查看: 1584|回复: 4
[求助] 开始使用X2 mr2 sp1编程了,可出现了MC9.1没有的问题。
发表于 2008-8-22 19:40:49 | 显示全部楼层 |阅读模式 来自: 中国上海
出一个程序就会外带一个(err)日志。我贴一个日志来,大家看看。
+ t# ]% w/ g+ {7 R9 Z) m程序验证是可以用的。
' z6 p9 X/ U, M& b3 ~  d# l22 Aug 2008 07:28:46 PM - <0> - 已创建报告
- k7 H2 f4 C; G+ i22 Aug 2008 07:28:46 PM - <2> - Initialize posting log file' O# N% q9 d- z) W: ~( q
22 Aug 2008 07:28:46 PM - <2> - Using MP run version 11.00 and post components version 10.00& T6 p' O9 m9 e5 |; c+ {' W
22 Aug 2008 07:28:46 PM - <2> - Initiate opening the post processor file(s).
4 Z3 a0 ?! x# L22 Aug 2008 07:28:46 PM - <2> - 后处理文件名: D:\MCAMX\MILL\POSTS\MPFAN.PST) p* q. m% V, ~' [- a7 \: u- u
22 Aug 2008 07:28:46 PM - <2> - 此后处理程式已被成功开启.; w1 ^" J2 w1 m7 V! h7 Q( y8 Q
22 Aug 2008 07:28:46 PM - <2> - 此后处理程式已经完成读取过程.. @$ i& X% c2 R
22 Aug 2008 07:28:46 PM - <2> - Post version information (input):
4 h& G6 |- S! @  ]' m$ H# A22 Aug 2008 07:28:46 PM - <2> - UPDATEPOST 版本 11. was used to modify this file.$ d2 q3 B! k! }) o3 N! I! ~
22 Aug 2008 07:28:46 PM - <2> - The file was modified by this product on 13 Jul 05 21:05:27
5 i7 X/ B$ g; E: a/ \22 Aug 2008 07:28:46 PM - <2> - The post was written to run with Mastercam Version 11.
( ?9 v. e5 R1 ^22 Aug 2008 07:28:46 PM - <2> - The post product type is 铣床.
' h; [% A  p9 h" m  ]  F22 Aug 2008 07:28:46 PM - <2> - Initialization of pre-defined post variables, strings, postblocks was successful.. p( N/ Y8 M% s7 F- ^
22 Aug 2008 07:28:46 PM - <2> - Search for defined post variables, strings, postblocks was successful.
+ m4 _! ?' ^3 t0 L* m2 F22 Aug 2008 07:28:49 PM - <2> - 控制器定义 - - Post variable 'err_file$' was re-initialized from 0. to 1.
- T( e# k$ \4 Q$ b+ w22 Aug 2008 07:28:49 PM - <2> - 控制器定义 - - Post variable 'dec_seq_right$' was re-initialized from 3. to 0.
. s* a- K3 E: S, F$ s5 |5 ?22 Aug 2008 07:28:49 PM - <2> - 控制器定义 - - Post variable 'omitseq$' was re-initialized from 1. to 0.
7 r$ @0 U  K1 {7 I22 Aug 2008 07:28:49 PM - <2> - 控制器定义 - - Post variable 'sub_seq_typ$' was re-initialized from 0. to 1.
! h/ V8 G  L0 n# f+ e22 Aug 2008 07:28:49 PM - <2> - 控制器定义 - - Post variable 'tplanemode$' was re-initialized from 2. to 0.% S9 U3 L( l1 r4 U) j7 U2 a& m
22 Aug 2008 07:28:49 PM - <2> - 控制器定义 - - Post variable 'arctype$' was re-initialized from 2. to 5.* w% g$ }& K6 [! m: p& n4 W; J
22 Aug 2008 07:28:49 PM - <2> - 控制器定义 - - Post variable 'arctypexz$' was re-initialized from 2. to 5.
" v9 l, R1 B: T+ a' A+ s* X6 ^22 Aug 2008 07:28:49 PM - <2> - 控制器定义 - - Post variable 'arctypeyz$' was re-initialized from 2. to 5.
# |( j& ], f( ]- @& x4 p! L. D22 Aug 2008 07:28:49 PM - <2> - 控制器定义 - - Post variable 'larctype$' was re-initialized from 2. to 5.
: g+ L7 V, [( R$ x, F22 Aug 2008 07:28:49 PM - <2> - 控制器定义 - - Post variable 'larctypexz$' was re-initialized from 2. to 5.* y- S+ m1 A  U* b0 G3 ]
22 Aug 2008 07:28:49 PM - <2> - 控制器定义 - - Post variable 'larctypeyz$' was re-initialized from 2. to 5.
% z) b7 `4 V3 e0 h, H2 Y! R8 c4 z, ~22 Aug 2008 07:28:49 PM - <2> - 控制器定义 - - Post variable 'arccheck$' was re-initialized from 1. to 111.5 i* C8 I& B( {: ~& S; i
22 Aug 2008 07:28:49 PM - <2> - 控制器定义 - - Post variable 'larccheck$' was re-initialized from 1. to 111./ [" H" l! K" C% _. q
22 Aug 2008 07:28:49 PM - <2> - 控制器定义 - - Post variable 'peckacel$' was re-initialized from 0. to 1./ T' m3 H6 x. O2 x
22 Aug 2008 07:28:49 PM - <2> - Successful completion of posting process!
发表于 2008-8-22 19:55:40 | 显示全部楼层 来自: 中国辽宁铁岭
X版以后可能都有,我的也i
发表于 2008-8-22 20:00:17 | 显示全部楼层 来自: 中国广东肇庆
我用的X版本好像没有出现这样的问题
发表于 2008-8-22 20:43:08 | 显示全部楼层 来自: 中国广东珠海
很正常呀,MASTERCAM哪个版本都有
发表于 2008-8-22 20:49:10 | 显示全部楼层 来自: 中国江苏苏州
,8.0的都有的,就是设置,可以关的.不过这个东西对你的加工没有任何影响的
. k, }4 [4 L8 Z1 G& F不会的也不需要关闭,出来删除就好了
