查看: 1026|回复: 0
[风能] Troposphere Wind
发表于 2008-11-5 08:20:54 | 显示全部楼层 |阅读模式 来自: 中国湖南湘潭
Abstract:
9 f; G7 I- v+ F9 S- y# v- I: cIn the troposphere located at 2~ 8km height above sea-level of the equator area between south latitude 30°and north latitude 30°(most areas including China, Australia), there is a strong wind which has a constant good, abundant wind energy , stable wind direction and stable high speed wind - -extremely ideal wind source for wind power(or: wind powered electricity). The wind power utilized above-mentioned strong wind as its driven force is tentatively called " troposphere wind power" by us. Troposphere wind power is characterized by high scientific technical contents, high projects difficulties
Dong Yongqi.pdf
144.18 KB, 下载次数: 2
