查看: 2295|回复: 4
[分享] Cimatron E实体入门DOC版本
发表于 2008-10-19 13:32:28 | 显示全部楼层 |阅读模式 来自: 中国安徽宣城
目录Table of Contents  y3 l$ k9 q% f# C
实体入门Solid Introduction............................................................................... 3
- s# f% \/ s5 ^5 l2 ~# p6 P导动Drive........................................................................................................................ 4/ c1 }9 r) k" R; n. o
导动描述+ V5 o) E8 ?+ r- r# h5 O
Drive Description............................................................................................... 4
& k( p9 O7 H% b3 a* E( [
拉伸$ X5 R" `. P; `& o% z
Extrude..................................................................................................................... 5
0 X( {* c* m: `" B: b
组合
9 D& U6 o) u; W( o% d7 }+ yComposite................................................................................................................. 7
, E: B/ v. [6 b6 h: U+ n+ h$ x
截面. z. B+ V+ F' A. p8 I/ G4 G7 B: m
Section...................................................................................................................... 9
* E4 h% _& U: g& x$ {; M1 v( {导动
. I, i  n6 r, a1 [5 Q- ^; r1 xDrive......................................................................................................................... 9
1 Z, |  }  K8 J
镜像
& F9 i/ r! j* h7 ^. {Mirror......................................................................................................................
11
5 P" m9 ^( E# K" F5 A0 i
分开
+ b( M& H- R8 G0 v" R# EDivide..................................................................................................................
12
) E3 `" S! G! J3 o: V4 J5 S( Z
输入0 l. \* a& e0 i5 |: E
Import.....................................................................................................................
12
  _2 N) P6 q: \% L裁剪
. O% Q$ `# U: s5 D+ WTrim 1.....................................................................................................................
13
- U$ H! M. r$ c/ |. J5 m3 G
裁剪& M  p5 m8 w) B
Trim 2.....................................................................................................................
15
2 v) _, K" H4 v3 \混合Blend........................................................................................................................ 16
6 Z5 D8 ^8 x8 |& ^; O开放边界Open Edges....................................................................................................... 18! q6 _9 n2 @; P& w  i# Y2 H# r) o
激活. E* ^: n  F: y3 K, J% r  l% r3 Q
Activate...................................................................................................................
19
$ c9 \' m9 b( W( O切割4 r6 |8 k9 E1 H- j# `
Cut..........................................................................................................................
21
9 m; n. ^: [) O- m1 o5 k导动 2 Drive 2................................................................................................................. 24
5 P: ?9 I3 \: q4 ~/ j圆角3 O# w2 n$ ~" {/ U
Rounds................................................................................................................
27
  @: w/ x( o+ ^1 Z6 k) M
线性: A8 t3 E0 ^2 W1 u0 v  o. }
Linear......................................................................................................................
27
$ u# e+ `2 ~3 M) I  }样条
. U- n) c% o* k9 cSpline......................................................................................................................
28
2 P2 N6 e- O1 T圆角+ Q& W( f! x3 F7 a: }
Rounds....................................................................................................................
29
# U# |) y: p# e  u& K
旋转
" s6 i; q) B* F" xRevolve...................................................................................................................
30
% F$ ~9 x6 {8 K# Z! ?* r多重Multi......................................................................................................................... 336 S2 ?6 O! o( j
预览
& ?6 z( r1 k) O) L. s( UPreview...................................................................................................................
34
; ~9 L( z3 {( i% `
合成Loft........................................................................................................................ 36
3 U9 `0 P; H2 N4 M; m平面! E$ H: X4 P7 J( b+ I0 u  Q, l
Planes.....................................................................................................................
36
4 g0 M/ p( @5 C5 }6 H2 i3 B
草图
& h9 p, c5 C# J5 u8 @Sketch 1..................................................................................................................
38
/ _/ K' }7 S+ L4 V5 l
草图Sketches.................................................................................................................... 40
4 B" g0 p/ t  R' Z! Z8 S4 c合成Loft........................................................................................................................... 42
7 D6 x! t; c, A/ v( X0 a拉伸$ G" w" H) A1 M$ H8 a
44
. I+ L  R- t1 V! b7 V
穿过" @+ Q& n. B7 k! Y) S/ ]; {5 m
Through................................................................................................................... 44
8 Y* w* l. s+ q7 S  S" l
拔模角
5 K' A8 L. A0 X  |' ?+ ]Draft Angle.......................................................................................................... 46
9 u: x, S. v! ?6 `  y$ M( R
YZ 平面4 n& f4 h9 |! ?7 ]: E& ]3 N: x# a
YZ plane........................................................................................................... 48
5 g* M9 V/ p+ t中平面增量Delta mid Plane.............................................................................................. 49" g# \5 s2 J$ o- [0 P
拉伸
( u7 k* m6 _' [: C! ?/ \* q5 l- FExtension................................................................................................................. 51
. ^+ p3 {9 t1 X0 [0 h( J阴影拔模
& _0 E" ?% [" r. {+ s! w* _Shadow Taper........................................................................................ 52
' I3 W/ U  ~1 C0 k3 Y- I. G+ d
1 C9 Y' W3 I% ^7 i6 ZShell............................................................................................................................ 52
! w9 C4 R# G  C拉伸去除' e" S/ W$ P( ^5 \$ ^( ^& e+ h
Extrude Remove............................................................................................... 53
& N+ X! v/ v- v. |3 x) e( m; O- F; D, U
Cimatron E实体入门.rar
1000.97 KB, 下载次数: 287
发表于 2010-2-1 21:03:48 | 显示全部楼层 来自: 中国山东
好东西,多长些
发表于 2010-2-1 21:09:22 | 显示全部楼层 来自: 中国黑龙江哈尔滨
E4版本的,不过对粗学者还是有帮助的
发表于 2010-6-29 13:33:15 | 显示全部楼层 来自: 中国浙江宁波
xiexie  an shi xin shou
发表于 2010-6-29 16:34:11 | 显示全部楼层 来自: 中国山东
借阅一下,不知有深点的吗
