查看: 7682|回复: 29
[原创] Ai Design 2007
发表于 2008-10-28 16:19:22 | 显示全部楼层 |阅读模式 来自: 马来西亚
Ai CAD design tooling plug-in for autocad
9 d- V. f& w5 rnot yet crack, any guys can crack it pls do
; b6 I! ]4 f' }& d/ |& b7 Uand share here; E+ m* H. d: o1 c4 \; R1 B2 U6 C) H
" [/ e8 a0 S# d# d5 v8 K
Tq
AI_Design_2007.part1.rar
1.39 MB, 阅读权限: 25, 下载次数: 30
rar file
AI_Design_2007.part2.rar
512.12 KB, 阅读权限: 25, 下载次数: 30
rar file
 楼主| 发表于 2008-10-28 16:43:35 | 显示全部楼层 来自: 马来西亚
file uploaded
发表于 2008-10-28 17:28:58 | 显示全部楼层 来自: 中国山东青岛
我晕~又是E文的 啊 ~~~我晕了 啊 就不能传中文的啊 晕了 啊
发表于 2008-10-28 20:23:19 | 显示全部楼层 来自: 中国安徽芜湖
Please make a introduce.
 楼主| 发表于 2008-10-28 21:40:38 | 显示全部楼层 来自: 马来西亚
原帖由 ss988 于 2008-10-28 20:23 发表 http://www.3dportal.cn/discuz/images/common/back.gif
& n" X  B8 X* J. qPlease make a introduce.
! [/ g- r0 Z4 B
' Z3 j( f- f1 q, w0 \
AI Tool Design Gold Edition is one of the most cost effective, productive and comprehensive tool & die design and manufacturing solution available for the industry. It is built base on the most innovative non-constraint rule-based parametric and Al (Artificial Intelligent) technologies. AI Tool Design adopt the knowledge-based design concept that allows the user to input the basic design knowledge and data into the system for optimum design effectiveness and efficiency. Thus, It reduces the human errors and eliminates the repetitive designing and drafting tasks.9 O$ v8 o8 r& c
With AI Tool Design, the designers no longer need to spend their valuable time for detail drawing drafting, almost all of the time consuming designing and drafting task are now assisted and done by the automation features of the AI Tool Design. The designers will optimize their time for more value added task: to continuously enhance the tool design quality and research and development of new tooling technology.# u( P: r4 e1 S# u( I, }
3 [$ _0 g- Z" w* F8 f% gAI Tool Design helps the designer throughout the entire design process from flat blank development, strip design, strip simulation, assembly design, holes and profiles definition etc until drawing dimensioning, detailing. During the designing process, the designers will gain great advantages from the fully associative context of AI Tool Design. The Al association engine links all the related drawing objects together. For instance, moving a hole will update all the associated hole list in the entire assembly regardless whether the relevant layer is off or freeze. Delete a hole will also remove all related hole list. Such powerful design context will definitely improve the design quality and productivity tremendously.
5 I; x: E) u0 W7 H3 a. r9 q
' N- A$ T9 f/ Y. U8 m; NAI Tool Design offers a basic set of customization features within the system to allow the designers to customize the system according to their company standard and preferences.: y) c" O  N8 }/ [8 P  R9 S
1 e4 A( j: G# U' @9 gAl Solution offer a full range of CAD/CAM products including AI Tool Design Platinum Edition, Gold Edition, Classic Edition, Al Wire, Al Mill and Al Drill. All the products are fully integrated for maximum productivity. AI Tool Design is fully compatible with the higher version of Al solution such as the Platinum Edition so the future upgrade to a more powerful platform is ready.) i$ Y: M6 y& Q& z+ H
  r! {! E6 ^4 y  \& ~4 ]( n1 F& C
AI Tool Design built on top of the world''s most popular AutoCAD software and leverage on Autodesk''s ObjectARX, Active-X, VBA and Visuallisp technology.
发表于 2008-10-28 22:27:55 | 显示全部楼层 来自: 中国江苏苏州
Ai Design 2007
楼主这样还是不要放在上面好了,这么高的威望没有谁可以下,强烈要求版主删去此贴,不要浪费我们有现的资源供大家学习!!!
发表于 2008-10-29 21:49:14 | 显示全部楼层 来自: 中国江苏苏州
强烈要求删除,不要浪费空间
强烈要求删除,不要浪费空间
发表于 2008-10-30 07:32:03 | 显示全部楼层 来自: 中国北京
楼主是在开玩笑吧,这么高的威望,论坛有几人啊
发表于 2008-11-11 15:02:34 | 显示全部楼层 来自: 中国浙江杭州
权限是不是设的高了点?
发表于 2008-12-2 00:53:40 | 显示全部楼层 来自: 中国广东惠州
一定不是什么好东西
; c3 h. w& d8 ~# |  O; e# q3 @要不怎么那么高的权限
 楼主| 发表于 2008-12-3 19:32:30 | 显示全部楼层 来自: 马来西亚
this plug-in only basic package- n5 ?. h+ |0 |) o
and using 2 secure one hardlock (Sentinel usbPro)
# Q4 B& S- o5 {and authorize code to run the program
, W0 \) B6 u# y% X0 i+ uthe gold package can see here http://www.3dportal.cn/discuz/vi ... 41&highlight=v6
发表于 2008-12-3 20:55:39 | 显示全部楼层 来自: 中国山东青岛
这个软件多少钱?完整版程序多大?楼主有没有正式的完整版?
 楼主| 发表于 2008-12-3 22:49:00 | 显示全部楼层 来自: 马来西亚
refer attachment file above,
2 r) ]5 q" D0 Ait's original file
& Z" `  M# P% Pyou don't have dongle, you can't run the software+ u4 {6 |# u' F  G& d; O4 d# D: q
if you using emulator the software can run but need code to fully run
 楼主| 发表于 2008-12-5 22:19:15 | 显示全部楼层 来自: 马来西亚
some of the Ai Design 2007
 楼主| 发表于 2008-12-5 22:35:12 | 显示全部楼层 来自: 马来西亚
some of them
发表于 2008-12-5 22:57:09 | 显示全部楼层 来自: 中国贵州遵义
终于找到Crack了
/ d  k2 E! _0 |. W/ e还没有试用
发表于 2008-12-6 09:27:18 | 显示全部楼层 来自: 中国广东广州
发表于 2008-12-11 21:29:59 | 显示全部楼层 来自: 中国山东青岛
lantoi快加我qq:329404408啊!
发表于 2009-1-5 15:26:11 | 显示全部楼层 来自: 中国广东东莞
不知是否為完整的...
发表于 2009-2-9 20:35:31 | 显示全部楼层 来自: 中国广东中山
原来楼主是来这灌水的啊
发表于 2009-2-26 12:33:03 | 显示全部楼层 来自: 中国广东佛山
挂在autocad的?
发表于 2009-2-27 09:07:48 | 显示全部楼层 来自: 中国湖南株洲
什么东西?不能写中文啊。
 楼主| 发表于 2009-3-4 19:37:35 | 显示全部楼层 来自: 马来西亚
who can make emulator file data,
& g# u$ U! }. j1 P9 L" V; G) Fi got original data dongle and Application Key#3 ]2 i0 `) a  D0 u. X2 N
email=cadman8@gmail.com
发表于 2009-4-2 16:36:32 | 显示全部楼层 来自: 中国湖北武汉
时间过去这么久了,楼主能否降低权限?浪大家都学学。
发表于 2009-6-16 15:01:52 | 显示全部楼层 来自: 中国辽宁大连
楼主有教程吗
