Abstract:
0 w. O: a9 k# M7 cIt is highly important in Japan to choose a good site for wind turbines, because the spatial distribution of wind speed is quite complicated over steep complex terrain. We are developing the unsteady numerical model called the RIAM-COMPACT (Research Institute for Applied Mechanics, Kyushu University, Computational Prediction of Airflow over Complex Terrain). The RIAM-COMPACT is based on the LES (Large-Eddy Simulation). The object domain of the RIAM-COMPACT is from several m to several km, and can predict the airflow and the gas diffusion over complex terrain with high precision. In the present study, wind simulation of an actual wind farm was executed using the high resolution elevation data. As a result, an appropriate point and an inappropriate point for locating a wind turbine generator were shown. This cause was found to be a topographical irregularity in front of the wind turbine generator. |
