查看: 1635|回复: 5
[风能] Vestas用户指南
发表于 2008-10-28 16:27:47 | 显示全部楼层 |阅读模式 来自: 中国湖南湘潭
目录 ............................................................................................................... ..页6 i# y2 b$ {, v5 o* G3 G$ X
1. 操作说明.......................................................................................................................... 2
+ t+ A2 b: V' f' P" n* q( W* \0 l2. 集成终端.......................................................................................................................... 3
( d: v1 }% a: i( M8 `0 n: h3 @8 b3. 用户模式画面................................................................................................................... 5. J+ Y; r3 |! a. P! H4 W9 |2 T1 A
4. 画面总览.......................................................................................................................... 6- o3 q# P# a( z0 o+ D# h8 b/ G
5. 发电量统计...................................................................................................................... 7; f/ E2 w$ [( {2 g4 ?
6. 小时统计.......................................................................................................................... 9$ A% w- I2 L; c( \* F
7. 可利用率........................................................................................................................ 117 r' y2 y& q0 G4 n7 O! l
8. 电气参数........................................................................................................................ 119 k  o5 A9 b7 u( {* P: t2 j
9. 温度...............................................................................................................................128 z# l% l3 p( e) q  K
10. 警告日志........................................................................................................................ 14; A* m; `3 p/ A' v' y/ L5 e1 U
11. 运行日志........................................................................................................................ 140 W$ ]+ t  B, {5 Z# u
12. 报警日志........................................................................................................................ 16. A) h6 H$ C2 _2 g0 ]0 _9 L: F
13. 画面总览........................................................................................................................ 16
944643zh.V09_V80 User Guide.pdf
407.8 KB, 下载次数: 54
发表于 2008-10-28 22:34:59 | 显示全部楼层 来自: 中国上海
谢谢LZ提供的资料5 ?' }4 p) T* d3 A6 F3 s- q- {/ ?
这个是针对风电场最终用户的手册,主要是控制这块的
 楼主| 发表于 2008-11-7 22:26:55 | 显示全部楼层 来自: 中国内蒙古乌兰察布
值得注意的是,每种机型的模态设定不一样,所以每种机型的控制策忧也不一样,注意分析,此文仅供学习探讨用!
发表于 2008-11-9 00:36:08 | 显示全部楼层 来自: 中国河北保定
谢谢LZ提供的资料
发表于 2008-11-9 15:42:51 | 显示全部楼层 来自: 中国辽宁沈阳
不错的资料,不过推荐用LINUX!
发表于 2008-11-9 19:08:21 | 显示全部楼层 来自: 中国四川成都
是好东西啊!!!
