发表于 2008-10-31 15:51:12
|阅读模式
来自: 中国内蒙古包头
硅片行业术语大全(中英文对照 A-H)
9 t/ V2 d& I) X& X* {( f! s. M) Q$ s, E5 j" t
Acceptor - An element, such as boron, indium, and gallium used to create a free hole in a semiconductor. The acceptor atoms are required to have one less valence electron than the semiconductor.
! O/ }, ~& a6 i0 |$ i受主 - 一种用来在半导体中形成空穴的元素,比如硼、铟和镓。受主原子必须比半导体元素少一价电子
# N( Y) v0 r: |# @8 r. r1 dAlignment Precision - Displacement of patterns that occurs during the photolithography process.
2 P+ f" L7 V1 E" k3 V+ P0 y; ]套准精度 - 在光刻工艺中转移图形的精度。
9 U! B2 c) q+ H) H0 |6 {Anisotropic - A process of etching that has very little or no undercutting
# F. K; A" X% A9 P7 F, u5 Z各向异性 - 在蚀刻过程中,只做少量或不做侧向凹刻。 0 R$ |, s6 G E$ k
Area Contamination - Any foreign particles or material that are found on the surface of a wafer. This is viewed as discolored or smudged, and it is the result of stains, fingerprints, water spots, etc. ! Z5 q0 A3 k" q) U. z; h
沾污区域 - 任何在晶圆片表面的外来粒子或物质。由沾污、手印和水滴产生的污染。
" C: g) a+ l2 b3 [, D& y* X* _Azimuth, in Ellipsometry - The angle measured between the plane of incidence and the major axis of the ellipse. 0 R( M* `% w/ x- E/ M$ L$ B
椭圆方位角 - 测量入射面和主晶轴之间的角度。
% w: }' U' Y! |- [* N) M7 bBackside - The bottom surface of a silicon wafer. (Note: This term is not preferred; instead, use ‘back surface’.)
* V9 R! ?9 i8 ]( k2 Q& A+ |背面 - 晶圆片的底部表面。(注:不推荐该术语,建议使用“背部表面”) 7 i6 U2 t* V7 p# U0 S! E# Y& X
Base Silicon Layer - The silicon wafer that is located underneath the insulator layer, which supports the silicon film on top of the wafer. ( s! i! ?2 K7 p. M
底部硅层 - 在绝缘层下部的晶圆片,是顶部硅层的基础。 ) f+ _, o% I: u2 D: B6 f, b! ~, d" N
Bipolar - Transistors that are able to use both holes and electrons as charge carriers. 5 r, H j5 u! }+ B
双极晶体管 - 能够采用空穴和电子传导电荷的晶体管。
! { I: j s3 x! \+ r0 h8 XBonded Wafers - Two silicon wafers that have been bonded together by silicon dioxide, which acts as an insulating layer.
" l f0 t( ~) Y6 T: _' P, H绑定晶圆片 - 两个晶圆片通过二氧化硅层结合到一起,作为绝缘层。 % H! @7 F& G: Q/ }* u4 j
Bonding Interface - The area where the bonding of two wafers occurs.
( ? F/ y) g3 ~3 J6 w+ Z* E绑定面 - 两个晶圆片结合的接触区。 ; c/ h2 O+ [! E* k" S# v9 |# {* y
Buried Layer - A path of low resistance for a current moving in a device. Many of these dopants are antimony and arsenic.
5 a3 G; v" f6 Y2 j. E2 }- }' T5 _8 L埋层 - 为了电路电流流动而形成的低电阻路径,搀杂剂是锑和砷。 , H6 w7 j( W; b3 x
Buried Oxide Layer (BOX) - The layer that insulates between the two wafers. 2 |" P( t, n( y" B
氧化埋层(BOX) - 在两个晶圆片间的绝缘层。 0 V# D0 Y9 B0 {% ? c
Carrier - Valence holes and conduction electrons that are capable of carrying a charge through a solid surface in a silicon wafer. 0 j3 `1 I; d' x! s( l
载流子 - 晶圆片中用来传导电流的空穴或电子。
7 g1 N6 a. T2 Z5 DChemical-Mechanical Polish (CMP) - A process of flattening and polishing wafers that utilizes both chemical removal and mechanical buffing. It is used during the fabrication process.
