `! J. z9 T( `
ent.Delete
4 e# h- l' A& iThisDrawing.ActiveLayer = oldlay '把当前图层还原
: ~3 s4 y/ }: b" v5 b# S1 eZoomExtents '显示整个图形4 ^9 {6 d' x5 M& i3 [
End Sub |
