发表于 2008-9-28 20:45:33
来自: 中国江苏无锡
7 l, D0 J. a6 E8 U1 M
; U' c( R; g7 }, |我也不熟悉lisp,只是lisp参考好找的,照着修改容易看到成果,呵呵。.
' v" }! k" f9 K% D# @1 k& s" O1 w# k
- (defun c:ssh_max( / D1 ss1 ss_data enname TM )9 f. ?) r, E I3 u$ C
- (setq ss (ssget '((0 . "TEXT" )))3 s/ p2 a. N# ?. B# U
- n 0
* x* J+ R6 B9 D+ h4 ]( j - ) ;_ 结束setq( z9 u7 R$ h6 f. V- C
- (setq i (- (sslength ss) 1)) H8 ]1 `3 M- s' b
- (setq ss1 (ssname ss i)) 6 g' x0 h ^4 `( g- U5 d2 i5 z& S
- (setq ss_data (entget ss1)) ;;取得SS1的码组带入ss_data
& i" m, x7 w4 y) ?- ]9 I& J - (setq ennamei (cdr(assoc 1 ss_data))) ;;取得ss_data文字内容
1 O0 [$ I/ @5 I9 F( ~6 ?' A - (setq ennamei (atof ennamei))
% G6 D1 x) F: x9 x* ^# ~0 k0 _+ _ - (setq ssn ss1)
# O3 p' D. }( _ c- F - (command "layer" "M" "tigerspace_max" "" )
7 G) C% {* c {, X9 ] - (repeat (sslength ss)/ Y, `2 N- {! ]5 R3 j% h7 E
- (setq ss1 (ssname ss i)) 3 @" u ~( c5 @3 \
. ^8 i4 X! K( u8 J# B c - (setq enname (cdr(assoc 1 ss_data))) ;;取得ss_data文字内容- ?3 I" @/ r6 ]* R4 }
- (setq enname (atof enname))
' F7 Q& {+ c+ Z& D - (if (> enname ennamei)
) X( x4 ^+ O. y' C. g$ q9 Z - (setq ennamei enname)
4 v5 N- \/ X- s; O" Z6 h - ()
1 i A1 Z D2 {' p# @* B - );;结束if4 T* V* z& S7 c u, u* V$ V, G
- (setq i (- i 1))
" m, R) o0 X) l& z$ o- H) z - );;repeat
7 k" u% {3 U0 {, l, i2 e/ ]1 ^ - (setq i (- (sslength ss) 1))
) E5 w5 R# p+ I: G3 a3 Z: v - (setq ss1 (ssname ss i)): }. ~- M9 q$ U* n1 N0 }
- (repeat (sslength ss)( T5 L5 Y' z) W& u2 m8 S2 j
0 ]( G" }, K* U& [! h - (setq ss_data (entget ss1)) ;;: j4 p7 D- P ]# ^9 k
' z: v8 a8 Z! n/ k& C - (setq enname (atof enname))
+ g+ ?5 y0 A+ g" @' s. X& u - (if (= enname ennamei)
/ [2 P3 h+ X5 S9 b) I2 b: W4 @ - (command "change" ss1 "" "P" "LA" "tigerspace_max" "c" "1" "" ); x8 l5 x% N8 Z+ s; C" t# w" F7 D3 w
- ()- l8 p5 N; x4 j0 \4 `
- );;结束if- s, d, \' e; H6 a* Y
- (setq i (- i 1))4 h. @. Q; Y* [/ T6 g- V1 @* S# s
- );;repeat% i( S" |! t# @+ f" J' T% h/ O1 \
# Y; D$ f6 Q) I/ p: K+ i- (princ)8 L! x1 ~4 h; ]# h/ y1 A& Q& [& W' m+ G3 P
- );;;;结束defun( m& z" W' l* B! e8 `7 Z( t* u: {
- (prompt"\n 命令:ssh_max" )
: I. I8 d# }5 T; n: @ - (prin1)
}1 S0 I$ t! F' A( P, N
复制代码 |
