dimensions of shaft : diameter 49mm,length 300mm;
# }3 U7 s6 \& c5 k6 p+ I
5 [" b, c N) e" u X2 bshape: cylindrical;
5 H0 O! X* q0 \3 E% b- i, v1 Q1 `" r% L5 j" H4 N8 U
material mark: 42CrMo;2 W/ ]$ G- o( b% d3 N
' {4 D9 G' }# }8 ]2 s* q; C
heat treatment condition: unknown
P9 ?8 n' @7 Z2 j4 E1 U
# p/ S7 i' H( V8 O9 O& S7 x" itest requirement: broken torsion.(remark: fix an arbitary end, and rotate the other end until the shaft break. record the maximum torsion before the failure of shaft. )& }* I" H6 n' A. `3 V
9 R- S4 Y8 n4 B7 V7 U: R, T, |where can this test be performed? how much one pcs?
, w' Y Z" O2 v3 k/ `# H4 L% A4 B% F$ U2 f
if you need more detailed information concerning to this test, please let me know. |
