楼主 |
发表于 2008-8-11 21:13:52
来自: 中国江苏苏州
Values of The Error Function" A# q2 e1 K$ f: f
Diffusion in Metallic Systems9 \. X/ c; q1 `. q
Diffusion of Metals into Metals
+ `. {" l, o; L; V. RDiffusion in Semiconductors
& P: C' W5 v n6 D( t4 MCHAPTER 5 Thermal Properties of Materials
) I+ t$ V4 a4 E. _8 e# jSpeci?c Heat of the Elements at 25 ?C
3 f4 r( U l& s% iHeat Capacity of Ceramics- z A: }) z9 W
Speci?c Heat of Polymers
; y; o$ a7 A, m5 D' c* MSpeci?c Heat of Fiberglass Reinforced Plastics
4 ]% P! ]- e% Z4 L; a3 M4 kThermal Conductivity of Metals (Part 1)* E. p% ]3 d6 }/ z7 w! L4 y. c! s
Thermal Conductivity of Metals (Part 2)
- j( k5 e& M. c1 J3 O& _7 |, R7 K; vThermal Conductivity of Metals (Part 3)5 g' U4 E( I3 r# b7 j7 _! x
Thermal Conductivity of Metals (Part 4)0 O. i7 _& b7 f, d
Thermal Conductivity of Alloy Cast Irons5 K+ \. r) B( F0 n/ |
Thermal Conductivity of Iron and Iron Alloys
* u1 V ~4 e) h- x/ F* @2 ?Thermal Conductivity of Aluminum and aluminum alloys+ j+ H! D5 e n' `- r. R" Q
Thermal Conductivity of Copper and Copper Alloys. o, a9 W- X$ l1 a+ ]! d. o( j$ L
Thermal Conductivity of Magnesium and Magnesium Alloys
2 L& p9 a6 ~0 M& d$ Q( PThermal Conductivity of Nickel and Nickel Alloys6 T; D! q& h5 w; O" }* s
Thermal Conductivity of Lead and Lead Alloys1 Z. r# N4 X" B$ H( A- }$ q' y9 U% |
Thermal Conductivity of Tin, Titanium, Zinc and their Alloys: {3 b' P) \- f; t' a
Thermal Conductivity of Pure Metals# m# }& z2 j0 \& C
Thermal Conductivity of Ceramics
' ?6 P2 v, [8 n0 Z' ^. j! i$ j+ aThermal Conductivity of Glasses; ~- |8 N5 O: | J
Thermal Conductivity of Cryogenic Insulation
3 k! z+ |2 U9 K7 xThermal Conductivity of Cryogenic Supports6 @( G2 J- o# k+ [; ]
Thermal Conductivity of Special Concretes
b+ M m0 h: E2 T) KThermal Conductivity of SiC-Whisker-Reinforced Ceramics
' x! z& k8 t; a! M7 v. ^. i' wThermal Conductivity of Polymers8 i3 o) o6 V% ^( p7 e9 H
Thermal Conductivity of Fiberglass Reinforced Plastics& b1 E4 ?( y% z5 L" H
Thermal Expansion of Wrought Stainless Steels# ~% r% N/ ^' l% Q4 Q% k
Thermal Expansion of Wrought Titanium Alloys6 P3 [7 t& r: R9 _/ I0 _. I8 P' _
Thermal Expansion of Graphite Magnesium Castings
% Q9 y, p$ v o& I( e0 {6 U1 HLinear Thermal Expansion of Metals and Alloys! V- Y! |! ?" c
Thermal Expansion of Ceramics
# F4 W2 |4 X7 J2 d) d$ JThermal Expansion of SiC-Whisker-Reinforced Ceramics
1 l7 v8 h. _/ s; B" |) O0 HThermal Expansion of Glasses
& ]6 S6 |8 V. g2 l* JThermal Expansion of Polymers- I" Y1 W2 B# V9 Q
Thermal Expansion Coef?cients of Materials for Integrated Circu; | ~$ y. T1 f% P$ E; t: [( b+ w
Thermal Expansion of Silicon Carbide SCS(R)C2Al7 w$ b9 Q# |8 N3 S8 ]% K
ASTM B 601 Temper Designation Codes 6 K( M% D' C+ h7 r( a$ f
