查看: 1288|回复: 0
[书籍] 《Adhesion of Polymers聚合物粘度》
发表于 2008-7-20 15:08:17 | 显示全部楼层 |阅读模式 来自: 中国山东德州
作者:Vladimir Kestelman, Roman Veslovsky
  \: L7 E0 r  c( N- v/ m8 u/ g- hHardcover: 397 pages
! U0 B: K* F& s$ P+ O6 G; iPublisher: McGraw-Hill Professional; 1 edition (December 5, 2001)
+ {% I  {) M$ j3 s* Q# vLanguage: English
* \3 I: F2 A" l6 k9 p; V# MISBN-10: 0071370455
& @) W( c  ~6 j0 QISBN-13: 978-0071370455
' e$ P! J( h& ^$ ?Product Dimensions: 9.2 x 6 x 1.3 inches   N! G7 E3 S  ?, L0 ]( j4 K( V
Book Description7 H  B/ j$ w% r. I1 Y! P! _5 s
Current applications for bonding and sealing are expensive and time-consuming. Adhesion of Polymers presents a state-of-the-art method for improving bonds and sealing strength between different materials underwater and in the human body. This time- and cost-efficient technology will allow engineers to create or repair stronger seals in underwater pipes, repair ships at sea, even bond and seal tissues in the body
: x9 X- u( |" G& p+ V9 K1 \
共3个压缩卷,解压后5.23M
1 `0 ?' V: h) [7 @0 t4 Y0 M7 QChapter 1. The Process of Adhesive-Bonded Joint Formation 15 t0 g: b, n0 O5 b  s/ C
Chapter 2. Adhesive Properties Control by Surface-Active Substances 22
: _0 p; ~$ ^  T0 m1 W2.1 Alteration of Properties of Polymeric Composites under the Influence of. l1 Z  ~. L$ s' |
Surface-Active Substances 228 s8 g1 u0 ]9 F- B1 d7 [
2.2 Colloid-Chemical Properties of Surfactants in Heterochain Oligomers 25
7 b0 E. c" C! L' Q2.3 Surface Tension of Heterochain Oligomers with Surfactant Additives 33! p, z, y$ [( X8 h7 X
2.4 Surface Tension of CuringOligomers 38
* R2 ], B. }' j2 K. M2.5 Effect of Surface-Active Substances on the Thermodynamic and Physical-' n: P3 W  \  F  ?* V
Chemical Properties of Solid Polymers 45
' X2 {7 {0 O9 S  I/ f2.6 Oligomer–Metal Interphase Tension 60
- t& V4 m0 a/ o  f) G9 z2.7 Control of Polymer Adhesion Strength by Means of Surfactant 67
2 {; @$ [5 c# j5 H. k' A2.8 Influence of Surfactants on the Structure of Polymers 74) L% E. S! e# }7 [/ [3 F
2.8.1 Influence of Surfactants on the Structure of Polyurethanes 74# t8 z4 D* }" @2 @# S* X8 _
2.8.2 Influence of Surfactants on the Structure of Polyepoxides 81
9 ~1 M: S8 n9 i; M1 t: {& D- a4 n2.8.3 Influence of Surfactants on CuringProcesses and Structure of
5 c! `% x, p! H8 z, iUnsaturated Polyesters 89' I( |2 C% d2 a' M
Chapter 3. Properties of Adhesives Based on Polymeric Mixtures 987 P3 Q. @# _2 u
3.1 General 98
! k+ p. F- {& Y, o8 ]+ s3.2 Adhesives Based on InterpenetratingPolymer Networks 102: T4 h7 E. h  Q1 a
3.2.1 Properties of Sprut-5M Adhesive-Based Reinforced Coatings 109) g+ h2 ^% j" z  y6 H  @
3.3 Adhesives Based on Thermodynamically Incompatible Polymeric
* r/ }9 H+ d# e1 C. o: d, @  P; `' uMixtures 112
6 E' S6 L+ f1 C) q' i3.3.1 Adhesives Based on Acrylic Polymer Mixtures 112
; d0 _% p1 {7 M: t3.3.2 Controllingthe Properties of Adhesives Based on Epoxy Rubber
9 A* m/ P+ C# |. _3 Y" hPolymeric Mixtures 128& e  [& h0 l8 ^' Q5 ~# o( w
3.3.3 Modification of EP-20 Epoxy-Diane Resin by Epoxided
$ d& q* X4 ^/ q1 yPolypropylene Glycol (Laproxides 503M and 703) 160+ B" {2 i, L/ t8 t
3.3.4 Influence of Surfactants on Structure and Properties of
- M& S6 t( N/ [% TPolyurethanes Based on Oligomer Mixtures 164  p6 ]$ F6 M3 ?1 k5 ~# R
3.4 Organo-Mineral Composites 202
) B3 a4 ~4 w( }1 g9 T0 q+ g
....................../ ^! y6 E) I$ `) R; B) u
& E/ S( G  P, }9 i6 R. R$ ^) {# O
Veslovsky R[1].A., Kestelman V.N. - Adhesion of Polymers. (McGraw-Hill 2002).part1.rar
1.91 MB, 下载次数: 15
Veslovsky R[1].A., Kestelman V.N. - Adhesion of Polymers. (McGraw-Hill 2002).part2.rar
1.91 MB, 下载次数: 14
Veslovsky R[1].A., Kestelman V.N. - Adhesion of Polymers. (McGraw-Hill 2002).part3.rar
1.14 MB, 下载次数: 14
