查看: 2059|回复: 2
[书籍] Selection of Polymeric Materials英文电子书3本
发表于 2008-7-25 16:58:33 | 显示全部楼层 |阅读模式 来自: 中国山东德州
Selection of Polymeric Materials: How to Select Design Properties from Different Standards (Plastics Design Library)
) i5 s, y1 z. \; L! _By Alfredo Campo
- C! G  [( e/ \  ^/ ?0 tPublisher:  Plastics Design Library
0 n* p* E. F# B$ p, B% uNumber Of Pages:  250   % l' s3 N* R  K# j
Publication Date:  2007-09-17    y. k% W; i( }( g
ISBN-10 / ASIN:  0815515510   3 R+ w  w9 R" R
ISBN-13 / EAN:  9780815515517
% {6 Y8 j, f- e; `5 g  `7 H8 v, O1 ]Binding:  Hardcover
" c1 L1 v( j1 E/ ?$ U: Y( j6 \Product Description:   # @, }3 Q. n9 l- c
Today engineers, designers, buyers and all those who have to work with plastics face a dilemma. There has been a proliferation of test methods by which plastic properties are measured. The property data measured by these test methods are not identical and sometimes have large differences. How are engineers, designers, buyers going to decide the type and resin grade and their property data? Which are the valid test methods? The right plastic property data are the difference between success and failure of a design, thus making the property selection process critical. For the first time this book provides a simple and efficient approach to a highly complex and time consuming task. There are over 26,000 different grades of polymers and millions of parts and applications, further adding to the difficulty of the selection process.
1 U  U* G4 L( @5 Q" `% b, C( d  ]5 e  目录
4 H/ X- H9 p5 G, _3 Z1  Polymeric Materials and Properties . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1- a/ n# |+ n* p* L2 o" \7 D
1.1   Tensile Stress-Strain Comparison Graphs . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3
/ m" K9 E2 {# Z  d# C2 ~, ]5 ~1.2   Property Data Information for Polymeric Materials . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4) y: P1 |1 K2 a
1.3   Material Selection Guidelines . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5
0 G& o- J; }  H& i! n1.4   Polymeric Materials Specifi cations . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6/ B7 C7 t# I4 x/ v5 t
1.4.1    Single-Point Database Systems . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 69 h4 A/ v4 u! t7 V* C- W. \& R
1.4.2    Functional (Multi-point) Database Systems . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7
$ z: X' W/ {# [* P) T1 O1.5   Testing Polymeric Materials. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 83 p4 \; p: B% N' r
1.6   The Need for Uniform Global Testing Standards . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10
4 v+ K) |- A- g8 |# W0 ~0 X$ g1.6.1    Uniform Global Polymeric Materials Specifi cations . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
0 X& ~6 F7 i& s) f7 j/ n1.6.2    Selection of Testing Standards . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14
  }0 `- X- k8 T/ I6 b5 I1.6.3    Issues and Concerns . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 157 S7 F' n7 q, ^6 _
1.6.4    Summary . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16; z- W7 y5 _, q6 g; W$ r/ r! k/ G0 ]
1.7   Origin and Applications of Polymeric Materials . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16
. d% V  M7 z, B' S& ^1.8   Modern History of Polymeric Materials . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16
7 e, x9 P7 w- s5 C5 t( b& f1.9   Polymeric Materials Families . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18
; \5 P9 O$ M/ t. K5 S1.10 Classifi cation of Polymeric Materials by Performance . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18' w1 M) x3 Z4 d2 ^6 O1 ~. P! y3 P
1.11  Types of Thermoplastic Molecular Structures . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19
2 l: W2 j% H) A4 C) b$ N1.12  Manufacturing of Polymers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19
5 I2 ?+ X) P( H  l1.13  Polymeric Materials Compounding Process . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20; o3 T8 w$ H; {4 ?; K( m' d( q' F! w
