2021-06-25
查看: 1269|回复: 1
[讨论] 大哥帮帮忙!@~!~!
发表于 2008-9-1 19:35:04 | 显示全部楼层 |阅读模式 来自: 中国广东广州
我在教程里看的PRO/E4.0下了后  setpu 这个文件 怎么打不开,是不是我的电脑那里,没有设置好还是怎么回事,我机子里已经把2001版本 装了.
发表于 2009-3-1 13:01:49 | 显示全部楼层 来自: 中国台湾
原帖由 lznyl 于 2008-9-1 19:35 发表 http://www.3dportal.cn/discuz/images/common/back.gif8 u4 ]3 `, G# w+ v0 P
7 Z1 O8 M- x$ G* c3 O
6 Y7 [: A1 w- K5 v- Y$ J9 q% |9 B此問題出現在安裝了2個不同版本的proe後,絕非系統問題,附件是PTC工程師的解答,我用了方法二,一勞永逸~絕對正點!如解決的請頂!
% o5 I0 M6 w3 J' E; |. l* [. i, Z! y1 j2 M; Y  j7 n
Unable to startup Wildfire 4.0 with only the logo appeared then disappeared.# Y( ~6 B/ k* a- g
4 I/ r& `6 ?8 a7 b9 k* o% DIssue Desc:
6 h: }4 r1 y: d9 dWhen startup Wildfire 4.0, only the logo appear then disappear, Wildfire 4.0 cannot be launched.1 G, ?6 @% p# }2 I6 f
" n" ]; H& h; z4 @
4 a" V6 g; B, \
Resolutions:- k5 t7 Z% _" I; D7 m8 y( \
This issue happened when there are two different versions ofPro/ENGINEER installed on one machine and they are share the same cache.
0 T$ n, v3 C6 l. B; M" k6 }# j2 K! G' a; i) ~
To resolve this issue, there are two ways:, F# U( T- j5 D) j# y+ d
# |( Z0 P; Y0 T; ^7 Y: I4 D& V
One way is to delete the cache before startup Pro/ENGINEER Wildfire 4.0.) c& V; u5 X+ o8 W
>> Browse to C:\Documents and Settings\Administrator(or yourlogin name)\Application Data\PTC\ProENGINEER\Wildfire\.wf, delete the.wf folder.
4 ^5 z2 c$ K- g>> If you had set system environment PTC_WF_ROOT, please delete the folder under PTC_WF_ROOT.$ ]: Y, \) u: Q: ~! Y8 A7 @; ^
) H- @# x# L8 A$ a( YThe other way is to add system environment at Pro/ENGINEER Wildfire 4.0 startup command.
7 F8 `- |6 t$ ]- V  |+ }" X3 J5 _0 b>> Open the Pro/ENGINEER startup file .psf (at<proe_loadpoint>\bin folder) with wordpad, add a line"ENV=PTC_WF_ROOT=D:\workspace\windchill\Forwf4", the valueD:\workspace\windchill\Forwf4 is the path for writing cache. (Refer tobellowed picture)
