发表于 2008-10-5 22:37:29
来自: 中国
- (defun c:myhatch (/ a b c d)' Y" Z3 s) |# G4 p1 u
- (setq pa '(0 0 0))
- C+ ^& q% n6 g: H3 k - (setq pb '(400 400 0))
( u- s5 X0 h( }. m+ o" G - (setq po '(300 300 0))
5 K% z ]$ w+ a% V - (command "rectang" pa pb)
: p9 }% H2 b" A) x a" N - (command "-hatch" po "P" "solid" "" )$ }! _+ B: R, o C6 G, Y! z
- (setq a (entlast))
3 a# W/ M$ Q ?- _ - (setq b (entget a)), ~& d4 r" l1 h b1 a% }
- (setq c (assoc 62 b))
7 ]. L, g; B8 Y: \ - (if c
$ G2 h! ?4 A- }6 y - (progn" W# o! K( ^3 o7 |0 C: r+ o5 Y
- (setq d (cons 62 1))
8 `+ d! `' [1 [! c7 h8 H: s( q - (setq b (subst d c b))# A$ W( z- W% f4 b& L
- )' T) _/ |6 V5 m- k4 h+ d- R
- (setq b (append b (list (cons 62 1))))
* t# i2 B) [: L- ]8 l5 F1 @9 Q - )
2 v4 m: h0 q. |& e- l) @% A - (entmod b)
+ @% a2 ^8 `* r$ t" e6 T - (princ)
* S# F! |" b0 r/ W3 _ - )
复制代码- 9 s1 Q; W3 p- B/ w; m/ d. W/ n/ x
- (defun c:myhatch ()- P9 T* j/ y" P1 u$ A) B }& N
- (setq pa '(0 0 0))& s, t! O( k; D; I* ~
; ^# ^; S; R+ N+ l7 n' _" Q - (setq po '(300 300 0))
3 R, T0 n& r. M: l5 Y - (command "rectang" pa pb)3 X+ @) C$ |, O0 C
- (command "-color" 1)8 i" @) |3 h$ R e5 v
- (command "-hatch" po "P" "solid" "" ), W6 s6 r* d+ Z N& m8 P
- (princ)
9 m, _: Z. ]& {7 V# {3 ? - )
' j; f& C K# U8 P1 g; `, U
复制代码
7 w Z) H9 |* m& q5 a6 V[ 本帖最后由 woaishuijia 于 2008-10-6 06:55 编辑 ] |
