发表于 2008-9-23 07:10:54
来自: 中国浙江温州
指PG制螺纹,常用的有M制螺纹。. j3 c/ R' M# s3 S; U T0 h( ^& c, s: D
PG螺纹属于钢管用螺纹,详细标准可查DIN 40430标准.! k t/ x# V* t6 R; g1 u# j
Pg Thread DIN 40430' s. V$ v( T: G; ~5 W& d
Steel Conduit ThreadFor cable diameter3 ~& G6 I' \& O
mm | Thread Size | Major Diameter4 {& O8 S8 L1 D+ Q
mm | Tapping) w4 q8 ~# q7 I( j) y' v% W2 c
Drill Size | Pitch
; o- ]4 |6 S% f/ G( fmm | | 6,0 | Pg 7 | 12,5 | 11,3 | 1,27 | | 8,0 | Pg 9 | 15,2 | 13,9 | 1,41 | | 10,0 | Pg 11 | 18,6 | 17,3 | 1,41 | | 12,0 | Pg 13,5 | 20,4 | 19,1 | 1,41 | | 14,0 | Pg 16 | 22,5 | 21,2 | 1,41 | | 18,0 | Pg 21 | 28,3 | 26,8 | 1,59 | | 25,0 | Pg 29 | 37 | 35,5 | 1,59 | | 32,0 | Pg 36 | 47 | 45,5 | 1,59 | | 38,0 | Pg 42 | 54,0 | 52,5 | 1,59 | | 43,0 | Pg 48 | 59,3 | 57,8 | 1,59 | | http://www.gewinde-normen.de/en/images/pg-thread.gif |
! R& l$ B& w( ~# ]& D( x Q( eOn 31.12.1999 the safety standard VDE 0619 which included the standards DIN 46319 for metric sizes and DIN 46320 for PG-sizes were withdrawn. On 01.01.2000 the new standard DIN EN 50262 came into force. The new standard uses the new metric sizes. In the transitional period - until 01.03.2001 - the PG-standard could still be used. For replacement PG-items may still be used. The ten sizes PG 7 / 9 / 11 / 13,5 / 16 / 21 / 29 / 36 / 42 and PG 48 were replaced by eight new metric sizes, i.e. M 12 / 16 / 20 / 25 / 32 / 40 / 50 and M 63. No direct conversion is possible!
9 L5 H- _3 _& F; x: }
' T, [+ V3 I" S" o2 a4 bBy this new standard a suitable solution was not achieved. ' Z f2 D% U6 p" M8 {$ Z
| | Possibilites for a conversion: | | PG Size | Major Diameter# S+ w4 b% r7 M
mm | For cable diameter9 ]' |6 r, v! c* K# o
mm | Conversion to metric, p- ~& C. V9 @# @% Y
mm | | Pg 7 | 12,5 | 6,0 | M 12 | | Pg 7 | 12,5 | 6,0 | M 16 | | Pg 9 | 15,5 | 8,0 | M 16 | | Pg 11 | 18,6 | 10,0 | M 20 | | Pg 13,5 | 20,4 | 12,0 | M 20 | | Pg 13,5 | 20,4 | 12,0 | M 25 | | Pg 16 | 22,5 | 14,0 | M 20 | | Pg 16 | 22,5 | 14,0 | M 25 | | Pg 21 | 28,3 | 18,0 | M 25 | | Pg 21 | 28,3 | 18,0 | M 32 | | Pg 29 | 28,3 | 18,0 | M 32 | | Pg 29 | 28,3 | 18,0 | M 40 | | Pg 36 | 47,0 | 32,0 | M 50 | | Pg 42 | 54,0 | 38,0 | M 50 | | Pg 42 | 54,0 | 38,0 | M 63 | | Pg 48 | 59,3 | 43,0 | M 63 | | Wrench Size for Cable Connection | | Connecting Thread | Wrench Size U) [: S9 i K0 B6 S( D. ^
mm | | Old | | | PG7 | SW 15 | | PG9 | SW 19 | | PG11 | SW 22 | | PG13,5 | SW 24 | | PG16 | SW 27 | | PG21 | SW 33 | | PG29 | SW 42 | | PG36 | SW 53 | | PG42 | SW 60 | | PG48 | SW 65 | | New | | | M12x1,5 | SW 15 | | M16x1,5 | SW 19 | | M20x1,5 | SW 24 | | M25x1,5 | SW 30 | | M32x1,5 | SW 36 | | M40x1,5 | SW 46 | | M50x1,5 | SW 55 | | M63x1,5 | SW 66 | }' w6 ?& z' T( A
% w* }3 F# N) U* B# l2 b# t0 T
[ 本帖最后由 CHNLOONG 于 2008-9-23 07:14 编辑 ] |
