2天前
查看: 1687|回复: 2
[求助] 求問alloy steel 1.4562
发表于 2008-8-6 08:19:33 | 显示全部楼层 |阅读模式 来自: 中国台湾
各位大俠* u% n* L: n, [! K5 A* L; t4 S
        請幫我查alloy steel  1.4562詳細化學成份及國標號
发表于 2008-8-6 12:26:00 | 显示全部楼层 来自: 中国上海
Designation:    X1NiCrMoCu32-28-7
# K9 U: b) x6 j8 X% s: _, _! q: r 9 j% C& D3 e/ ?3 T& U
Material Number:    1.4562
+ K( i) l: G8 e2 q/ r- K9 O : E$ k' D. p" }* }% }
Material Type:    Stainless steel, austenitic  * u- f- G! G: `' J
. ]4 ?, P4 y& @8 D6 N9 o, x
Organisation:    European Registration Office
' j* a, ]  k9 @! I2 X ( L& y. {1 o8 z: S" P
Region:    Europe 9 E" O" ?9 U6 x  s  [% S
- W8 w& i! V6 A  t3 [; y$ u5 T- X+ C' i
Element    Min. [%]    Max. [%]
& t" }. b/ Y" t$ N6 s3 y8 h# | C        0,015    8 }2 Z3 A" F# R7 D  Y( T: ~
" d1 W1 I( j% M. B Si        0,3    7 e7 `$ F3 _4 A  h/ f; {) m7 f) A
8 m  q! v) C) V7 {; H+ @
Mn        2
  t2 ?/ J9 A( a: \) g ' l" O& P. K, A
P        0,02
; C$ d, K$ r: _. G * g) O/ o3 y7 i5 b9 {
S        0,01
6 u2 b8 y: o' D) Y! N
/ i, i5 x' ?' ~$ m N    0,15    0,25    * i& a/ }7 A* ]+ M2 |! [
  d, t& Y& p! ?; C0 l Cr    26    28    ' r- u# p% [6 w, {6 I' t# n/ J
8 F: z! R- z, T3 x+ V2 T
Mo    6    7    ; S5 W, C! a3 g2 n: `" g
# B* c; f0 M( a) [0 g- ~! Q5 U) o
Ni    30    32    1 G, m4 K/ d' D- r- Y6 x- m  B7 x
# K  ~8 B' Z$ w Cu    1    1,4 3 ~9 e, h- Z$ e' I) K& f
3 q/ F1 \* j5 ~9 l5 q- JStrip, sheet  $ P/ _. X! q2 ?9 U  i6 m6 d" _5 {
1 o) M2 {% @) k   Forgings
. Q* C  ?6 L) L5 T9 P; P
" N6 o' ~  w3 c6 J- W& N" v   Rods
3 ^1 L; V: t3 J2 u9 I2 {! F3 ~
+ r1 |) G8 v! U, \8 B! ~! V   Wire
; q0 s" [# L3 Z
8 X# ]+ _8 ?% ]5 r* L   Tubes
, S; s* A8 z1 m! ?9 L7 o
" K: Q( G- ^. X' C5 ], |$ l. }   _& c- G- Y# j. s2 t
  Treatment Condition
) L% I/ G% j1 v8 O . ?/ f) Q# D% c. ^) S# }
   quenched
8 x0 @! m( q9 X  `( \& w5 p' d9 {6 O) }
  X2 p6 o7 {! _. _; M: E( |% ~
3 }  I5 t  H' O# P' H
/ `2 B6 x1 |, v, j+ j7 v# G# WDimension ' ?! V& O) B; e; z
, }* L' U/ j! P7 ^! @7 o, z: W   max. (wall-) thickness, diameter [mm]: 20
% i* b& ~% Q8 N) F7 J9 f & R: q2 N& F0 y8 T* S  ]/ e4 b
   max. (wall-) thickness, diameter [mm]: 25  ) p4 h- X' |' _/ L$ t
0 ~: }& l. ~$ ?' Z! z1 o. E6 s9 p
; e/ L; Q, x; c$ c, R4 H3 o" s
- d! x* d4 w* ]6 @/ H& \
hardness Rockwell B max.:      " K  M0 a5 Y  [. a- [2 p
7 A8 R" x. E. Z) [2 J
hardness Rockwell C max.:
9 ?( d- K: I% [6 W9 k 4 C8 |9 t7 Y+ X% Y: \0 n) M6 H
6 \' Y2 X* U3 ]1 {$ Y/ C. g hardness Vickers max.:      0 d) W3 w9 v- F
+ N3 ?0 t: J. F
hardness Brinell max.:      ' `, ~3 Y2 `  [1 D
. G2 P1 D' M: E0 y- t$ c & Q+ [1 g5 ?- k* h  i
yield strength min. [MPa]:    190
# H# `% v$ O2 E+ V0 j7 _: ^ 3 C  g' N9 i% t5 J# B/ g
yield strength max. [MPa]:
$ l: o+ [1 X+ }1 Q
" R! r% b! U; O, _& ~2 n
& T( _% r5 _' a" D" ]3 l& o 1% - yield strength min. [MPa]:    225
; a- q5 |2 \9 u" D' f2 h
9 Q& j* E+ `* |+ n8 M& s" H
1 k4 Y$ }0 ?1 C7 a+ g tensile strength min. [MPa]:    490  ; K2 D5 Q' G/ w" G: x4 A
6 E. ^! r& Y! C1 W) k* x8 N tensile strength max. [MPa]:    690  1 R" X# Z4 I9 l9 V& M" E- N
* W& C  W9 ?$ w9 r) m4 D1 l
# M& q( M( u: S elongation to fracture longitudinal min. [%]:    40  5 h9 v$ n* }2 U! ^& o, B$ j1 m# I
9 c8 L, G7 {. B; @! U
elongation to fracture transverse min. [%]:    40  6 k/ I1 _, I# }1 e
! Q3 U+ e' D" h; n' {$ z3 l" s( _
reduction of area min. [%]:
. R* Y& g( V  N * ^$ Q4 V( e. A
  w. r( v; z' [% {+ t- I charpy v notch toughness transverse min. [J]:    90  ; q9 E2 C, B/ A! g7 g# E9 s# r
; k5 s% e$ {7 p7 R$ i! u+ o* v
charpy v notch toughness longitudinal min. [J]:    120
 楼主| 发表于 2008-8-7 23:47:12 | 显示全部楼层 来自: 中国台湾
回复 1# 的帖子
國內有生產嗎! t/ E1 ?+ F6 X' w3 D. [3 T1 }2 P
價格大概多少
