5天前
查看: 1432|回复: 1
[分享] 求救:SOLIDWORKS2008退出时显示蓝屏错误信息
发表于 2008-8-15 23:13:28 | 显示全部楼层 |阅读模式 来自: 中国广东广州
求救!!!!
$ ^6 O) h! N3 a  j每次退出SW2008时出现以下蓝屏信息,2 u( m# g/ r$ }* y& w8 h
% r+ m' g4 B+ t, {5 k" v7 J2 g
A problem has been detected and windows has been shut dwon to prevent damge to your computer.
& Y2 N+ u- m& m  G, F
2 i% t7 Z+ {, z# y7 c3 L  O7 w7 YIf this is the first time you've seen this stop error screen restart ypur computer, If this screen appears again .follow these steps:
! {- z8 P, f# r, k9 y' u
: [/ [5 u- n+ ]0 j0 A9 o6 b! e9 Z    Check to be sure you have adequte disk space, If adriver is identified in the stop message.disalde the driver or check with the manufacturer for driver updates,Try changing video adapters.+ l2 t  Y- J0 }
4 X9 I) ?8 A% Z* C6 s7 D3 w9 F
     Check with your hardware vendor for any BIOS updates,Disable BIOS memory optints such as caching or shaowing, If you need to see safe Made to remove or disalde components ,restart your computer ,press F8 to select  Adranced startup options,and then select safe Mode.
7 h" e# a: D7 H- c8 \! }" X4 F9 G9 Q, T1 d! W
          Technical    information:6 b) W$ w; h1 d# B
    ***   STOP:  0X0000008E   (0XC000005,0XBFA3A873,0XA7E9E2A8,0X0000000)
) g& M1 s+ ^! A* t0 g! @
9 t$ I, Z+ h2 R5 Y                        ati2cqag.dll_Address BFA3A873 base at BFA19000,Datestamp 00000000
发表于 2008-9-8 09:21:40 | 显示全部楼层 来自: 中国湖北武汉
应该是软件问题,建议重装,
