By ( Y0 g6 o) j! ~2 k* @+ T# W
M. Hinton, Defence Evaluation and Research Agency (DERA), Structural Materials Centre, Kent, UK
0 G* E: |" J4 J$ R b& sP Soden, UMIST, Applied Mechanics Division, Manchester, UK
9 d/ B; d! n; K& pAbdul-Salam Kaddour, QinetiQ Ltd, Hampshire, UK! m; r u8 O+ E n
; S0 d/ H7 }8 T& s0 q6 \% h+ J/ ZDescription
' j" R: Q' Z. e5 o% Y+ iFiber reinforced polymer composites are an extremely broad and versatile class of material.Their high strength coupled with lightweight leads to their use wherever structural efficiency is at a premium. Applications can be found in aircraft, process plants, sporting goods and military equipment. However they are heterogeneous in construction and antisotropic, which makes making strength prediction extremely difficult especially compared to that of a metal. This book brings together the results of a 12year worldwide failure exercise encompassing 19 theories in a single volume. Each contributor describes their own theory and employs it to solve 14 challenging problems. The accuracy of predictions and the performance of the theories are assessed and recommendations made on the uses of the theories in engineering design. All the necessary information is provided for the methodology to be readily employed for validating and benchmarking new theories as they emerge @; \0 G( M+ k1 y9 l
无封面,目录,共包含41个PDF文件。压缩卷8个,解压后16.5M' x8 N# V, W6 W' G
% B* D) @7 f: L! B+ ~3 [[ 本帖最后由 fenglianxiang 于 2008-7-26 15:06 编辑 ] |
