查看: 1131|回复: 0
[风能] The Study Of Aerodynamics And Aeroelasticity Model
发表于 2008-11-5 09:06:48 | 显示全部楼层 |阅读模式 来自: 中国湖南湘潭
Abstract:
" C3 h% `  B5 X" O7 p: v% q$ CAn aerodynamic model is development and coupled with a structural dynamic model. The BEM method with the modification of Du-Selig 3-D stall-delay model is adopted to calculate aerodynamic force. The structural dynamic model is an eighteen DOF rigid-elastic beam element including rigid displacements of flap, lag and pitch hinges. Finally, the aerodynamic model is verified and shows good agreement with experiment data.1 o9 N/ S0 \  w, f& ]/ }
Keywords:aeroelasticity, aerodynamics, wind turbines
Hong Liangyou.pdf
193.91 KB, 下载次数: 8
