1.刀口型直尺:knife straigjht edge
' L; H) T# L1 M2 ?5 o1 s2.刀口尺: knife straigjht edge
! b+ v- B* P/ Y6 s2 I7 {3.三棱尺three edges straigjht edge- O( k! s" o; O- B8 |
4.四棱尺four edges straigjht edge0 v& d. a3 N2 ]# Y
5.条式和框式水平仪 bar form and square levels
- w6 l; N( n! B6 b1 q: Z" v6.合像水平仪 imaging level meter6 j0 h9 A9 C$ d% ?: Z
7铸铁平板 cast iron surface plate
: f3 t- G# g0 F7 V# X, Y7 I8.岩石平板 granite surface plate" Z- t' F2 M' q
9.铸铁平尺cast iron straigjht edge& R) V) _/ K I6 o; G. A, B
10.钢平尺和岩石平尺 steel and granite straigjht edge
# Y g3 D9 F1 {' O; i11.圆度仪 roundness measuring instrument
' ?$ L2 ~; o3 A12.电子水平仪electronic level meter0 a- U% n- N1 m, F9 j6 L' ^ M! \) T
13.表面粗糙度比较样块铸造表面 roughness comparison specimens cast surface
% t1 X' D. ]3 Z/ P t14.表面粗糙度比较样块磨、车、铣、插及刨加工表面
; t: _6 x/ B# E! e( croughness comparison specimens-ground,turned,bored,milled,shape and planed
$ |4 t5 w* u8 w15.表面粗糙度比较样块电火花加工表面9 w* [$ |; o- i9 _! \
roughness comparison specimens spark-erostion machining surfaces
$ M: ? l3 C+ X) ^16.表面粗糙度比较样块抛光加工表面
. V8 A# E- f4 ]4 ~- r3 [# g/ \+ j; z' {roughness comparison specimens pollshed surfaces& j- W8 G! I$ ?4 U
17.接触式仪器的标称特性
( z( n/ k! j* B5 ~$ B Y, p18.轮廓profiles
: W; y5 Y( m6 N/ g' I/ P3 t7 A9 w19.轨迹轮廓 traced profile: Z/ E0 ? @ D2 ]
20.基准轮廓 reference profile' g1 V/ ?% ~( ~- t5 `: P
21.总轮廓 total profile; @, h, P7 y& |2 i$ W ?1 m
22.原始轮廓 primary profile
6 ~' f8 S, v( p! @23.残余轮廓residual profile
y1 p9 E+ ]$ u3 z1 y24.触针式仪器stylus instrument
- \" A) r9 s: y25.感应位移数字存储触针式量仪displacement sensitive,digitally storing stylus instrument& M! O. d; Z+ E: N- \1 q
26.触针式仪器的部件stylus instrument components& K/ Z% ^4 S' X1 k- B8 K5 ?5 \- }4 s
27.测量环measurement loop
7 ?8 E- V H! k3 F5 p+ M- a28.导向基准renfence guide
' \! ^5 U" J7 R& N- W29.驱动器drive unit; n2 l9 B8 ?9 k
30.测头(传感器)probe(pick-up); z8 X9 P+ u" j* I2 @" ?* @
31.拾取单元tracing element0 ]; W4 x7 w0 Z5 Z! Z% ] x' q
32.针尖stylus tip. P& m6 k/ W F: V7 e- x: X
33.转换器transducer
& f+ G, w7 Q, x6 t34.放大器amplifier
1 i6 d) T3 M: O35.模/数转换器analog-to-digital converter
- k- S2 I9 e1 Z, T$ ]36.数据输入data input" j8 S$ S& s( ^9 l3 h- v/ X7 R# E
37.数据输出data output
?, b4 j4 C/ C3 ~ t: c, b) q38.轮廓滤波和评定profile filtering and evaluation
1 g J* W/ J. Y9 O39.轮廓记录器profile recorder8 X% o0 L g5 q" s5 Z5 Z* v
40.仪器的计量特性metrological characteristics of the instrument
# j$ s$ Y* [( C* l* G+ o41.静测力的变化change of static measuring force
7 i$ f! j: K B2 m- m6 _! {( w42.静态测力 static measuring force5 J* v/ u" I% M- G3 b" m! ]
43.动态测量力 dynamic measuring force
; X1 ^8 n# w8 n- e$ k( Z& }44.滞后hysteresis( M. U. H7 f3 W% ?# Q! N6 @
45.测头的测量范围 transmission function for the sine waves1 p9 D+ C. G& w9 {
46.仪器的测量范围measuring range of the instrument$ ^8 v7 l* B/ ]( m* [+ b! @
47.模数转换器的量化步距quantization step of the ADC- p4 W* x9 {0 X8 d! ?
48.仪器分辨力 instrument resolution6 z) x8 k& z, z' x, R' i
49.量程分辨力比range-to-resolution ratio; J& a2 J, o; o6 B8 V
50.测头线性偏差probe linearity deviation" z9 p, d7 q0 K0 G1 `9 B: U# }
51.短波传输界限short-wave transmission limitation7 L; {- |! L! v! T7 |
52.轮廓垂直成分传输 vertical profile component transmission1
( m9 c- B x* ] g53表面粗糙度比较样块抛丸、喷砂加工表面: Z) K. Q6 ~$ ]
roughness comparison specimens shot blasted and blasted surfaces+ S9 L8 b5 E8 C
54产品结构几何量计术规范(GPS)geometrical product specifications(GPS)5 W+ t3 T t; v4 j4 j
55表面结构 surface texture7 @# d7 W& r, j0 F/ `# f# q
56接触式仪器的标称特性 nominal characteristics of contact instruments% P U/ h% g0 Q7 _4 O& G
57公法线千分尺micrometer for mearsuring root tangent lenghths of gear teeth; |3 n/ M5 I; V7 u3 g9 ?
