查看: 1160|回复: 0
[风能] The Sliding Mode Control for the
发表于 2008-11-5 09:00:27 | 显示全部楼层 |阅读模式 来自: 中国湖南湘潭
Abstract:# C7 e* d0 c: g# a( @4 a% f* x
The variable-pitch system that increases the energy capture at low wind speeds and enables an efficient power regulation at higher than rated wind speeds is widely used in the MW level wind turbine. This paper utilizes the mathematic models of close and open pitch operation of hydraulic pitch system, adopting the sliding mode control (SMC) to carry on a simulation on the 1 MW variable-speed constant-frequency wind turbine pitch system. The simulation results show that SMC strategy adopted in the variable-pitch system can achieve an accurate pitch
& z+ Z* q) o# s. R$ X
8 c* D' h1 {( h7 T7 n% T3 H8 J[ 本帖最后由 19721212 于 2008-11-5 09:04 编辑 ]
Arno.J. Brand.pdf
156.93 KB, 下载次数: 5
By Deng Ying, Yi Chuanbao.pdf
142.38 KB, 下载次数: 4
