发表于 2008-8-6 15:53:34
|阅读模式
来自: 中国黑龙江齐齐哈尔
国外最新钢、铁水包内衬技术8 L. l: d8 H2 Y4 E7 c& u
IMPROVE YOUR FOUNDRY PROCESSES, N- Q: w& K' S+ G
AN INTEGRATED APPROACH
8 G2 g3 ~$ q3 g: k" F2 eTO HELP YOU IMPROVE
1 R( h, g2 z) P. G' l8 HYOUR PERFORMANCE
. n1 M3 z& B4 c2 iKALTEK* ladle lining systems are just one# i# b# C# F6 b
example of a long list of innovations that
, W4 a: R5 W JFoseco has developed and commercialized
5 n; e8 P% Q9 P/ t: usince we began helping foundries in
4 P0 `" J. {# ^' v; A1932. Our ability to help your foundry
# e& Z/ D7 H zsucceed comes from our comprehensive
4 r6 L, @3 f) r# Eknowledge of the foundry business and
- i% m2 ^7 g+ jprocesses, coupled with technical skill,; @9 i) z; ?( i! J
experience and a global perspective.1 v0 ]9 A" C9 u1 V5 J6 \8 e
It all comes together for you in five
% I M" L7 c! e# m( ]. Zspecific areas of foundry performance
: W- |3 T% w- r$ o0 X: U5 I7 e" oimprovement:* C( i; ?9 _ \ i, i( k {3 F
• Improved foundry processes and
: q: M, t# y3 G0 hproductivity p3 @- o5 k( h! q& b2 T
• Improved yield
" w, `, m4 d8 z6 l( a5 G8 W: ]- F• Improved metallurgical properties
- S4 k( X3 ]; ], d# y• Improved metal cleanliness
: }# ? f4 O( m8 P0 R, k* l ^+ i* ^• Improved casting finish and) A9 X' x& ~4 ^3 o6 I6 }% {
appearance
9 y8 x* V" x w) lKALTEK ladle systems demonstrate how. l" n/ Y1 M" K. t! K7 H
our integrated approach pays off in, y2 {' Y5 g. r) C, h m
improved foundry processes and productivity.) Y, ^7 a; c2 K0 ^) k4 f
Combining efficient insulation with
1 A0 q% W* O4 A! e- @/ E' }' arefractory stability, KALTEK systems9 U2 e2 o" T8 _- ^! k0 O8 x! J
improve metal quality while lowering& C" Z9 M* V9 s l
energy, cleaning and refractory costs.
$ H% I5 Z6 m. q4 A$ bThey also minimize ladle preheating costs
- Z: D. B* H9 [0 K2 dand metal temperature variation during
; m* I% g( E1 Qpouring while increasing casting quality1 A4 R# n4 X4 h$ E4 u9 i
and improving the overall work environment
* T9 y. X) \. l2 G# ?by reducing noise and radiant heat
& e3 R- l4 i( s8 Lin the melt area.- J( H! g1 e4 { {8 o9 n! E
ENERGY SAVINGS AND MORE7 S+ O) ^5 s- ~, L9 `' f
Lower tapping and holding temperatures
0 v) z8 d. d# e4 _save energy by reducing the amount of4 I% {8 M; K/ Q( P/ r K1 s. Q
energy required to% ^$ N2 [; }& n! U( X) E2 j- I
melt and hold
' P1 p. v2 `- a! v0 U( y7 Imolten metal. The
1 l% L1 x& |8 M$ N; OKALTEK ladle lining
" O: p% A0 q' E h. {, X+ Psystem generally
8 r$ C1 e2 U% }( r0 {requires no preheat,2 d! T. Q. J: k$ q8 J
so energy costs% _3 w' d- e) S0 D3 D/ R
associated with gasfired* J1 W1 j2 f5 }2 W
or electric
1 j, P `4 k) M: v- N# O8 Apreheaters are: n; C2 o5 M* e' [/ b: U, G
virtually eliminated.
+ z" A9 t0 ~4 f6 @! eReduced tap and holding temperatures
' q: z/ t1 k5 U; P3 Nalso allow furnace refractories and electrodes& Y2 U4 G/ K# z, \" s! u! C% B
to last longer.
2 P3 B! {' k) `IMPROVED LADLE PREPARATION
A8 n4 J% d) l7 V* aAND CLEANING ROOM) C! e6 A$ K+ l0 f- j& T
PRODUCTIVITY& J! c# S) T' S
KALTEK ladle lining systems minimize7 H* D2 v1 f1 I9 r
ladle turnaround time. Ladles with
* }. L; P9 Q9 q9 hKALTEK systems can usually be taken out
5 X% L4 [. d, bof service, relined, and returned in less$ p+ F! f; Z6 U
than one hour, without the need for labor
. F% H# l9 M6 X/ G; d6 kintensive slag removal and refractory
! J" N, Z; r/ g6 ?1 s- F1 w" {maintenance. In addition, lower tap
* H+ M. }6 e0 B7 Q# E% {; vtemperatures in batch pouring operations
0 u: } h) O! |( v0 Z! |2 h2 W Jlet you reduce tap-to-tap times. Productivity! ~$ T8 s0 x5 \' S1 I
gains in the cleaning room resulting9 ?. t: I, @1 P, B# i. [0 |" q
from cleaner castings will significantly
; Z1 N3 X Y( S }" o/ M4 [reduce cosmetic grinding and weld+ M# \1 A" i% ]9 N: S! B+ B- z4 \: X
repairs. Reducing the scrap resulting from
* \: T @% {2 i& b/ h7 D6 |! xtemperature variation and dirty ladles will
' _% E' Z/ l! y& p% \: p% Mprovide additional productivity gains.
# x3 f' c5 A! c2 CIMPROVED WORK ENVIRONMENT$ u4 M* [2 }1 ?$ J: l
The KALTEK ladle lining system offers: K) N/ n% y* ]. R
unique environmental and ergonomic9 |' M/ B( T. ~, Q' s
advantages in the metal shop and on the
/ [' P6 S. X( epouring floor. Lower ladle shell temperatures8 t7 i( r! r: x" s& `
allow ladle operators to reline and8 c7 E' z2 A- ~" k
return ladles to the melt shop more
! n B, ~& M+ m" z+ s- D/ E. z. Rquickly, without the labor-intensive and/ d$ y! w4 V: x v+ @
dusty chipping and hammering required E" P2 e0 ^& D" l, Q; @
to maintain conventional refractories.
# d; z* e. {7 ]Eliminating extensive ladle preheating8 N9 g |5 O4 C
reduces noise and makes for a more9 d3 s. v& x# k& k- l+ k
comfortable working environment on and# }" a' f2 ^: l( D* O
around the pouring floor. |