58最大允许误差 maximum permissible error
5 C' [& b% {- m6 c0 S6 g59圆柱直齿渐开线花键量规 gauges for straight cylindrical involute splines! J& u4 Q: {! T- t% ^0 x7 ^- j
60齿厚游标卡尺 Gear tooth vernier9 w% ~- ~& b6 F- e8 ] [' o. Y+ ]
calipers
* `& a$ A! q& _; {: m8 R; I61齿轮渐开线样板the involute master of gear
! a$ G7 q, @4 n! U" S- `9 c62齿轮螺旋线样板 the helix master of gear
! z1 \% k( p( f+ G4 E. }" Y63矩形花键量规 gauges for straight –sided splines
T# I- Z9 D$ ?) A: p) V9 S% R64测量蜗杆 master worm
: E: {4 q8 g6 @/ f; G! z7 _65万能测齿仪 universal gear measuring instrument
/ \9 @! p" K0 l- C# @& t" ~66万能渐开线检查仪universal involute measuring instrument+ O4 F4 R) V$ m# m; }
67齿轮齿距测量仪gear circular pictch measuring instrument
4 S2 d0 Y8 Z. {! T+ U68万能齿轮测量机 Universal gear measuring machine
2 x: Y5 G. F* q3 ^2 t" {9 y69齿轮螺旋线测量仪gear helix measuring instrument
$ J7 T8 }! |1 |, \. e3 ~2 j70便携式齿轮齿距测量仪 manual gear circular pitch measuring instrument
( {- f U& m0 G& `# g# G* E71便携式齿轮基节测量仪manual gear base pitch measuring instrument
4 z% x3 W1 `+ X: \+ d) ]3 m/ P72立式滚刀测量仪vertical hob measuring instrument
/ w: p( W) p8 v2 E8 N v8 q- a73齿轮双面啮合综合测量仪Gear dual-flank measuring instrument
1 |1 P* `; I. a- H74齿轮单面啮合整体误差测量仪Gear single-flank meshing integrated error measuring instrument2 @" A8 o% F* y$ M9 W1 c
75梯形螺纹量规 gauges for metric trapezoidal screw threads . Y/ I- I6 D' p" A
76工作螺纹量规work gauges for metric trapezoidal screw threads
9 u$ Q- H5 [! T7 I1 h& h ~77校对螺纹量规check gauges for metric trapezoidal screw threads! x! f8 h9 }9 }2 m, [: ]7 l
' [4 ], h+ m5 O. [- ^8 S+ m78.梯形螺纹量规型式与尺寸 Types and dimensions of metric trapezoidal screw threads; R8 s1 G" x% |3 S
79.普通螺纹量规型式与尺寸 Types and dimensions of gauges purpose screw threads
7 i3 M" o! J" Z1 M q3 _80.非螺纹密封的管螺纹量规 Gauges for pipe threads prcessure-tight joints are not made on the threads0 j1 B. n( @; M! A' i i% e
81.螺纹千分尺
) t% G% x8 p" c0 {- bScrew thread micrometer
3 ?% m- A v# k* z$ o82.最大允许误差 maximum permissible error
" B1 [, K3 @; R3 m( g83.间隙螺纹量规 Clearance screw gauge
X- V8 z7 @! K3 G84.量针
" i- |) b; P. v9 T3 ?! G, oBar gauge
1 i3 h0 k3 A$ G0 `1 N85.螺纹样板 Screw thread template- G) ]& l3 Z! }1 v' S
86.用螺纹密封的管螺纹量规
4 k1 m) {' z4 M! d0 ]4 W0 pGauges for pipe threads where pressure-tight joints are made on the threads
: j9 M: j( I! \7 y3 P87.刀具预调测量仪 精度0 k0 ?9 O5 N/ i. V6 ]$ I8 ]# v
Accuracy of the presetting instrument t/ u# z& m) K/ o
88.薄膜式气动量仪5 {7 C6 ~* @* h+ H- U
Membrane type pneumatic measuring instrument. @0 e z5 y1 C2 @3 y, g5 L5 Y
89.光栅线位移测量系统
3 c' T* s) @; z+ N/ ~# G' N- ?Grating linear displacement measuring system0 Z; [' c3 J" D1 r
90.光栅角位移测量系统+ N* P. v1 g& Z7 d
Grating angular displacement measuring system
4 I0 C f) ^# \. {3 Y+ e$ z' j91.磁栅线位移测量系统
, y; i, j9 d" R0 ^ E4 EMagnet-grid linear displacement measuring system6 M. y4 q4 \3 W5 I
92.量块附件4 J5 I+ V, J* ~5 {( j8 J
Accessories for gauge blocks. [3 @ A+ Y7 F" c
93.V形架
% [, N, K4 a7 E" l# uVee blocks
) a( ?1 i+ S) h. \9 W2 L94.比较仪座
2 z: y- Q" ?; P3 C8 t( i* @( l8 ZComparator stand( p. U$ ~$ [; l$ l5 Q+ s
95.磁性表座
) M; j# M) T5 }1 l: UMagnetic stand
! X4 y: T$ O1 D' D/ x- m! J" X# D96.万能表座
- O2 T' S5 e5 H1 {9 B- \4 `9 w3 FUniversal stand for dial indicator |