1.13.1   Chemical Additives for Polymeric Materials Compounding . . . . . . . . . . . . . . . . . . . . . . . 20* v- O1 j$ D; H) C
1.13.2   Fillers and Reinforcements for Polymeric Materials Compounding . . . . . . . . . . . . . . . . . 23
: \2 }8 q& H0 F/ Q1.13.3  Impact Modifi ers for Polymeric Materials Compounding . . . . . . . . . . . . . . . . . . . . . . . . . 23
! I6 G) V6 U6 V2 k$ O$ d1.13.4   Colorants for Polymeric Materials Compounding . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 24& W$ B1 ?2 k% r8 W6 X
1.14  Families of Thermoplastic Polymers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 24
- a; o2 K9 u& b; M1.14.1   Acrylonitrile-Butadiene-Styrene (ABS) Terpolymer . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 24% w; W* i3 a, v3 r) r; Q" w! R% D: H
1.14.2   Acetal (Polyoxymethylene, POM, Polyacetal) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 24
* d7 F5 q  ^+ z# P5 }0 C3 M1.14.3   Polymethyl Methacrylate (Acrylic, PMMA) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 25
6 D0 |) ]. K! }1.14.4   High Temperature Nylon (HTN) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 25
. Q, y* T! g' w1.14.5   Liquid CrystalPolymer (LCP) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 250 i9 v8 o% h4 @& H7 V" Q5 l# M
1.14.6   Polyamide (PA, Nylon) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 26; d" j# f# q. F; L! |2 ^. y
1.14.7   Polyetherimide (PEI) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 26
# P1 J6 t2 r8 k+ U7 z1.14.8   Polyetherether Ketone (PEEK) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 27
& U9 Z1 p7 c0 T# z# J1.14.9   Polycarbonate (PC) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 27" t- L! n  ^2 l) d4 T" r5 C5 F
1.14.10 Modifi ed Polyphenylene Oxide (PPO) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 27
9 E' e2 {) O+ [0 i, U1.14.11 Polybutylene Terephthalate (PBT) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 28: c) B3 _) ?$ x1 h" z. u* O
1.14.12  Polyethylene Terephthalate (PET) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 28. }: C0 k3 H  ?  u
1.14.13  Polyethylene (PE) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 28
: |- x* I+ s9 P  D9 {. ^1.14.14 Polytetrafl uoroethylene (PTFE) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 29
0 p* }! ]+ J) W: k1.14.15 Polyphenylene Sulfi de (PPS) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 29
8 D' {3 y7 i, {8 v. q8 L1.14.16  Polypropylene (PP) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 30
, S) }3 e. o8 I% `..............# r. c8 X3 @: z9 k5 }
共7个压缩卷,解压后13M
4 A- ~; n5 h8 D! ]% |4 b2 \, E6 a, m- I! ~2 @$ F
[ 本帖最后由 fenglianxiang 于 2008-7-25 17:14 编辑 ]
Selection_of_Polymeric_Materials.part1.rar
1.91 MB, 下载次数: 11
Selection_of_Polymeric_Materials.part2.rar
1.91 MB, 下载次数: 10
Selection_of_Polymeric_Materials.part3.rar
1.91 MB, 下载次数: 11
Selection_of_Polymeric_Materials.part4.rar
1.91 MB, 下载次数: 10
Selection_of_Polymeric_Materials.part5.rar
1.91 MB, 下载次数: 12
Selection_of_Polymeric_Materials.part6.rar
1.91 MB, 下载次数: 10
Selection_of_Polymeric_Materials.part7.rar
256.55 KB, 下载次数: 11
参与人数 1三维币 +10 收起 理由
云动风清 + 10 好资料,感谢对论坛的支持!
 楼主| 发表于 2008-7-25 17:06:48 | 显示全部楼层 来自: 中国山东德州
MonomersPolymers&CompositesFromRenewableResources
Monomers, Polymers and Composites from Renewable Resources 6 U. K5 Z; p  Y+ K9 l- @! a
; M1 |  l8 k3 M0 _# C" R
By Mohamed Naceur Belgacem, Alessandro Gandini
7 c+ g  K+ t1 q& |* M( J
& l3 d  m1 r8 kPublisher:  Elsevier Science
4 s4 {( [, R8 s- @Number Of Pages:  560
! |& K& @  D, N& ~Publication Date:  2008-06-06
/ e3 w& e# Y; Q% I3 C" eISBN-10 / ASIN:  0080453163
2 y/ r* J2 ^6 q* B6 ?ISBN-13 / EAN:  9780080453163
/ \, k0 ~& g7 Y4 Y# M9 R8 ~Binding:  Hardcover
' M% `& h" _  n6 p) V; s$ B* h* ~; F) q: n
Product Description:   M4 R6 S1 o  S" t# P+ q
, r) o* M( H2 i) s! @
The progressive dwindling of fossil resources, coupled with the drastic increase in oil prices, have sparked a feverish activity in search of alternatives based on renewable resources for the production of energy. : q+ Z  Z9 s% |! p