for Copper and Copper Alloys# ^% v% j5 U3 H' `0 x, O
Temper Designation System for Aluminum Alloys
# A0 f5 E. o8 N5 A+ s& l! hTool Steel Softening After 100 Hours( k: `& N% V' I
Thermoplastic Polyester Softening with Temperature
: c4 c+ g' C% s% HHeat-De?ection Temperature
; U+ X. e; |8 }8 |of Carbon- and Glass-Reinforced Engineering Thermoplastics4 Q t! n. D9 q6 T( ^5 S% x7 {
CHAPTER 6 Mechanical Properties of Materials
9 k$ r4 z: p* {: gTensile Strength of Tool Steels
' [+ M* i* G+ @, X3 J. O$ CTensile Strength of Gray Cast Irons
; E5 |4 Z2 y Z, Q$ i* XTensile Strength of Gray Cast Iron Bars
+ Q, {. G/ L ~9 l" ?1 {7 C8 \Tensile Strength of Ductile Irons
- Y0 r+ B$ r& d0 b+ fTensile Strength of Malleable Iron Castings
* O8 j1 n$ D8 L K+ l8 n" |" [Tensile Strength of Austenitic Stainless Steels
8 D8 o0 Q T4 X0 n( i$ ?9 RTensile Strength of Ferritic Stainless Steels
# h' _- ^2 ~0 _7 i7 r# ~Tensile Strength ( e, |* S! }4 Q2 C" C8 y
of Precipitation-Hardening Austenitic Stainless Steels3 [2 f! f/ g; [( b
Tensile Strength of High(R)Nitrogen Austenitic Stainless Steels: [- {' x2 {% F9 p
Tensile Strength of Martensitic Stainless Steels& P/ n0 v8 j( b* g t- Z
Tensile Strength of Wrought Coppers and Copper Alloys
% P! O e& @5 x- PTensile Strength of Aluminum Casting Alloys
1 M" A. ?' k& j( |: r! gTensile Strength of Wrought Aluminum Alloys
' K: d4 D' w$ d; Q% K) S2 P+ lTensile Strength of Cobalt-Base Superalloys, H Q# b& m& i' U, Q
Tensile Strength of Nickel-Base Superalloys
* A7 t {- s3 c) I' y* N I- MTensile Strength
$ _& S! y3 V4 ~8 f( U4 Z; M, Z3 |of Wrought Titanium Alloys at Room Temperature1 B0 _0 s, A7 W" m6 _, Y# M' b/ q
Tensile Strength of Wrought Titanium Alloys at High Temperature, G9 v0 d" d! r$ s6 F
Tensile Strength of Refractory Metal Alloys* v; B2 n& n c" y3 Q+ r
Tensile Strength of Ceramics
* A8 e* I% A0 z) T& G: cTensile Strength of Glass
7 o+ o8 t4 H! v3 S. tTensile Strength of Polymers
$ p* g9 M' A6 D4 H( L2 zTensile Strength of Fiberglass Reinforced Plastics
: ?% ]- X: k" u$ _2 @ o" I* zTensile Strength
+ Z" j$ c0 x- d/ L6 I; Vof Carbon- and Glass-Reinforced Engineering Thermoplastics' ]2 }; P. w3 k" ]) ^
Strength of Graphite Fiber Reinforced Metals
% ?1 z( Q. ^& }# m7 tTensile Strength of Graphite/Magnesium Castings
k0 m5 _4 \$ Q2 YTensile Strength of Graphite/Aluminum Composites) D; C: V; Z [( w
Tensile Strength of Graphite/Aluminum Composites' l- Q2 B" k8 ?+ i7 y+ ?- Y& G
Tensile Strength of Silicon Carbide SCS(R)C2Al
% q6 k9 J; a G. m; }) |6 W/ m& `Ultimate Tensile Strength of Investment Cast Silicon Carbide SCS(R)Al" }* D7 g6 ]5 s
/ V) L" w9 C3 f! @( W3 D( _of Silicon Carbide(R)Aluminum Alloy Composites
