查看: 2032|回复: 1
[讨论] 有关于过滤后的程序还是没有圆弧
发表于 2008-7-30 18:12:50 | 显示全部楼层 |阅读模式 来自: 中国广东东莞
不知道为什么,,
! `: ~* W' @0 U% }5 i" E( k6 C  我用的是mastercam9.1sp2版,但是编出来的程序没有圆弧,我用的是2:1的过滤,,可是程序在机床上用时,,机器走的很慢,,这是我现在用的后处理。。, i, j4 @9 ^5 n4 C. M4 K& z
spaces      : 1     #Number of spaces to add between fields
4 n! u# X" d2 @omitseq     : no    #Omit sequence numbers?
  G( X$ |& ?% gseqmax      : 9999  #Max. sequence number: t/ c8 t  [0 {) G) U% x7 T8 R
arcoutput   : 0     #0 = IJK, 1 = R no sign, 2 = R signed neg. over 180
- ~" e# e6 a4 harctype     : 2     #Arc center 1=abs, 2=St-Ctr, 3=Ctr-St, 4=unsigned inc.
" I0 m( E6 z8 y! ^/ z, Zbreakarcs   : 2     #Break arcs, 0 = no, 1 = quadrants, 2 = 180deg. max arcs$ Z+ Z! I, r9 r1 i& M
do_full_arc : 1     #Allow full circle output? 0=no, 1=yes
6 l0 Q( q9 Z  h/ c0 ?% ~4 _helix_arc   : 1     #Support helix arc output, 0=no, 1=all planes, 2=XY plane only
. X' M( d- z" i) Jcompwarn    : 1     #Warn if cutter comp applied on arc, 0=no, 1=yes * L8 Y/ r: e2 Y; C
miscerror   : 0     #Error out if Misc Values button is disabled, 0=no, 1=yes
( u, @7 _3 @6 U2 D+ _! Zmaxrad      : 999   #Maximum arc radius% j4 S. @, [( r: w+ @$ f8 Z# l. h
hel_2100    : no    #Acramatic 2100 style helical moves, 0=no, 1=yes
' `8 w4 S% [; N; z& p' S7 @+ \usecanned   : yes   #Use canned drilling cycles?  Set to no for long output.; _& Z" o0 b8 k6 T
force_dpts  : no    #Force XY output on all drilling lines including cycle call?/ S5 K) S9 ~% f: k
haas_drill  : 0     #Haas style peck drill, 0=no, 1=yes
3 a7 [+ ]0 q5 E; _wcstype     : 2     #0 = G92 at start, 1 = G92 at toolchanges, 2 = G54, 3 = Off$ l% s4 T$ H9 E, E8 @' a
force_wcs   : yes   #Force WCS output at every toolchange?4 z# O6 @1 G9 m0 x$ N
stagetool   : 0     #0 = Do not pre-stage tools, 1 = Stage tools
% Y1 X0 a0 R) R  k( T- ytool_table  : 1     #Tool table, 0=no, 1=yes, 2=Predator VCNC, 3=MetaCut View #. e7 A8 `% x6 N
output_z    : yes   #Output Z Min and Z Max values (yes or no)
4 Z, b) }  M& }* K0 u9 Tcool_zmove  : yes   #Coolant off with last move
0 W! B+ Y+ r3 g# s3 luse_pitch   : 0     #0 = Use feed for tapping, 1 = Use pitch for tapping
- c5 R$ v9 Z  W7 ~tap_feed    : 0     #0 = 2/1 (in/mm) decimal places, 1 = 4/3 (in/mm) decimal places; p. x9 S" n% w4 F# W  s  b  T
maxfeedpm   : 500   #Limit for feed in inch/min
% n) O! ~' A  M# Jmaxfeedpm_m : 10000 #Limit for feed in mm/min
0 ]' r, ^5 O1 @/ ]" f( euse_gear    : 0     #Output gear selection code, 0=no, 1=yes
6 ?9 i5 {  V; z: L) _4 f" qmax_speed   : 10000 #Maximum spindle speed7 C( P5 r0 v. k, l' y+ c% Z* I* \& {
min_speed   : 50    #Minimum spindle speed0 w3 ]; l6 H( v
sextnc      .NC     #NC extension override
$ @# [, P: q$ s5 S8 P+ uvmc         : 1     #0 = Horizontal Machine, 1 = Vertical Mill
3 E/ \1 o6 I, V. |" d' n/ d: ^rot_on_x    : 0     #Default Rotary Axis Orientation, See ques. 164.
! }% }: y3 U/ I$ u2 K! {                    #0 = Off, 1 = About X, 2 = About Y, 3 = About Z
/ `2 k) \& J) ^' Prot_ccw_pos : 1     #Axis signed dir, 0 = CW positive, 1 = CCW positive
8 _" ^' k% ?8 Lret_on_indx : 1     #Machine home retract on rotary index moves, (0 = no, 1 = yes). U+ G! ^$ G3 S; ]- A1 a7 P8 o
index       : 0     #Use index positioning, 0 = Full Rotary, 1 = Index only3 i/ _" y0 @4 I+ N( y
ctable      : 5     #Degrees for each index step with indexing spindle/ k8 |! E' }' c0 F; r
one_rev     : 0     #Limit rotary indexing between 0 and 360? (0 = No, 1 = Yes)
$ @( V1 j5 d) x5 L9 r$ O2 ]lock_codes  : 0     #Use rotary axis unlock/lock M-Codes? (0 = No, 1 = Yes), a. Q) h5 r' A3 |( l% c
use_frinv   : 0     #Use Inverse Time Feedrates in 4 Axis, (0 = no, 1 = yes)
! W  g% {) `( o2 w# ~1 T/ }6 hmaxfrdeg    : 2000  #Limit for feed in deg/min" S/ f) H* o5 ^/ b
maxfrinv    : 999.99#Limit for feed inverse time. s/ w- z! M( Z, B" y, S# H
frc_cinit   : 1     #Force C axis reset at toolchange" a) M3 n6 H! S0 A9 O; h9 D  B
ctol        : 225   #Tolerance in deg. before rev flag changes  L4 l3 l$ @# x& Y
ixtol       : .01   #Tolerance in deg. for index error
% @# s) Y6 m  H! sfrdegstp    : 10    #Step limit for rotary feed in deg/min
发表于 2008-7-31 08:59:50 | 显示全部楼层 来自: 中国江苏扬州
光看后处理好像没有什么问题,把你的源文件发上来看看