  u4 @* m! _4 x% a
Given the predominance of petroleum- and carbon-based chemistry for the manufacture of organic chemical commodities, a similar preoccupation has recently generated numerous initiatives aimed at replacing these fossil sources with renewable counterparts. In particular, major efforts are being conducted in the field of polymer science and technology to prepare macromolecular materials based on renewable resources. The concept of the bio-refinery, viz. the rational exploitation of the vegetable biomass in terms of the separation of its components and their utilisation as such, or after suitable chemical modifications, is thus gaining momentum and considerable financial backing from both the public and private sectors.: ]) R. H5 Z+ l7 G; e3 ^3 _
, p# Q! k8 ^$ S' B, k$ A( oThis collection of chapters, each one written by internationally recognised experts in the corresponding field, covers in a comprehensive fashion all the major aspects related to the synthesis, characterization and properties of macromolecular materials prepared using renewable resources as such, or after appropriate modifications. Thus, monomers such as terpenes and furans, oligomers like rosin and tannins, and polymers ranging from cellulose to proteins and including macromolecules synthesized by microbes, are discussed with the purpose of showing the extraordinary variety of materials that can be prepared from their intelligent exploitation. * m, G: E5 M7 L) q1 a9 l/ i
( k& i1 K4 A' [) Q# }+ c7 |Particular emphasis has been placed on recent advances and imminent perspectives, given the incessantly growing interest that this area is experiencing in both the scientific and technological realms.# J% L  j' t& m3 }
共3个压缩卷,解压后6.37M
7 w/ |  Z# S0 x, F. `7 v3 g3 ?) x# P/ F1 l' M" S! P. L$ `
[ 本帖最后由 fenglianxiang 于 2008-7-25 17:11 编辑 ]
MonomersPolymers&CompositesFromRenewableResources.part1.rar
1.91 MB, 下载次数: 11
MonomersPolymers&CompositesFromRenewableResources.part2.rar
1.91 MB, 下载次数: 4
MonomersPolymers&CompositesFromRenewableResources.part3.rar
1.75 MB, 下载次数: 3
 楼主| 发表于 2008-7-25 17:18:02 | 显示全部楼层 来自: 中国山东德州
Electron Microscopy of Polymers
Electron Microscopy of Polymers (Springer Laboratory)% K( ]2 s: U( C1 K1 Y% a
By Goerg H. Michler
5 F% ~8 d4 y3 B; i, Q% _
Publisher:   Springer + j) M$ Q/ z+ Y
Number Of Pages:   473
2 W9 l1 c7 ^# [, X: }  V$ L# rPublication Date:   2008-08 & F8 T6 `1 l( d8 H) }
ISBN-10 / ASIN:   3540363505
. p* S; q/ c/ x4 n5 b2 d" }ISBN-13 / EAN:   9783540363507
& n8 ]# H. E$ {' H2 M, JBinding:   Hardcover
. Y5 x0 K: \+ @+ Y  W& i; S$ z4 O) M/ P. h, N
# p: O* D& g, p& v8 {There are many books on electron microscopy, however, the study of polymers using EM necessitates special techniques, precautions and preparation methods, including ultramicrotomy. This book discusses the general characteristics of the various techniques of EM, including scanning force microscopy (AFM). The application of these techniques to the study of morphology and properties, particularly micromechanical properties, is described in detail. Examples from all classes of polymers are presented.  W: ?5 D. ]$ J' g3 n
共10个压缩卷,解压后18.5M
0 b$ U( q" b0 i) R
3 B) f3 d9 D4 g" f$ K2 C[ 本帖最后由 fenglianxiang 于 2008-7-25 17:25 编辑 ]
Electron Microscopy of Polymers.part01.rar
1.91 MB, 下载次数: 4
Electron Microscopy of Polymers.part02.rar
1.91 MB, 下载次数: 4
Electron Microscopy of Polymers.part03.rar
1.91 MB, 下载次数: 4
Electron Microscopy of Polymers.part04.rar
1.91 MB, 下载次数: 4
Electron Microscopy of Polymers.part05.rar
1.91 MB, 下载次数: 4
Electron Microscopy of Polymers.part06.rar
1.91 MB, 下载次数: 4
Electron Microscopy of Polymers.part07.rar
1.91 MB, 下载次数: 4
Electron Microscopy of Polymers.part08.rar
1.91 MB, 下载次数: 4
Electron Microscopy of Polymers.part09.rar
1.91 MB, 下载次数: 4
Electron Microscopy of Polymers.part10.rar
1.35 MB, 下载次数: 4
参与人数 1三维币 +15 收起 理由
云动风清 + 15 好资料,感谢对论坛的支持!