: r/ I. j" s0 m4 E5 ]. YTensile Strength of SiC-Whisker(R)Reinforced Aluminum Alloy" o- u# y0 [9 V) d# ~
8 J* N8 j* Q/ C, T* Gof Aluminum Alloy Reinforced with SiC Whiskers vs. Temperature, P/ Q" H* m% k* Q$ W6 {8 Y& M
Ultimate Tensile Strength ! x8 n: q4 O* d4 l u. z
of Reinforced Aluminum Alloy vs. Temperature
4 L0 I! f( _6 f& u6 r# hTensile Strength / ?' L# O& f+ u) x$ K% E# e
of Polycrystalline(R)Alumina(R)Reinforced Aluminum Alloy3 h# G8 u+ j5 N. }& [ i$ i
Tensile Strength of Boron/Aluminum Composites
0 M9 y! O* G" nCompressive Strength of Gray Cast Iron Bars% k8 X* {- o" B1 l
Compressive Strength of Ceramics
8 }$ P3 Y" t- i+ q# D4 S6 LCompressive Strength of Fiberglass Reinforced Plastic# O" v0 G5 \! j( b
Ultimate Compressive Strength : u, q9 N2 e# k$ }5 O. F* l8 G6 b8 _
of Investment Cast Silicon Carbide SCS(R)Al' x, ^$ C% s K! o$ S/ `% B( W
Yield Strength of Tool Steels: p0 f) P! V9 H7 i1 Z4 j; Y
Yield Strength of Ductile Irons
7 f8 b( v$ v7 y; i$ H7 fYield Strength of Malleable Iron Castings
. ]% v: y; h1 {9 U& pYield Strength of Austenitic Stainless Steels0 |* e) q2 P+ I: M( [* D0 l, Y
Yield Strength of Ferritic Stainless Steels
) {4 j! }' f; X/ O& |: tYield Strength of Martensitic Stainless Steels
8 V: a$ d# c% x: O7 i' p: z- PYield Strength of Precipitation-Hardening Austenitic Stainless Steels2 X: V( s* m! d, e7 ?% {: S& L
Yield Strength of High(R)Nitrogen Austenitic Stainless Steels
T4 M* v; L: c! [$ {3 ?Yield Strength of Wrought Coppers and Copper Alloys
+ U: ~- w. H& {7 O2 y4 Y) cYield Strength of Cast Aluminum Alloys$ L8 s$ R5 Z' M X0 @ C
Yield Strength of Wrought Aluminum Alloys
. J: b! A4 y3 y) G! H1 _; EYield Strength of Wrought Titanium Alloys at Room Temperature; H$ Q5 f: e4 b8 S) }, @! K9 W3 }
Yield Strength of Wrought Titanium Alloys at High Temperature
( A0 X E2 T; B5 EYield Strength of Cobalt-Base Superalloys
7 M/ ~/ Y+ h( d9 M! f# ]Yield Strength of Nickel-Base Superalloys
3 k* W, O8 j% b) S$ xYield Strength of Commercially Pure Tin
3 u/ K$ {' E( F: eYield Strength of Polymers
( D1 J' s7 Z* z' Z) rYield Strength of SiC-Whisker(R)Reinforced Aluminum Alloy3 E8 P& X. D3 c" m: h( e' W( P- l
Yield Strength of Reinforced Aluminum Alloy vs. Temperature1 q! D$ G2 m, |. h
Yield Strength of Polycrystalline(R)Alumina(R)Reinforced Aluminum Alloy' K% {6 y) v2 o& K3 {+ v
Compressive Yield Strength of Polymers " A! Q: M! s' @$ F: t6 X
Flexural Strength of Polymers
! n! T4 @7 |1 B$ eFlextural Strength of Fiberglass Reinforced Plastics
( q" t9 @8 P2 T* [! O6 G9 [Shear Strength of Wrought Aluminum Alloys" S: V) A- d/ I3 R+ M3 S- G
Torsion Shear Strength of Gray Cast Fe/ i# r, z6 C5 g, ]
Hardness of Gray Cast Irons2 Z( l8 `0 m3 b
Hardness of Gray Cast Iron Bars* h: G+ Z) _' Y
