发表于 2008-11-18 13:35:06
来自: 中国上海
打开13安装文件,把Crack的ID,序号安装过程中填上去,
8 ?7 z% j# E1 X8 t, a' d! s+ o最后安装CIM12/CRACK/iso-cit13i.exeCrack文件安装上就OK了! }, ]* K' L3 \7 Y
9 a! z- N. p8 k, }5 R Cimatron It v13.0" I# d# k( C9 U6 f: |7 r
-----------------9 N$ S' M9 c! O* ?- l
0 {0 J# ^+ t1 `, ?0 c - run cimatron it v13.0 installer, choose complete install. 8 |" T7 x5 X4 Y0 e4 Y0 P/ M* l
- during installation enter providen plug id and key codes.- C; V) I" [) ]! o7 a
- note: we've encountered some strange issues with installer, so if installer is crashing for' ^ X( o" B( ~/ `
you, do not enter real key codes (just type smth else and press next), after you done with
# \5 L$ x" I0 j( F/ U k installation run 'bin\updatereg_it.exe' and now enter real key codes.( Y8 S' M% N+ Q+ v/ O5 ~2 s# c
- if you wanna install cimatron quickconcept v2.2.1, do it now.2 Y! @2 Y% r5 X
- after it's done, run 'iso-cit13i.exe', choose components you want to be patched and- T' t2 ^% }+ `* |
point to destination locations of every component.. S+ g* H3 W+ {5 `
- note: we didn't cracked magics stl and cimarender pro since they aren't integral part of - @- ~9 \1 C+ c4 j. d, E" e9 S
the cimatron it v13.0 (just third party addons).
2 e v0 D" ?8 h" D - that's all!
9 i; z0 v" `9 m/ |4 [
! _) R7 n; F* T = plug id: 5791 (注意就是这个ID)
( R+ D4 { y h# k0 s, b = key code: 42290,53157,5827421,1372587,1372579,5002109,31341,31333,5781637,1315306,1315298,4983933 (接是这个序列号)
" ^3 F7 K* i2 J; j- T = catia key code: 40bd 26ad af2b 8983 740c 4465 c39e b0df
9 j6 Q; O" u" s5 W- S = ug key code: 30af 9c69 45df 07a0 e218 3ae1 ea40 9eb9" h# L" ]/ `6 G/ e1 F
= re_enge key code: 5fde- q" f5 a' G8 O" E
' |' P! @9 t1 z6 n# v" I e!l |