" h. D$ P+ N9 i( q, J/ Z( |9 a化学-机械抛光(CMP) - 平整和抛光晶圆片的工艺,采用化学移除和机械抛光两种方式。此工艺在前道工艺中使用。 & ?+ q( x( L- Y
Chuck Mark - A mark found on either surface of a wafer, caused by either a robotic end effector, a chuck, or a wand. 2 h- p9 D& T" X2 v
卡盘痕迹 - 在晶圆片任意表面发现的由机械手、卡盘或托盘造成的痕迹。
, c, u' X* a5 o# A2 {Cleavage Plane - A fracture plane that is preferred.
! I- I0 c3 o; r1 T1 l4 a9 a( p解理面 - 破裂面 # G# q2 X4 c5 d: _7 f4 g' k
Crack - A mark found on a wafer that is greater than 0.25 mm in length. 7 P$ U3 _' M( T! `2 l
裂纹 - 长度大于0.25毫米的晶圆片表面微痕。 ) l/ J0 m$ A0 j5 ^2 B3 K
Crater - Visible under diffused illumination, a surface imperfection on a wafer that can be distinguished individually.
, `2 a0 Q' i" O. n1 f& r) ^微坑 - 在扩散照明下可见的,晶圆片表面可区分的缺陷。
( A+ O% t5 e- |) b( Z1 [Conductivity (electrical) - A measurement of how easily charge carriers can flow throughout a material. ! t/ F# D) T, k+ d
传导性(电学方面) - 一种关于载流子通过物质难易度的测量指标 。
& x) m2 R; U* e: KConductivity Type - The type of charge carriers in a wafer, such as “N-type” and “P-type”. x( r4 V3 S' f; n6 X
导电类型 - 晶圆片中载流子的类型,N型和P型。
) N/ A+ B. k* H7 x+ UContaminant, Particulate (see light point defect) ! {+ B0 U. {' h$ q7 y% @, {1 C
污染微粒 (参见光点缺陷) + n( S3 F r/ m8 }' e
Contamination Area - An area that contains particles that can negatively affect the characteristics of a silicon wafer. ^& G, h2 V+ h. L3 F2 ?
沾污区域 - 部分晶圆片区域被颗粒沾污,造成不利特性影响。 / n+ y. T3 ~# \0 O* m1 V& d
Contamination Particulate - Particles found on the surface of a silicon wafer. ' N# x( f1 C, W
沾污颗粒 - 晶圆片表面上的颗粒。 3 G( _0 |! ~$ ~: p/ E1 J
Crystal Defect - Parts of the crystal that contain vacancies and dislocations that can have an impact on a circuit’s electrical performance.
8 M3 V4 G2 K/ L) P. {晶体缺陷 - 部分晶体包含的、会影响电路性能的空隙和层错。7 d/ T1 o. B* A! y5 d/ |
Crystal Indices (see Miller indices) / l4 D6 u8 Y, _ a
晶体指数 (参见米勒指数) + I6 k2 E) ]3 ]4 s B* t) ~8 _! X
Depletion Layer - A region on a wafer that contains an electrical field that sweeps out charge carriers.
. N% v; n) Y* g# t耗尽层 - 晶圆片上的电场区域,此区域排除载流子。
+ x5 K. M7 H4 h$ uDimple - A concave depression found on the surface of a wafer that is visible to the eye under the correct lighting conditions. : [- @$ H3 D2 I5 v5 k* t
表面起伏 - 在合适的光线下通过肉眼可以发现的晶圆片表面凹陷。 : H& @% i1 w& Q
Donor - A contaminate that has donated extra “free” electrons, thus making a wafer “N-Type”.
* S' c; p n: A i施主 - 可提供“自由”电子的搀杂物,使晶圆片呈现为N型。
: v/ Q- f6 d( z a( PDopant - An element that contributes an electron or a hole to the conduction process, thus altering the conductivity. Dopants for silicon wafers are found in Groups III and V of the Periodic Table of the Elements.
) ?/ b% {* @1 H6 l0 h9 ]; t搀杂剂 - 可以为传导过程提供电子或空穴的元素,此元素可以改变传导特性。晶圆片搀杂 剂可以在元素周期表的III 和 V族元素中发现。
9 o' O2 O2 T3 y# CDoping - The process of the donation of an electron or hole to the conduction process by a dopant.