Hardness of Malleable Iron Castings: C2 n- l0 H' i$ a- l; g' p! u; \! K
Hardness of Ductile Irons
6 Z9 b8 G7 Q2 K2 k- BHardness of Tool Steels% F! Y3 v- b3 ?% @
Hardness of Austenitic Stainless Steels& Q, C$ Q- Z4 L' {7 F
Hardness of Ferritic Stainless Steels7 h _' {/ r9 l j- c
Hardness of Martensitic Stainless Steels& {( l: v4 s) T+ j0 v6 q9 A
Hardness of Precipitation-Hardening Austenitic Stainless Steels
" I. X3 u% x( J/ ~) C7 w2 _7 LMachinability Rating of Wrought Coppers and Copper Alloys3 H4 N1 x1 S4 N" m8 j2 U
Hardness of Wrought Aluminum Alloys
( T- f' r: V1 c9 E6 T: iHardness of Wrought Titanium Alloys at Room Temperature( }5 @( [+ J/ R8 u& @
Hardness of Ceramics8 Z5 l( y) S) p0 V6 _& W, d
Microhardness of Glass( |6 r j- x2 Z
Hardness of Polymers
0 d: G- J5 l$ w5 VHardness of Si N and Al O Composites
7 X- L, c* e1 E/ J, t3 4 2 3
/ t( f9 y! [+ M8 C; pCoef?cient of Static Friction for Polymers
2 z* ?) k$ T) _- W3 XAbrasion Resistance of Polymers# `( C. |5 E" i% R( L# z/ D: ?( o
Fatigue Strength of Wrought Aluminum Alloys* I0 X& i. c7 {2 j1 I
Reversed Bending Fatigue Limit of Gray Cast Iron Bars e7 o1 |) A Q- n# S4 x
Impact Energy of Tool Steels' d% w o. b$ ?4 }0 `
Impact Strength of Wrought Titanium Alloys at Room Temperature. F7 H2 h e0 `" p4 W: ?( w7 a
Impact Strength of Polymers
$ U( E. G, H3 I& M: O) v/ l. R0 _2 S% bImpact Strength of Fiberglass Reinforced Plastics& ]! F; [% K. {9 F" Z6 W
Impact Strength of 6 y8 E' |) o1 a$ Z m0 c, A
9 Q2 \) A; L: G+ }. EFracture Toughness of Si N and Al O Composites% t0 N2 v1 e* f$ \
3 4 2 3
3 q! I' M7 Y. X' ATensile Modulus of Gray Cast Irons9 C7 P4 i: s7 D( s* T$ j4 }5 u
Tension Modulus of Treated Ductile Irons
# \# s1 Y4 ]' yTensile Modulus of Fiberglass Reinforced Plastics
( N+ g( G' l2 GTensile Modulus of Graphite/Aluminum Composites
! h1 `# Y$ E7 g( e3 W. _6 P2 kTensile Modulus of Investment Cast Silicon Carbide SCS(R)Al1 m' t n, T% r* c9 |
Tensile Modulus of Silicon Carbide SCS(R)C2Al
9 c8 F6 Q' Y! f% [Young°s Modulus of Ceramics7 g1 _/ R3 R" F; [
Young°s Modulus of Glass7 C' k( q" W' ~
Elastic Modulus of Wrought Stainless Steels
7 ~- W4 d+ X' h- lModulus of Elasticity of Wrought Titanium Alloys$ \; J r3 s3 x! n4 _; a8 L: t2 |
Modulus of Elasticity in Tension for Polymers; N* e- C1 p7 d% y3 j
! _7 k7 w6 z; d5 t+ m% |, wof 55MSI Graphite/6061 Aluminum Composites* ~ V; f1 J. u, ]- Y6 b' i
Modulus of Elasticity of Graphite/Magnesium Castings
" z1 m# w6 w( ]& G' k q* A$ TModulus of Elasticity of Graphite/Aluminum Composites+ g5 e' {7 r- }; t0 D }' h/ [1 s
Modulus of Elasticity of Graphite Fiber Reinforced Metals
9 U$ s! e/ T, f* E1 HModulus of Elasticity of SiC-Whisker(R)Reinforced Aluminum Alloy |
