查看: 1106|回复: 0
[风能] Operation Strategy Of The Pitch System In A Variable Speed Pitch
发表于 2008-11-5 09:11:13 | 显示全部楼层 |阅读模式 来自: 中国湖南湘潭
Abstract:
8 Q; k7 y7 ?1 y4 WFor a variable-speed pitch regulated (VSPR) wind turbine system, the blades will pitch to a feathered position when wind speed reaches the cut-out wind speed. This article examines the possibility for the turbine to extend its operation wind speed over the present cut-out wind speed. Pitching actions have been considered for fatigue load reduction under extreme wind condition. The final result reveals the possibility of operating in high wind speed without inducing too much fatigue load.
- N9 v% V" A( p8 TKeywords: Variable speed wind turbine, fatigue load, pitching strategy, extreme wind speed operation
Jui-Hung Liu.pdf
191.34 KB, 下载次数: 4