- q% g2 g) \( }6 u/ `: {- h掺杂 - 把搀杂剂掺入半导体,通常通过扩散或离子注入工艺实现。 3 v9 p, u+ |/ \! r- Z1 w. ?0 a
Edge Chip and Indent - An edge imperfection that is greater than 0.25 mm. . S5 L ]% d3 c) l$ z
芯片边缘和缩进 - 晶片中不完整的边缘部分超过0.25毫米。
$ ^3 q$ A ~6 a+ r4 }, x2 KEdge Exclusion Area - The area located between the fixed quality area and the periphery of a wafer. (This varies according to the dimensions of the wafer.) 3 J6 }$ H, k0 M8 |' ^3 R
边缘排除区域 - 位于质量保证区和晶圆片外围之间的区域。(根据晶圆片的尺寸不同而有所不同。)
; f" Y- m5 G1 S+ G7 F5 I3 kEdge Exclusion, Nominal (EE) - The distance between the fixed quality area and the periphery of a wafer. * k5 H# n6 O4 o- a
名义上边缘排除(EE) - 质量保证区和晶圆片外围之间的距离" g; M) K( j) n
Edge Profile - The edges of two bonded wafers that have been shaped either chemically or mechanically. # q, \( L& l; ~0 k
边缘轮廓 - 通过化学或机械方法连接起来的两个晶圆片边缘。 4 m( E5 \# `# P7 Y4 z
Etch - A process of chemical reactions or physical removal to rid the wafer of excess materials.
|% V) e5 p" ?. z蚀刻 - 通过化学反应或物理方法去除晶圆片的多余物质。
# n& D6 E& n6 {* i; C) f8 ~Fixed Quality Area (FQA) - The area that is most central on a wafer surface. 0 ~! C$ q1 \- ?% x: k2 B" C
质量保证区(FQA) - 晶圆片表面中央的大部分。 : P! V) Z8 a3 _; K1 R- H% d0 a( x
Flat - A section of the perimeter of a wafer that has been removed for wafer orientation purposes.
8 Z+ E- e2 K: e平边 - 晶圆片圆周上的一个小平面,作为晶向定位的依据。 3 |+ k, g! G: W, D7 l$ g, A
Flat Diameter - The measurement from the center of the flat through the center of the wafer to the opposite edge of the wafer. (Perpendicular to the flat) ) E; T0 ?& V+ y2 A! p1 V' o/ O
平口直径 - 由小平面的中心通过晶圆片中心到对面边缘的直线距离。
$ B! A2 t: d/ C, ~+ t1 xFour-Point Probe - Test equipment used to test resistivity of wafers.
& g. }9 d+ g+ M4 w3 t7 O( _四探针 - 测量半导体晶片表面电阻的设备。
2 J0 o" p. {$ EFurnace and Thermal Processes - Equipment with a temperature gauge used for processing wafers. A constant temperature is required for the process.
9 ~- |% t6 u/ [0 @4 e炉管和热处理 - 温度测量的工艺设备,具有恒定的处理温度。. v7 p, |, Y" U7 A% I% [7 S
Front Side - The top side of a silicon wafer. (This term is not preferred; use front surface instead.)
, q* ?) o8 `4 r正面 - 晶圆片的顶部表面(此术语不推荐,建议使用“前部表面”)。
* I" A. X- P5 TGoniometer - An instrument used in measuring angles.
( K# ~ e5 |2 Q0 J- w" X4 N0 g角度计 - 用来测量角度的设备。 0 I8 v* y; L" i9 {( Q+ N. K
Gradient, Resistivity (not preferred; see resistivity variation)
9 K3 K; W8 i! I. @$ @" V电阻梯度 (不推荐使用,参见“电阻变化”)
! z- n& p# ^, gGroove - A scratch that was not completely polished out.
$ y+ Y! {$ t8 o凹槽 - 没有被完全清除的擦伤。 ' K# }, s2 |" `
Hand Scribe Mark - A marking that is hand scratched onto the back surface of a wafer for identification purposes. 5 a- f5 k4 ^& c
手工印记 - 为区分不同的晶圆片而手工在背面做出的标记。7 g. ^9 k4 d) i& X
Haze - A mass concentration of surface imperfections, often giving a hazy appearance to the wafer. 5 ^* ?5 f6 ?) p; Z$ K+ @
雾度 - 晶圆片表面大量的缺陷,常常表现为晶圆片表面呈雾状。9 Y9 B3 r3 g7 V4 B: s" ^
Hole - Similar to a positive charge, this is caused by the absence of a valence electron.
6 K% P! H, k U$ `空穴 - 和正电荷类似,是由缺少价电子引起的。: H0 M) j6 T: h9 W9 q
硅片行业术语大全(中英文对照 I-Z)
; r1 h* l9 x* [/ G8 Y- f
0 e- x6 e6 }9 E' ]3 V& cIngot - A cylindrical solid made of polycrystalline or single crystal silicon from which wafers are cut.
D/ }" Z: B% F- e2 H晶锭 - 由多晶或单晶形成的圆柱体,晶圆片由此切割而成。
: B/ J9 ^- m" Z, a+ ^3 S8 cLaser Light-Scattering Event - A signal pulse that locates surface imperfections on a wafer.
4 M4 w8 Z+ K5 \+ v/ s2 f激光散射 - 由晶圆片表面缺陷引起的脉冲信号。
& l- l. U1 y4 a8 f% bLay - The main direction of surface texture on a wafer. ! v7 A7 q( b( s& `* ^) u6 w
层 - 晶圆片表面结构的主要方向。 . N3 E2 T- s' } [) J
Light Point Defect (LPD) (Not preferred; see localized light-scatterer) 0 U4 `9 s$ M9 @5 L
光点缺陷(LPD) (不推荐使用,参见“局部光散射”)
2 ?# Y+ @9 e1 u3 U8 c: uLithography - The process used to transfer patterns onto wafers. & ], | ? E2 u4 D
光刻 - 从掩膜到圆片转移的过程。
1 x* J3 U. U* yLocalized Light-Scatterer - One feature on the surface of a wafer, such as a pit or a scratch that scatters light. It is also called a light point defect.
3 ~8 M6 \5 Q" E& K) ~# u$ h局部光散射 - 晶圆片表面特征,例如小坑或擦伤导致光线散射,也称为光点缺陷。
; s8 p, B+ Y: { J2 nLot - Wafers of similar sizes and characteristics placed together in a shipment.
- \7 P% s( a2 _5 I4 t批次 - 具有相似尺寸和特性的晶圆片一并放置在一个载片器内。
& X& j! a* b. R) f3 p6 d \+ |7 fMajority Carrier - A carrier, either a hole or an electron that is dominant in a specific region, such as electrons in an N-Type area.
8 V" G. ? v, L4 J7 _& w多数载流子 - 一种载流子,在半导体材料中起支配作用的空穴或电子,例如在N型中是电子。 ) v+ b. g! l4 J2 Q8 x" o" f
Mechanical Test Wafer - A silicon wafer used for testing purposes.
1 u) `7 N; G/ {2 B ~* g机械测试晶圆片 - 用于测试的晶圆片。
6 q7 O' s, n# @; s! z6 mMicroroughness - Surface roughness with spacing between the impurities with a measurement of less than 100 μm. ( f G, L5 O) H/ P
微粗糙 - 小于100微米的表面粗糙部分。 ; y# [6 o' B6 Z
Miller Indices, of a Crystallographic Plane - A system that utilizes three numbers to identify plan orientation in a crystal.
! A* w- L0 X* PMiller索指数 - 三个整数,用于确定某个并行面。这些整数是来自相同系统的基本向量。
( @" ^# t9 m) m: E7 vMinimal Conditions or Dimensions - The allowable conditions for determining whether or not a wafer is considered acceptable.
8 }# ^* P8 d R) u最小条件或方向 - 确定晶圆片是否合格的允许条件。
. D8 H7 N4 j# h% I* V* D6 YMinority Carrier - A carrier, either a hole or an electron that is not dominant in a specific region, such as electrons in a P-Type area. 7 U% }) m$ A6 Y% e- X
少数载流子 - 在半导体材料中不起支配作用的移动电荷,在P型中是电子,在N型中是空穴。
+ Z* V2 z8 p bMound - A raised defect on the surface of a wafer measuring more than 0.25 mm. " x7 P8 K1 Y& N0 J
堆垛 - 晶圆片表面超过0.25毫米的缺陷。 2 i, ]$ C, g0 P4 g
Notch - An indent on the edge of a wafer used for orientation purposes.
5 ~# \$ ~9 |% V0 q, Z凹槽 - 晶圆片边缘上用于晶向定位的小凹槽。 # T7 J# n0 ?8 e; |# t0 j! s
Orange Peel - A roughened surface that is visible to the unaided eye.
5 Q0 S. C( Q% j桔皮 - 可以用肉眼看到的粗糙表面
7 z: M" H3 Q% \1 i+ ?. Q" |Orthogonal Misorientation -
8 x7 G0 p8 f; k7 e5 {直角定向误差 - 9 J+ w) e5 m, y. j
Particle - A small piece of material found on a wafer that is not connected with it. : R# v( O1 P2 L) K4 b$ ^# k
颗粒 - 晶圆片上的细小物质。 & A2 }! P* m! W; s6 E
Particle Counting - Wafers that are used to test tools for particle contamination.
$ e* n' ~. O9 {1 `2 E3 k0 `颗粒计算 - 用来测试晶圆片颗粒污染的测试工具。 F5 v! ^" G$ q: i, x4 r
Particulate Contamination - Particles found on the surface of a wafer. They appear as bright points when a collineated light is shined on the wafer.
% E$ X6 B2 c7 b9 C# h颗粒污染 - 晶圆片表面的颗粒。
* d4 s6 X4 l; H2 SPit - A non-removable imperfection found on the surface of a wafer.
+ V3 ]1 k/ t1 t( [2 u% M# l( ~深坑 - 一种晶圆片表面无法消除的缺陷。
* R" y) P% q, x/ L. W) \. DPoint Defect - A crystal defect that is an impurity, such as a lattice vacancy or an interstitial atom. ( C2 L1 u* ] S3 L& P
点缺陷 - 不纯净的晶缺陷,例如格子空缺或原子空隙。 5 K! `0 U9 U$ R" B
Preferential Etch - ' Q" i2 M! g4 R) ~
优先蚀刻 - 0 R* Z$ P1 u& b/ D
Premium Wafer - A wafer that can be used for particle counting, measuring pattern resolution in the photolithography process, and metal contamination monitoring. This wafer has very strict specifications for a specific usage, but looser specifications than the prime wafer.
: D) W A2 R: G3 v9 e! q测试晶圆片 - 影印过程中用于颗粒计算、测量溶解度和检测金属污染的晶圆片。对于具体应用该晶圆片有严格的要求,但是要比主晶圆片要求宽松些。
r) w: X/ Q+ _# dPrimary Orientation Flat - The longest flat found on the wafer.
, B) X5 K7 |. P6 j主定位边 - 晶圆片上最长的定位边。
. l. I2 e9 _4 hProcess Test Wafer - A wafer that can be used for processes as well as area cleanliness. 6 x+ a) D0 S0 u: n, \
加工测试晶圆片 - 用于区域清洁过程中的晶圆片。
* o, ]% l% ]# a7 e4 `Profilometer - A tool that is used for measuring surface topography. # _9 ]1 y# }( o' K) P: t$ b
表面形貌剂 - 一种用来测量晶圆片表面形貌的工具。 9 [6 c9 ~ P0 q8 `4 r
Resistivity (Electrical) - The amount of difficulty that charged carriers have in moving throughout material.
; X" l* F* q+ m8 R电阻率(电学方面) - 材料反抗或对抗电荷在其中通过的一种物理特性。 m% c+ J6 l [! h' l1 S0 Z1 q) Z8 a
Required - The minimum specifications needed by the customer when ordering wafers.
- N, P' f+ p* g1 L必需 - 订购晶圆片时客户必须达到的最小规格。
8 j) |7 N7 }* T- I% I' URoughness - The texture found on the surface of the wafer that is spaced very closely together.
! ~$ a# T' r9 a. W( u8 |粗糙度 - 晶圆片表面间隙很小的纹理。
8 ^3 b- F- N! |! c3 F3 u' {Saw Marks - Surface irregularities - x- y g4 S2 ?1 l9 N8 z
锯痕 - 表面不规则。 Q' X) ~, i+ N$ @
Scan Direction - In the flatness calculation, the direction of the subsites.
3 s5 A3 [7 R! { Y7 M扫描方向 - 平整度测量中,局部平面的方向。
7 N" K% j Z* H9 V+ p3 ^Scanner Site Flatness - & b r; J4 b7 j4 r
局部平整度扫描仪 - 9 j! S8 S; G. Y. e, u; w
Scratch - A mark that is found on the wafer surface. * e# p% Y; Q& }/ H
擦伤 - 晶圆片表面的痕迹。
' D& ]% s* H3 K# x5 pSecondary Flat - A flat that is smaller than the primary orientation flat. The position of this flat determines what type the wafer is, and also the orientation of the wafer. 2 Y2 B4 d' i4 g! e
第二定位边 - 比主定位边小的定位边,它的位置决定了晶圆片的类型和晶向。
9 T7 f7 \ u" j/ e7 tShape -
- j; n% K5 U# r形状 - 0 A4 a5 }. b9 D. T" b g, m
Site - An area on the front surface of the wafer that has sides parallel and perpendicular to the primary orientation flat. (This area is rectangular in shape)
6 }; h7 h# D2 X7 e) G) d7 C8 I局部表面 - 晶圆片前面上平行或垂直于主定位边方向的区域。 0 d: X I4 D- c/ @! V7 [
Site Array - a neighboring set of sites ; e: R( l) n" s- g
局部表面系列 - 一系列的相关局部表面。
& B$ E% P/ N- b' d' wSite Flatness - 6 ~7 d3 X% c9 d: {
局部平整 - 8 i$ u8 F2 n+ _# E: I- U+ D
Slip - A defect pattern of small ridges found on the surface of the wafer. . A, G* ~: ]- U5 T& v1 t
划伤 - 晶圆片表面上的小皱造成的缺陷。 ! ?) X8 }1 t3 D1 i$ [8 Q4 B& G( M# ]
Smudge - A defect or contamination found on the wafer caused by fingerprints. ]3 c) j1 C ]4 y l6 Y! J+ M. R
污迹 - 晶圆片上指纹造成的缺陷或污染。
+ R6 c6 m% F" OSori - 7 @0 C1 w, l5 E6 T
Striation - Defects or contaminations found in the shape of a helix.
; P: P5 c9 x5 t' O. X" D条痕 - 螺纹上的缺陷或污染。 - p; L0 \$ h# g6 M) D% y4 l0 u6 b
Subsite, of a Site - An area found within the site, also rectangular. The center of the subsite must be located within the original site. & H: f5 O6 x" ?+ I$ e. Q! M. U- k+ Z
局部子表面 - 局部表面内的区域,也是矩形的。子站中心必须位于原始站点内部。 0 F4 x# a! F4 a- ?: W
Surface Texture - Variations found on the real surface of the wafer that deviate from the reference surface. 4 W4 W6 ~2 z: j
表面纹理 - 晶圆片实际面与参考面的差异情况。 7 f4 L7 ~' S4 N- E
Test Wafer - A silicon wafer that is used in manufacturing for monitoring and testing purposes. & i. n4 ]- E! F- m+ C
测试晶圆片 - 用于生产中监测和测试的晶圆片。 7 n9 Z+ d6 P9 f3 E0 v- F
Thickness of Top Silicon Film - The distance found between the face of the top silicon film and the surface of the oxide layer. / l( {2 C9 m7 ?' K$ T: D K
顶部硅膜厚度 - 顶部硅层表面和氧化层表面间的距离。 0 Y, R+ R. y- M- h, u2 |
Top Silicon Film - The layer of silicon on which semiconductor devices are placed. This is located on top of the insulating layer.
# o( g R; B h q, Q1 s: R( r顶部硅膜 - 生产半导体电路的硅层,位于绝缘层顶部。
. F# D) E( \: }6 f) U$ r+ xTotal Indicator Reading (TIR) - The smallest distance between planes on the surface of the wafer.
' F6 g* r; Q1 D# F0 g总计指示剂数(TIR) - 晶圆片表面位面间的最短距离。
, S* Q4 X3 I+ g# @) G1 A% K/ X, yVirgin Test Wafer - A wafer that has not been used in manufacturing or other processes. % J% H- P' X( L0 p
原始测试晶圆片 - 还没有用于生产或其他流程中的晶圆片。 ) s" m* W+ } f5 D6 y
Void - The lack of any sort of bond (particularly a chemical bond) at the site of bonding.
* w0 D! @% `- A* p: v' k" K4 L% U无效 - 在应该绑定的地方没有绑定(特别是化学绑定)。
- T6 G6 E l: d1 i* tWaves - Curves and contours found on the surface of the wafer that can be seen by the naked eye.
& C9 ^1 M: ?8 ?. `波浪 - 晶圆片表面通过肉眼能发现的弯曲和曲线。 8 ?5 q2 u& x9 Z( }2 L. P- O" \
Waviness - Widely spaced imperfections on the surface of a wafer.
( I) b* H r% b! i' m; S波纹 - 晶圆片表面经常出现的缺陷。 |
